Alain Foote | 26/03/2021 17:58:11 |
69 forum posts 10 photos | Question for you all, some of my steel rules are getting difficult to read as the graduations are no longer black. Any ideas how best to restore them please? |
SillyOldDuffer | 26/03/2021 18:23:54 |
10668 forum posts 2415 photos | My best attempt was with shoe polish, but printers ink is recommended in one my old books. I believe they mean the old-fashioned sticky ink full of carbon, not the modern fluid types. The rule face is coated with it and then the surplus is removed squeegee fashion with a straight edge, leaving the ink behind in the engraving to dry. Not tried it, but I believe Letterpress Ink is the modern equivalent. Dave
Brian H | 26/03/2021 18:26:11 |
![]() 2312 forum posts 112 photos | Engraving wax should do the track, it is rubbed in and then lightly polished with a tissue. Brian |
Peter Cook 6 | 26/03/2021 18:29:04 |
462 forum posts 113 photos | Clock dial engraving is filled with black engravers wax ( a.k.a elephant wax). That might work OK. It is applied by heating the engraved Item to melt the wax into the engravings. Squeegee excess wax off using a knife while soft. let it harden then remove the film of wax left using wire wool or fine wet and dry. Then polish. A new steel rule might be cheaper and far quicker |
Adam Mara | 26/03/2021 18:40:30 |
198 forum posts 1 photos | Black cellelose paint! but don't know if you can get it now! |
old mart | 26/03/2021 19:06:20 |
4655 forum posts 304 photos | If they were originally engraved, they would have been chemically blacked all over and then rubbed down leaving the black in the numbers and scales. There may not be enough depth to repeat the process. |
David George 1 | 26/03/2021 22:12:33 |
![]() 2110 forum posts 565 photos | I used to fill lettering etc on labels for tooling pre engraved I used paint sticks from RS components. Paint over engraving let to dry and clean off with a solvent damped cloth. I had red black and yellow. Edding Black 10mm Broad Tip Paint Marker Pen for use with Metal David Edited By David George 1 on 26/03/2021 22:21:30 |
Alain Foote | 27/03/2021 09:34:37 |
69 forum posts 10 photos | Thanks for all the replies, I have ordered some Black Engravers Wax to try that. Will report back when I have tried it. |
Alain Foote | 03/04/2021 20:58:30 |
69 forum posts 10 photos | Well I tried the Black Engravers wax and that was a failure. I think the trouble is that the markings are not deep enough. Might give up and buy a new rule! |
Neil Wyatt | 03/04/2021 23:40:26 |
![]() 19226 forum posts 749 photos 86 articles | The traditional material is gunge from the swarf tray... Neil |
Russell Eberhardt | 04/04/2021 10:43:55 |
![]() 2785 forum posts 87 photos | Posted by Neil Wyatt on 03/04/2021 23:40:26:
The traditional material is gunge from the swarf tray... Neil Applied by loosing the rule for a few weeks under the swarf? Russell |
Phil P | 04/04/2021 11:41:41 |
851 forum posts 206 photos | I use a black "Sharpie" pen, and rub the unwanted overspill away with a fine garryflex block. Phil |
Alain Foote | 04/04/2021 12:29:01 |
69 forum posts 10 photos | Thanks Phil, I’ll try that. Alain |
Peter Ellis 5 | 06/04/2021 21:47:12 |
110 forum posts 11 photos | This stuff is very good. The trouble is that post Brexit, they want a fortune to send it from Germany. https://euro-industry.com/main.php?index=details&cat=91&prod=23197370
Peter Ellis 5 | 06/04/2021 21:48:05 |
110 forum posts 11 photos | Brownells unfortunately no longer list it.
Trevor Drabble | 06/04/2021 22:19:46 |
![]() 339 forum posts 7 photos | H S Walsh and Son normally stock both hard and soft engraving waxes . |
V8Eng | 06/04/2021 22:38:20 |
1826 forum posts 1 photos | If you are looking for Markal products there is a company called Walters & Walters in Hertfordshire who stock the make. A quick search should locate their website. Edited By V8Eng on 06/04/2021 22:39:13 |
