Here is a list of all the postings Cabinet Enforcer has made in our forums. Click on a thread name to jump to the thread.
Thread: Definition of Handycrafts in Show competition |
06/08/2023 11:34:37 |
People entering stuff they didn't make has always been an issue in this sort of event, a good judge would have picked up on it, there is no need to "ban" such entries. Edited By Cabinet Enforcer on 06/08/2023 11:35:41 |
Thread: Anyone any experience of a Chester Model T Super Mill |
19/07/2023 14:34:23 |
Posted by Andrew Johnston on 19/07/2023 11:31:10:
Just out of idle curiosity do these types of mill have a seperate motor for the horizontal spindle, or is power transferred from the motor on the vertical head? Andrew The Warco spec page lists two seperate motors, 1.5kW vertical and 1.1kW horiz. |
Thread: Robot under-tree bramble destroyer |
13/07/2023 20:53:46 |
Posted by Bill Phinn on 13/07/2023 18:53:42:
Whether they use plastic line or metal attachments, potential damage to the trunks of Roger's orchard trees would rule those out for me. Anything that can clear brambles will be capable of harming even quite mature trees, the operator needs to be careful where they point it! The 4mm line on my brushcutter would easily kill my 10 year old apple trees if I was careless with it. I'm sure it would be possible to constuct some sort of stand-off guarding for the wheeled machines,but it would be rather unwieldy, better to watch where you are going.
Posted by Bill Phinn on 13/07/2023 18:55:41:
While we're at it, have a read about the fate of Anthony Robinson.
It isn't mentioned in the article, but I believe this was the first ever instance of an EU wide product ban arising from the product alert system. Of course now you can buy all manner of lethal power tool attatchments direct from your favourite website, particularly mind boggling is the version of said brushcutter chain attachment that uses chainsaw chain for added "spice". |
13/07/2023 18:19:05 |
Brush cutters are the conventional tool for this sort of job, for the specific job you describe I would think the walk behind type is what you would want, useless for a fine finish but loads of grunt and quite manouverable. |
Thread: Any dieticians out there - what are calories? |
13/07/2023 01:33:55 |
Fourth link on my google search, your google-fu is weak Robin-san. Edited By Cabinet Enforcer on 13/07/2023 01:34:20 Edited By Cabinet Enforcer on 13/07/2023 01:34:38 |
Thread: looking for new 3d cad |
22/03/2023 18:36:02 |
Currently my main use of CAD is generating paper patterns, after Draftsight went paid (which was fine for this purpose) I downloaded solid edge, the 2021 version I think. Recently I got around to trying it out, and while I can see the potential of the actual drawing package, it seems to have a particularly useless print driver. Apparently it is almost impossible to get it to print at exact 1:1 scale, you can ask it to easily enough but the print outs are not at 100% and also this "feature" is not consistent across scale either, with smaller features printing a touch larger. A Google search provided no useful info, beyond that it is indeed broken and things used to work properly before it went freeola.
Is the 2023 solid edge version better, or does anyone know of a workaround? Fusion 360 works ok for this but the limited documents and general online faffiness is a pain when you just want a quick paper pattern. |
Thread: Chester Super Lux / RF45 clone / Square Column mill spindle dimensions. |
09/02/2023 18:52:37 |
There are scattered reports of people replacing (usually) MT4 spindles with an iso/bt type.
The spindle was obtained from a german machine dealer, **LINK** I would like to get around to this myself someday, an iso holder would be so much better for quick changing, it seems maybe even iso40 is possible to fit. |
Thread: First print with new resin printer |
03/08/2022 21:28:33 |
Sort the FEP out first or you will just get failed prints or trash the FEP. Edited By Cabinet Enforcer on 03/08/2022 21:29:51 |
Thread: Bench lathe |
31/07/2022 19:06:15 |
Glad to hear it Graham. |
Thread: 4140 - general discussion |
31/07/2022 18:50:14 |
It seems that in the US, where most u-toobers hail from, 4140 is just the standard goto grade when something stronger is wanted, as you have noted EN19 or in a more modern nomenclature 708M40 is equivalent. Here in the UK I think the grade of choice when you need something a bit spicy is typically EN24, which is another cro-moly steel. |
Thread: Looking at a new resin 3D printer |
29/06/2022 13:13:08 |
I would recommend getting: a box of disposible nitrile gloves, 5l of isopropol alcohol, and a silicone mat for working on (pastry rolling mat for example), a small metal funnel for putting resin back in bottles, and remember the safety specs, you don't wan't a splash of resin in your eye. |
Thread: What is the best 3d printer for beginners |
16/06/2022 20:43:44 |
Posted by jack austin on 16/06/2022 13:28:20:
