Chris TickTock | 31/07/2020 19:36:07 |
622 forum posts 46 photos | Hi Guys, Currently I am going back to machining fundamentals. Reason: If you don't have a grasp of these you are ill prepared. So OK you are told different speeds for a given diameter of say mild steel, silver steel, brass or aluminium. But can any one explain why it is advised to go at a given speed for a harder / softer metal. Chris |
Cabinet Enforcer | 31/07/2020 20:02:03 |
121 forum posts 4 photos | Posted by Chris TickTock on 31/07/2020 19:36:07:
The "best" speed is due to the relationship between the mechanical properties of the material (shear and yield strength, Youngs modulus, etc) and the mechanism of chip formation, also often limited by the properties of the cutting tool. Practically speaking, it because that that is the speed that "works". |
HOWARDT | 31/07/2020 20:07:14 |
1081 forum posts 39 photos | There is a lot of science involved. Basically it is how the material being cut reacts with the cutting edge of the tool. If you compare the same material with different cutting edge profiles it will give you some idea. Tool manufacturers such as Sandvik have numerous solutions and in production machines it may take numerous trials with a particular machine to get to an optimum tool life. You can search online and find many articles on the science behind it all. With small hobby machines and a single type of tool for everything much is trial and error, what works for doesn’t for another. |
Dave Halford | 31/07/2020 20:45:18 |
2536 forum posts 24 photos | Posted by Cabinet Enforcer on 31/07/2020 20:02:03:
The "best" speed is due to the relationship between the mechanical properties of the material (shear and yield strength, Youngs modulus, etc) and the mechanism of chip formation, also often limited by the properties of the cutting tool. Practically speaking, it because that that is the speed that "works". I would also add it's also the speed that removes the most metal in the least time at the best cost of cutting tool. They assume you have at least a Harrison 300, some tables list the HP require to achieve the speeds and full flood coolant. Hence Mr Wheelers question if you saw it in time. Nice to know for college courses but not really relevant to the man in a shed, ultimately 'it depends' Edited By Dave Halford on 31/07/2020 20:47:26 |
Paul Kemp | 31/07/2020 23:17:47 |
798 forum posts 27 photos | "Hence Mr Wheelers question if you saw it in time." The mysterious disappearing post! I wondered about that as it vanished almost in front of my eyes, without trace! Sense and sensibilities ensuring inclusivity and diversity I guess? fpm is directly scalable from a Sherline to a Holbrook but that is where the similarity and theory end and why cutting speeds and feeds are recommended and not compulsory, dependant on tool material and geometry, machine rigidity, the way the work is held etc. The chances of getting a consensus on the OP question is about as likely on here as agreement on which lathe is best. Paul. |
Mike Poole | 31/07/2020 23:36:52 |
![]() 3676 forum posts 82 photos | Someone has gone through the pain of testing how materials machine with different tool materials and cutting angles, clearances and speeds. They are not set in stone but provide a good start point, they will always be a compromise so feel free to deviate. If your tool fails prematurely then you have gone the wrong way, if the finish you desire is not being produced then you need to determine where your problem lays. In my experience the recommended speeds, feeds and angles are not far out. It is probably better to go with the recommendations of hobby authors than full on industrial machine recommendations. Mike |
Ady1 | 01/08/2020 08:01:13 |
![]() 6137 forum posts 893 photos | On a small hobby machine it's often suck it and see If you do a big piece cutting can be not very good on the outside and improves as you whittle it down Not so easy to see subtle differences on a larger powerful machine because it compensates for more issues On the other hand a unimat sl shows you everything, a unimat is great for showing you good tool grinding angles since you have almost no stiffness Edited By Ady1 on 01/08/2020 08:02:59 |
Kiwi Bloke | 01/08/2020 08:07:39 |
912 forum posts 3 photos | I'm sure you can find more than enough explanation in books - remember them? However, in the home workshop, what works is what matters... Suck it and see. |
JA | 01/08/2020 08:34:57 |
![]() 1605 forum posts 83 photos | Posted by Kiwi Bloke on 01/08/2020 08:07:39:
I'm sure you can find more than enough explanation in books - remember them? However, in the home workshop, what works is what matters... Suck it and see. Suck it and see also applies in industry. For example a lot of high temperature alloys can be machined but since very few businesses use them there is not real "knowledge". So manufacturing engineers have to find cutting speeds. The easiest way is to put a piece in a lathe......... JA |
Michael Gilligan | 01/08/2020 08:54:47 |
