jon hill 3 | 01/09/2020 11:13:58 |
166 forum posts 40 photos | I am having great difficulty centering an independent 4 jaw chuck does anyone have any quick or fool proof methods? |
Ady1 | 01/09/2020 11:16:40 |
![]() 6137 forum posts 893 photos | I use the toolpost / side of the tool and finish with DTI You can do the job 98% by eye It's like sex The more you do it the easier it gets |
roy entwistle | 01/09/2020 11:16:53 |
1716 forum posts | Use two chuck keys on opposite jaws |
IanT | 01/09/2020 11:17:24 |
2147 forum posts 222 photos | Depends on what kit you have to hand. I generally use two centres and a DTI Regards,
IanT |
Former Member | 01/09/2020 11:21:47 |
1085 forum posts | [This posting has been removed] |
jon hill 3 | 01/09/2020 11:25:45 |
166 forum posts 40 photos | Thanks guys all useful tips, currently I just use a dti on say round bar. I think I will make a new 2nd key as my next mini project. |
Mick B1 | 01/09/2020 11:30:07 |
2444 forum posts 139 photos | If you can grip the piece in the drill chuck, offer it up from the tailstock end and carefully close the chuck jaws onto it. You should be within a few thou and well inside clock gauge territory by then. |
SillyOldDuffer | 01/09/2020 11:42:53 |
10668 forum posts 2415 photos | Posted by roy entwistle on 01/09/2020 11:16:53:
Use two chuck keys on opposite jaws +1 And practice! I position the job roughly by eye, sometimes using a centre in the tailstock as a reference, sometimes with the lines on the chuck, at this stage not tightening the jaws. Easiest and most accurate to measure offset with a DTI, but it can be done by eyeballing the gap between a cutter and job. With two jaws horizontal, set the DTI. Then rotate through 180 degrees to measure the difference. Turn the keys in opposite directions to halve the difference, tighten one while slackening the other. Rotate back through 180 degrees, measure the new difference and halve again. Then set the other two jaws horizontal and centre them with the same process. At this point, the job should be more-or-less accurately centred. Spin through a full turn to see how good or bad it is, and repeat the 'halve the DTI difference' with two chuck keys as necessary. Tricky bits;
I cracked it by spending a few hours doing nothing but centring various objects in my 4-jaw. Initially I had to think every move out, now it comes naturally. Dave Edited By SillyOldDuffer on 01/09/2020 11:44:34 |
Hopper | 01/09/2020 11:47:04 |
![]() 7881 forum posts 397 photos | Two chuck keys are good. Getting it roughly right by eye against the tool bit is good. Then the easy way to finish off is this:
I did it the old, hard, trial-and-error dial indicator way for 40 years before discovering this so-simple no-brainer quick method. Hope you are smarter than I was. The simplicity and effectiveness of this method still leaves me gobsmacked. Edited By Hopper on 01/09/2020 11:51:05 Edited By Hopper on 01/09/2020 12:04:08 |
Alan Johnson 7 | 01/09/2020 12:34:31 |
127 forum posts 19 photos | By eye - use the tool or tool holder to give you an indication. Then, digital DTI. It is easy (if you have one). Set to zero at jaw 1, rotate to jaw 3. DTI will give you a + or - error. Halve it, and adjust jaws to correct. Likewise jaw 2 and 4. Practice on a bit of round bar first. As others have said "prctice makes perfect." |
Gary Wooding | 01/09/2020 12:56:34 |
1074 forum posts 290 photos | I use a method which is very quick and accurate, but not, it would seem, very well known. ***THIS*** PDF explains the method. Although not absolutely necessary, the use of two chuck keys makes life much easier. |
Tony Pratt 1 | 01/09/2020 13:05:44 |
2319 forum posts 13 photos | Never felt the need for 2 chuck keys & lots of practice works wonders. Tony |
not done it yet | 01/09/2020 14:04:17 |
7517 forum posts 20 photos | If it is smallish round bar, you need to get it fairly close before tightening anything. Otherwise, if two jaws are OK and you are trying to adjust the other pair, the tight jaws may prevent the bar from moving as you might expect it to - due to trying to force a larger diameter through the already tight pair of jaws. Quite often, I don’t bother to change from a 4 jaw independent chuck to a self-centring one unless for a better reason than centring the odd new workpiece (I might if I was using smaller chucks than 160mm🙂 ). |
duncan webster | 01/09/2020 14:21:45 |
5307 forum posts 83 photos | Posted by IanT on 01/09/2020 11:17:24:
IanT Instead of 2 centres I have a bit of 3/16" rod about 12" long with a point on one end. Grip the non pointy end in the drill chuck in the tailstock and apply DTI towards the pointy end. Saves swapping from chuck to centre. One of these days I'll get round to loctiting a bit of bigger stuff to the non pointy end so that the DTI can be applied when the eccentricity is higher. I'll put a flat on it so it doesn't roll off the shelf, but not run the DTI on the flat. When applying it to the centre pop, I wind the tailstock out until the handle is at the back before locking the tailstock, The weight of the handle then keeps the point in the mark |
Howard Lewis | 01/09/2020 14:30:46 |
7227 forum posts 21 photos | Like IanT I use two centres, and a finger clock as the job comes nearer to being centred. This is extremely helpful where the job is either deliberately eccentric, or irregular in shape. I made a second key for the "baxk" jaw, but very rarely use it. Practice makes perfect. the more that you do it, the easier and quicker it becomes to centre work. Howard
SillyOldDuffer | 01/09/2020 15:29:57 |
10668 forum posts 2415 photos | Posted by Hopper on 01/09/2020 11:47:04:
... the easy way to finish off is this:
Just tried Hopper's method only to find it took longer. Despite understanding the logic I slowed down just because the method is slightly different from what I'm used to. Hard to break old habits I guess. I shall persist : Hopper's way must be easier! Dave |
Gary Wooding | 01/09/2020 16:21:30 |
1074 forum posts 290 photos | Posted by SillyOldDuffer on 01/09/2020 15:29:57:
Just tried Hopper's method only to find it took longer. Despite understanding the logic I slowed down just because the method is slightly different from what I'm used to. Hard to break old habits I guess. I shall persist : Hopper's way must be easier! Dave It is - it's the same way as described in my link. |
mechman48 | 01/09/2020 17:23:30 |
![]() 2947 forum posts 468 photos | Posted by IanT on 01/09/2020 11:17:24:
IanT This is also my preferred method, have also used the two chuck keys method.I find this one the easiest. George. |
Hopper | 01/09/2020 22:55:40 |
![]() 7881 forum posts 397 photos | Posted by Gary Wooding on 01/09/2020 16:21:30:
Just tried Hopper's method only to find it took longer. Despite understanding the logic I slowed down just because the method is slightly different from what I'm used to. Hard to break old habits I guess. I shall persist : Hopper's way must be easier! Dave It is - it's the same way as described in my link. It's not my way. I saw it published in MEW about 2 or 3 years ago. Can't remember the author's name. A Scandinavian chap maybe. He described it more clearly with illustrations. |
peak4 | 02/09/2020 00:10:04 |
![]() 2207 forum posts 210 photos | Here we have quite neat way of centring square bar in a 4 jaw. Bill |
