Here is a list of all the postings Luker has made in our forums. Click on a thread name to jump to the thread.
Thread: Heat Resistance - Wood & Wood Products |
18/09/2023 06:27:41 |
Hi Nigel, I can't help with the types of wood you have listed, but getting a small offcut and checking how it reacts in the oven will be a good indicator. I don’t think you need something that will handle 200DegC. For the cladding I’ve done; I used scrap sleeper wood. It smells and looks like rosewood for these two models. I chamfered the corners and glued the strips to the barrel using RTV silicone. This allowed movement and kept the strips from bowing outwards. Then strapping doesn't really matter. The unpainted wood was treated with linseed oil, and the Fire Queen painted by brush using 2K. Hope this helps…. |
Thread: Help needed - Firing up my grandads steam boiler |
17/09/2023 14:57:47 |
Gentlemen, I don’t think it’s necessary to scare newbies to the hobby… A dash of respectful caution maybe, but anything more for this little kettle may be unwarranted. Matt… From the limited pictures and views it looks like the boiler and other bits and pieces are exceptionally well made, and I would be very surprised if there’s anything wrong with the boiler. It also looks like its silver soldered which is more than adequate for a small gas fired boiler like this. This set is something special, and I would enjoy and cherish it for as long as you can. The copper tubes are circulation tubes and are common on smaller boilers that are externally fired, especially when built by experienced model engineers. The blower at the chimney is probably to make the boiler look ‘cool’, with a little condensate (‘steam&rsquo It looks like the safety valve is behind the whistle on the steam dome. I would check that this lifts with a bread knife (just a fraction, if it moves its working). It should have a small groove at the top. If it’s stuck just leave it overnight in a little citric acid-water solution. Fire it up! Post a video! It all looks fantastic and I would love to see it working… PS: the sat temperature at 60PSI is around 145DegC according to the steam tables; the energy release quoted in calories is based on some rather bold assumptions of direct heat transfer not taking into account secondary convective heat fluxes and latent heat removal… |
Thread: Fire Queen construction series |
06/09/2023 16:57:39 |
Posted by noel shelley on 23/08/2023 10:19:42:
A truely beautiful model. Being a true philistine, my second thought was take off the coupling rods,change the wheels, put a perch bracket under the smoke box and turn it into a traction engine ? Noel. Sorry Noel, missed your reply! Thanks, but all credit goes to the original designer of the Fire Queen. He was a brilliant young engineer, and his design was ahead of its time. Sadly, if you read up a little on him he was clearly not as good as Gresley or Crampton in promoting and selling his work, which is often the case with brilliant engineers. Totally agree with the traction engine modification! I’ve finished the calculations and design for a lovely little traction engine of a similar era, again with the original designer far ahead of his time, and not receiving half as much credit for his work than what he deserves! Some of the castings are done already! |
23/08/2023 07:47:24 |
For everyone following the Fire Queen series, here's some pictures that show scale a little better than the ones in the magazine... |
Thread: Casting an odd cylinder |
16/08/2023 12:39:02 |
Yep, I split the pattern. I was curious to hear how the other guys would have done a pattern like this. The discoloration is actually a very interesting point. This is a type of bronze that I’ve developed for my cylinders that casts at a higher temperature than gunmetal. This alloy requires coal dust as a cushioning additive (to prevent burnon) same as when I cast iron. But on this day I cast a number of low melting point alloys like aluminium and brass where cake flour works better, and I only made one batch of facing sand. This is why there is minor oxidation on the surface. The breathers and ingate is the correct colour because my backing sand is my standard iron mix. Here’s a few pictures which illustrated how I tackled the moulding… |
15/08/2023 13:40:20 |
