Robin Graham | 29/04/2021 01:17:06 |
1089 forum posts 345 photos | I have quite a few CCMT/CCGT inserts which are worn or chipped on the 80 degree corners but pristine on the 100 degree. I can't find holders to use the 100 degree corners though - probably not using the right search terms. They must exist! Can anyone advise? Robin. |
Paul Lousick | 29/04/2021 03:05:11 |
2276 forum posts 801 photos | I have seen them but only on DIY forums. You may have to make your own. Paul |
David Colwill | 29/04/2021 05:52:52 |
782 forum posts 40 photos | Hi, Here is a link to APT Link If you google the tool code (SCBCRxxxx) you may find them on eBay. David. Edited By David Colwill on 29/04/2021 05:54:49 |
DiogenesII | 29/04/2021 06:41:16 |
859 forum posts 268 photos | UK made and cheap.. |
JasonB | 29/04/2021 06:54:22 |
![]() 25215 forum posts 3105 photos 1 articles | You can also get SClCL which is the left hand one for facing, I got both L & R from JB Tools. Edited By JasonB on 29/04/2021 06:55:32 |
David George 1 | 29/04/2021 07:24:25 |
![]() 2110 forum posts 565 photos | I have one from JB tools l can turn and face with same tool holder. https://youtu.be/vzrhyDr4JBM David
robjon44 | 29/04/2021 08:29:54 |
157 forum posts | Back in the day we campaigned 80 degree rhombic turning tools using 12 16 & 19mm tips, we also had holders to use up the obtuse angled corners as well, these murdered things like square or other irregular shaped components in both steel & cast iron & saved the company vast amounts of money! If you are as tight fisted as I am it is perfectly feasible to make your own, don't ask me how I know, set out from positive rake tips in the home workshop. BobH |
Clive Foster | 29/04/2021 08:51:05 |
3630 forum posts 128 photos | i have a Sandvick branded one that I regularily forget to use so the pile of inserts with good 80° corners just keeps piling up. Rhombic inserts do a decent job at both turning and facing when the tool is set at 90° to the bed that its so convenient not to bother changing. Especially as being a mostly HSS guyI don't use "that" many inserts. Averages out about 2 or 3 a year so the bargain stash of 6 Sandvick boxes bought "mumble-mumble" years ago is lasting well. Clive Edited By Clive Foster on 29/04/2021 08:51:25 |
Niels Abildgaard | 29/04/2021 08:55:19 |
470 forum posts 177 photos | An old describtion of a homemade,ultra-rigid
Andrew Tinsley | 29/04/2021 09:27:16 |
1817 forum posts 2 photos | I had exactly the same problem and I was guided towards Jenny Blackwell of JB Tools. She has exactly what you want at the right price and I believe they are made in the UK. Andrew. |
Bo'sun | 29/04/2021 09:50:39 |
754 forum posts 2 photos | Another vote for JB tools |
jacques maurel | 29/04/2021 10:32:32 |
![]() 84 forum posts 20 photos | Hello I've sent a detailed article to Neil (MEW editor) on how to machine these tip holders and others, just wait for the publication. JM |
Howard Lewis | 29/04/2021 12:24:26 |
7227 forum posts 21 photos | Greenwood Tools used to sell such holders so that the 100 degree corners could be used. They are shutting down, so be quick and take a look, if Jenny Blackwell can't help you. I use mine for roughing, but they give a good finish anyway. Howard Edited By Howard Lewis on 29/04/2021 12:25:14 |
Daniel | 29/04/2021 15:22:05 |
![]() 338 forum posts 48 photos | I JB Cutting Tools
Robin Graham | 29/04/2021 23:32:15 |
1089 forum posts 345 photos | Thanks all - just what I needed. I have bought inserts from JB (and had excellent service), but didn't think to look there. An order will be winging its way to JB. Niels - thanks for the link to your ultra-rigid holder. That looks good. Apart from your holder, the thread is informative in general about the use of carbide tooling in a home workshop. It's sad to hear that Greenwood is closing. I have a KIT-Q-CUT parting tool which I bought from them years ago at a show (remember shows?). It's a wonderful tool - zips its way though pretty much anything. Robin. |
Niels Abildgaard | 30/04/2021 09:14:18 |
470 forum posts 177 photos | Hello Graham Thank You for kind words. There are pictures of Your lathe in album. What is size of lathe and can I have a picture of the headstock with internals? And spindle bearing numbers? I am interested as the screwcutting geartrain seems to be the same as in my future (and latest. I swear) dream lathe. Chineese of course and a 38mm bore for 1000$ called CJ0625. The same gentleman explain carbide part off tooling (and I hijack the thread here) Edited By Niels Abildgaard on 30/04/2021 09:15:08 |
Robin Graham | 30/04/2021 23:10:37 |
1089 forum posts 345 photos | Hi Neils. My lathe is of the generic Chinese 12x36 design - there are many variations, but the particular variant I have came from Axminster Tools. You can find a manual which gives some info about the headstock / screwcutting gearbox internals here . In the US Grizzly used to sell a very similar machine, marketed as a gunsmith's lathe - the (rather more detailed) manual for their variant can be found here . The Grizzly headstock spindle and gearbox arrangements appear to be identical to those in my machine, but the threading / power feed box is somewhat different. [Edit] I had a quick look and it seems the CJ0625 - if that's the one you're looking at- is an entirely different animal, so the above might not be of much use! If I can help further it might be better to continue discussion by private message, as its a bit off-topic here. Thanks for the link to the discussion of carbide parting tools on HMEM. Your step parting technique is interesting - as well as the Greenwood tool (which uses 2.2mm Sandvik Coromant inserts I think) I have an ARC tool which uses 3mm GTN inserts, so it could be a useful method for me in some circumstances. Robin.
Edited By Robin Graham on 30/04/2021 23:11:42 Edited By Robin Graham on 30/04/2021 23:15:04 Edited By Robin Graham on 30/04/2021 23:18:17 |
Niels Abildgaard | 01/05/2021 03:49:56 |
470 forum posts 177 photos | Hello Robin and thank You for links. Exactly what I wanted to look at. The CJ0625 is a very different animal but the procedure described in the Grizzly manual of Yours is universal for adjusting spindle bearings and has been bookmarked. Niels |
Ian Hewson | 02/05/2021 15:07:08 |
354 forum posts 33 photos | Another thumbs up for JB tools, great service from Jenny and some spare tips thrown in free gratis. ian |
ega | 07/05/2021 12:04:30 |
2805 forum posts 219 photos | The Glanze holders I bought from Axminster came with this card: SCBCR and SCKCR use the 100 deg corner. |
