Member postings for Alain Foote
Here is a list of all the postings Alain Foote has made in our forums. Click on a thread name to jump to the thread.
Thread: Belt/disc sander
24/08/2023 17:20:19
Thread: channel section
05/08/2023 20:11:18
You could try here **LINK** this is now sold by Steam Workshop I believe, but was designed for underframes so may be suitable.
Thread: Bright steel
03/05/2023 17:37:02
Stephen are you using a tapping compound e.g. Rocol RTD? Especially helpful if it’s stainless steel or gauge plate etc. What size thread/pitch/thread form? What is the material grade?
Alain
Thread: Steam Raising Blower
06/02/2023 18:43:26
Here is a ready made one **LINK**
06/02/2023 16:51:37
Model Engineers Laser do Blower parts, don’t know if it’s for Cliff’s design though.
Thread: Gordon Smith Safety Valve Design
10/11/2022 17:05:19
Thanks Norm, the old ones were single piece body, but the new ones will have a two piece body so that it will certainly be possible to get a good finish and concentricity on the seat.
10/11/2022 08:02:48
Thanks Jeff, that’s useful, Alain
09/11/2022 17:52:15
I am making some new safety valves for my 7 1/4 NG loco to the Gordon Smith design. I was wondering whether it is intended that the ball should be fixed in the guide/shroud or allowed to rotate. Any thoughts? Also any thoughts on whether to use the light hammer tap to seat the ball or whether to burnish the seat using Brasso or lapping compound, what do you think?
The existing safety valves were made to the EIM drawing scaled up, but this time I am making them a two piece body to the 7 1/4 NG design from Polly. I have never been happy with the old valves because they don’t reseat properly until the pressure has fallen by 15 to 20 p.s.i and even then they leak a bit!
Thread: Meddings dril tru Bench Drill Repair.
24/10/2022 16:15:08
img_4634[1].jpgHello Bob I confirm that on my drill it is 3/8" BSF see pictures.
Edited By Alain Foote on 24/10/2022 16:16:19
20/10/2022 09:35:47
20/10/2022 09:33:50
Bob, I have measured my Meddings, it is 60 deg.
Thread: Cliff Almond, William Spence, Guinness loco: Contact?
07/08/2022 20:35:29
Have you tried [email protected]?
Thread: Electric plug identification
11/07/2022 07:38:02
Sorry fizzy, but couldn’t find a spare in the workshop. Looks like you are sorted now anyway.
10/07/2022 21:20:09
I may have a spare 240V one in the workshop, will look tomorrow.
Alain
Thread: Laser or water-jet cutter who hold stock of spring or tool steels
08/02/2022 08:14:06
Try Model Engineers Laser **LINK**
Thread: Correct Drill Bit For 3/8” UNC Tap
23/10/2021 21:53:30
14.75 mm is the tapping size for 3/8” British Standard Pipe Thread which is 19 tpi. As previously mentioned the tapping drill for 3/8” UNC is much smaller at around 5/16”.
Thread: Kennedy Power Hacksaw Gaiter
07/06/2021 22:26:53
I have something if you message me with your email Leslie
Alain
Thread: Four facet drill grinding.
26/04/2021 17:13:12
DAG Brown Model Engineer 1994 no. 3968 is a good starting point.
Thread: Steel Rule Graduations Re-Blacking
04/04/2021 12:29:01
Thanks Phil, I’ll try that.
Alain
03/04/2021 20:58:30
Well I tried the Black Engravers wax and that was a failure. I think the trouble is that the markings are not deep enough. Might give up and buy a new rule!