Hi Gents, I recently cast the following cylinder and steam chest for my next project. I thought some of the other foundry-men might enjoy some pictures (as it came out of the sand). The interesting part of the mould is how to extract the lip that bolts onto the smokebox from the sand (if you ram sand into that recess when you extract the pattern the sand will brake out). There was only one parting line which is visible in the pictures, and the only core was the core for the cylinder hole. Normal green sand was used. I’m curious to hear how you guys would attempt this. |
Thread: Casting Bronze |
09/07/2023 06:59:30 |
Hi Stephen, I make alloys from base metals often, with no issues. The pickup (amount that goes into the charge) for the bronze alloy elements is high so you don’t need to worry about losses. Fade (the amount of additive/inoculant or alloy you loose during melting) is not significant with Zinc so you won’t have any issues there. The mass loss due to the fumes typically seen is very small. 3% Zinc will dissolve very quickly and should have very little fuming. When you do the brasses you should add a capping inoculant, I placed a recipe for one somewhere on this forum. If I don't have Zinc granulate then I use brass as a zinc source, but you need to do the calculations for the amount needed on a mass basis. Cast iron is a little different. I melt from pig iron and scrap and then you need to add carbon which has a 50% pickup. FeSi is added at the end of the charge to prevent fade. Melting alloys is easy; the trickier part is in the moulds. If you’re going to cast patterns with large surface areas and low volumes (plates etc.) you’ll be fine, the trick comes in when casting, for example, cylinders (large volume/surface area ratio) which require careful feeding to prevent draw etc. PS: your furnace should be built in such a way that the fumes are carried with the exhaust up away from where you stand when casting etc. Be aware of the fumes but don’t let it deter you. I have a tradition of going for a 10Km run after a day of casting to ‘wind down and relax’ and it’s always a pleasant run… |
Thread: Some model engineering in sunny South Africa |
08/05/2023 13:52:31 |
We starting to get the stationary engines running again after the recent vandalism... The members are incredible how they can do so much with so little, hats off to the guys! |
31/03/2023 14:24:05 |
Posted by duncan webster on 31/03/2023 11:19:18:
Did you get Hal from 2001 a space odessy to do the voice over? A little before my time |
31/03/2023 06:08:41 |
Hi guys, the Fire Queen series has started in Model Engineer. I hope all the readers enjoy the write-up. I've just finished the copper boiler design and description so that will be included somewhere down the line. I put the following video together with a few additional pictures that never made it to print, please excuse the narration, AI is much better at reading to script than I am! |
09/03/2023 05:28:09 |
Posted by Hopper on 08/03/2023 22:18:35:
Very sad about the thefts. Irreparable damage to pieces of history. Seems a big problem in SA. I have read reports that the railways were in danger of shutting down due to such widespread theft of overhead cables, and in one case a whole six miles of the actual tracks. Sounds pretty desperate. Yep, we have a big problem, and I think you probably only hear a fraction of what's happening. I wouldn't want to burden you guys with our problems, that's just not fair and it’s not why I started this thread! Once we get a hold of the situation I might reach out to you guys for help on fixing what was damaged, specifically drawings and technical info. I know there are a few forum members with access to museum archives, and this forum is always willing to help! -14DegC…. No words! |
08/03/2023 05:14:31 |
Hi Gentlemen, I've got some sad news from the RSME. We've been battling with theft recently and it's gotten to a point where engines have been seriously damaged. The windows have been welded shut and an alarm system installed. I also did a video to try and get the community involved, or at the very least let them know what they are loosing (added the video below). Other than that, not sure what else we can do? |
Thread: Motorcycle General Discussion |
26/01/2023 11:51:35 |
Posted by Hopper on 26/01/2023 11:19:44:
The thing about building a special is every little thing on them is so, well, special....
Been enjoying the pictures (and notes), not an easy thing you doing there! It’s an interesting exercise swopping between a classic British and a modern bike, feet get a little mixed up... Not as complex, but some interesting engineering none the less. Designed an automatic lubrication system for my Blackbird recently...