![]() 23121 forum posts 1360 photos | Posted by Paul Kemp on 31/07/2020 23:17:47:
"Hence Mr Wheelers question if you saw it in time." The mysterious disappearing post! I wondered about that as it vanished almost in front of my eyes, without trace! […] . Presumably removed by a moderator, as deletion of the content [by Mr Wheeler] would leave a trace. I didn’t see it MichaelG. |
larry phelan 1 | 01/08/2020 09:30:43 |
1346 forum posts 15 photos | Try Sparey,s book, still good after all this time. Simple Direct No bull. |
Nick Wheeler | 01/08/2020 10:37:32 |
1227 forum posts 101 photos | Mr Wheeler did wonder where, and why, it had gone! |
john halfpenny | 01/08/2020 10:42:02 |
314 forum posts 28 photos | Mr Wheeler, I thought it was incisive and excellent advice-but it disappeared. |
Chris TickTock | 01/08/2020 11:01:16 |
622 forum posts 46 photos | Than you for those that answered sensibly which was at a basic level the stock materials yield and strength have most to do with book suggested speeds. I see nothing wrong with asking what others may take as obvious or just get on with it type of questions. The marriage of handed down knowledge with hands on suck and see experience is likely to produce superior results to just having a go. I am a man in the shed in no rush to go any where. Those who like being rude or have a propensity to be intolerant on this forum may be impressing a certain type whilst alienating another. Chris |
Emgee | 01/08/2020 11:30:09 |
2610 forum posts 312 photos | Posted by john halfpenny on 01/08/2020 10:42:02:
Mr Wheeler, I thought it was incisive and excellent advice-but it disappeared. I also thought it was good advice although very much straight to the point, a very similar comment has been made but not in such a direct manner. Emgee |
Dave Halford | 01/08/2020 12:38:36 |
2536 forum posts 24 photos | Posted by Chris TickTock on 01/08/2020 11:01:16:
Than you for those that answered sensibly which was at a basic level the stock materials yield and strength have most to do with book suggested speeds. I see nothing wrong with asking what others may take as obvious or just get on with it type of questions. The marriage of handed down knowledge with hands on suck and see experience is likely to produce superior results to just having a go. I am a man in the shed in no rush to go any where. Those who like being rude or have a propensity to be intolerant on this forum may be impressing a certain type whilst alienating another. Chris Chris, The answers to most of your general lathe questions are, as Larry suggests in Spareys book and others, perhaps Jasons and Neils 'how to' series in the mag would be more to your liking. The reason why most replies involve 'suck it and see' is that we have found out not all small lathes behave the same. I know you feel like you are missing knowledge that would make you better at turning and you are, it's what comes from trying stuff out on your machine.
Chris TickTock | 01/08/2020 13:06:13 |
622 forum posts 46 photos | Posted by Emgee on 01/08/2020 11:30:09:
Mr Wheeler, I thought it was incisive and excellent advice-but it disappeared. I also thought it was good advice although very much straight to the point, a very similar comment has been made but not in such a direct manner. Emgee Agreed, a little diplomacy often helps. Chris |
ChrisB | 01/08/2020 15:50:31 |
671 forum posts 212 photos | I find it much easier to get a good finish on a small lathe with a VFD as I can alter the speed while taking a cut. The finish will change with rpm. But as mostly said above, it's trial and error, I know there are books and recommendations etc...but I'd rather make some swarf first, and then post the results and questions on the forum, probably you will get more meaningful answers. Edited By ChrisB on 01/08/2020 15:52:27 |
larry phelan 1 | 01/08/2020 16:36:17 |
1346 forum posts 15 photos | Chris Tick Tock, I hope you did not think I was being smart or rude with my reply, this was not my intention. The reason I mentioned Sparey,s book is because, like you, I had little or no idea regarding cutting speeds/materials ect, but this book explains it all in plain terms. If it is now out of print, more,s the pity, since it,s a goldmine of information for beginners [like me ] No doubt there are many other good book available, I just never felt the need to look any further than this one since it seems to cover almost everything. No doubt others here will advise you on the subject but the speeds given by Sparey are ; Stainless Steel 50ft per min Carbon Steel 60 Cast Iron,, Mild Steel Wrought Iron 80 ft per min Brass 200 Aluminium and its Alloys 300.
To calculate revs Cutting speed divided by quarter of work diameter= r-p-m Sorry if I sounded like a Smart-Arse, that is far from the case, I can assure you ! |
jann west | 01/08/2020 17:16:27 |
106 forum posts | some people find the following to be helpful as a starting point for feeds and speeds: **LINK**
you use a ruler, to indicate the correct speed, like so: **LINK** |