Thread: Boiler construction |
25/01/2023 15:57:24 |
Hi Garry, The main difference, as you pointed out, is cost. The joint design for the two different boiler construction methods needs to change, but provided the boiler is designed for the specific joint construction method there will be no difference. I have designed and built both TIG and silver soldered boilers and both work perfectly. My personal preference is TIG due to cost, and the fact that a crown stay is safer to construct using TIG (silver solder could let go when heating the stays in the firebox, and has happened once to me. A mission to fix!). BTW those prices are ridiculous! You can buy a decent second hand vehicle for that (in my neck of the woods)… |
12/01/2023 15:38:29 |
Posted by Oldiron on 12/01/2023 12:45:35:
Looks like a nice active club. Pity the cameraman stands in the way. regards It takes great skill for the cameraman to be in the shot and participate Yep we have a fantastic club, and the guys have been great with making these videos for our Facebook page. |
12/01/2023 11:22:32 |
A short video of one of the young engineers at the RSME assembling a steam oiler clack valve he made himself for the club loco. This was some of the maintenance done during December 2022. The beginning gambit is indicative of the times we living in, and will probably be more appreciated by the locals! |
Thread: Stephensons valve gear |
28/12/2022 13:27:23 |
Posted by Nigel Graham 2 on 28/12/2022 10:17:55:
On the matter of Lead: Every text I have seen (including ones written for professional use) states that with notching up, the lead with - - Stephenson's Link Motion ( and presumably its similar ones like Gooch and Allen) increases; - Radial Gears (Hackworth and its equivalents, Walschaert's / Baker, etc). remains constant. I don't know its name but the gear on Luker's video image appears a combination of Stephenson's and Gooch; the reverser moving the valve radius-link (G); but the expansion link curve faces the eccentrics (S) from a fixed suspension (also G). The animation shows the gear in one position so I could not determine if this is so.... Hi Nigel, the standard Gooch valve gear is a constant lead valve gear. The animation and video is also for a standard Gooch valve gear I designed and built. The orientation of the expansion link is, as you rightly pointed out, reversed but this doesn't change the valve gear motion. It’s just the eccentric offset relative to the driving crank that changes. I’ve designed and built a few different Stephenson’s valve gears and the most notable difference to the Gooch valve gear is the expansion link that is lifted instead of the valve rod. Some nice examples are the inside cylinder and frame classical Stephenson valve gear… The outside cylinder with rocker (changes the set point to get the lead correct when back notching)… And the most difficult Stephenson’s valve gear I’ve had to design so far (more fun than I’ve had designing anything else!)… Edited By Luker on 28/12/2022 13:33:10 |
28/12/2022 06:34:25 |
28/12/2022 06:33:58 |
Posted by Perko7 on 27/12/2022 08:35:58:
Ok, I've been reading up on this subject for a little while and have viewed the Dockstader simulations and read most of what Don Ashton has written, but there is still one thing that puzzles me. Most (if not all) the simulations and design texts assume that the valve rod is suspended in a fixed position and the expansion link is lowered or raised to provide forward and reverse running. The original drawings for the loco I am constructing have the expansion link suspended in a fixed position and the valve rod raised or lowered to provide forward and reverse.
This does sound like the Gooch valve gear, or a variation of it. Regardless the first principles will be the same. The expansion link radius matches the length to the CL of the eccentric rods for constant lead. If you want to increase lead when back notching this radius needs to change, but then you could just as well modify the setup to be the Stephenson’s valve gear. Because you need to split the expansion link the material thickness needs to be thicker than true scale to prevent pin wear and slack on the valve gear. The mid-gear position isn’t on the CL relative to the driving axel, so I suggest cutting the reversing lever stand slots right at the end. The CL needs to be designed slightly lower to improve balanced valve opening. Unfortunately, you’ll probably only find passing mentions of these types of valve gears due to die slip issues that was difficult to design out on paper. But with more modern techniques you can actually design a very satisfactory valve gear. Some of my simulations… |
18/12/2022 16:57:47 |
And a video after the flooding we had a little over a week ago. The guys have done an amazing job at the RSME! |