I have a growing interest in art and craft. I recently was introduced to 3D printing by a colleague and loved it. My question is which 3D printer should I get to jumpstart my newfound passion. Assuming you want the "squeeze plastic filament out through a hotend in layers" type of printer, then my advice is don't, they are all rubbish If you want cheap, then the ender 3 (or any of the inumerable copies of it) is the way to go. Not technically much better would be a printer from Prusa, but it is part of a cohesive ecosystem with something approaching a support system, and will be be more reliable. Quite a lot more money than an Ender, for many the extra hand-holding is worth every penny. Most cheap printers are basically a less good Prusa with no support. Then you have more commercial suppliers, like makerbot, more like an out of the box device which can be expected to "just work". A lot more expensive again. For the technically adept there are self build options which can have very good performance and reliability, but costing similar or a little more than a Prusa. An example would be the Voron 2.4. Edited By Cabinet Enforcer on 16/06/2022 20:44:04 |
15/06/2022 20:54:02 |
You mean Thomas Sanladerer's review? All the issues he raised are to do with the additional features that you do not need to use, just don't connect it to the internet and use USB to move files like any sensible person. He did actually say this in his review... |
Thread: Mill Quil play before lock down |
10/03/2022 15:17:52 |
Chris, it is hard to tell exactly what you are asking about, is your quill moving a lot when you clamp it, or are you just asking about how to keep track of Z axis movement? It is true that you need to take care not to wind down the fine feed while the quill clamp is engaged, the mental discipline comes easily once you have spoiled a couple of parts
The fine feed should have markings on the handle, same as the x and y, so in a pinch you can count those. Otherwise many of these mills have a cheap caliper type readout attached to the quill which while not as nice as a proper DRO is very useful, and despite mine having fittings which are not wholly convincing in their ridgidity, seems fairly repeatable. It looks like this one: Another option is to improve the awful depth stop, as detailed by Stefan Gotteswinter here: Stefan also later fitted a proper DRO to the quill, which can be seen in this more recent video dicussing other modifications: Edited By Cabinet Enforcer on 10/03/2022 15:18:49 |
Thread: Being nice to a vise |
09/10/2021 11:33:49 |
When cutting smaller pieces on the bandsaw I usually just use some packing pieces from the offcuts left on the saw.
However my next roundtuit will be spent on one of these, which is the most elegant solution I have seen for a bandsaw vice: Edited By Cabinet Enforcer on 09/10/2021 11:34:39 |
Thread: Vfd frequency Warco WM290 and WM280v |
30/08/2021 15:27:02 |
I use the 60 on the motor and the 140 on the spindle, if I need more speed for something specific, I can change pulleys back to the first set I bought. I would recommend machining a bush to clamp the taperlock bush onto, if that's your chosen route, mine clamps direct to the spindle which works but isn't very practical. The 280 has threaded holes in the bed which are sized for an 80 frame motor foot, so my motor is stood off on some threaded bar, which also provides some tension adjustment for the nutlink belt. You can see a photo in my album. |
30/08/2021 13:53:47 |
I have a 280 and have added a VFD, I used a compact 1.1KW 80 frame 4-pole TEC motor, no manufacturer guidance on max speed/frequency, I run it up to double speed IIRC. As for bottom end, just program in the motor to the VFD and set the min speed at zero, this lets you use the speed pot to adjust down to a full stop. I used taper-lock z-section v-belt pulleys and nut link belt. 60mm and 140mm pulleys give a range of about 40 upto about 1300, I used to have 71mm and 106mm on there which gave a 2000 top end but the bottom end was a bit lacking in torque and would only run down to about 75. |
Thread: Interfering with fits? |
17/08/2021 09:00:07 |
The domestic oven is a fine device for gently and controllably heating a part for shrink fitting purposes, and is usually conveniently located near the freezer
Nice belt sander, is it Jeremy Schmidt's design? |
Thread: Strimmer /BrushCutter … any recommendations ? |
01/07/2021 16:41:29 |
Struggling to reconcile your description of downmarket with the inclusion of Stihl? Which would be my default recommendation, they have a standard 2 year warranty and currently have an "offer" to extend to 3 years with an additional purchase item. My father has a bent shaft "grass trimmer" type which would happily chew through a small area of brambles, I have one of the commercial size machines which is frankly total overkill for my garden, both get plenty of use, the trimmer also abuse, both stihl and both have been very reliable and give off a reasonble air of being properly engineered. The only shortcoming I would describe about either is that I am not too keen of stihl heads, they seem a bit soft/fragile compared to say an oregon one, but they are pretty much a consumable and a standard M14 fitting. Edited By Cabinet Enforcer on 01/07/2021 16:41:52 |
Thread: Dangerous eBay listings can be removed by regulators |
10/05/2021 19:56:44 |
There is no legal authority within the UK legal system for any regulator to prevent the sale of second hand machinery, no-one has any power to prevent the sale of such items including on a marketplace such as ebay. There is the power to restrict the sale of new items that don't comply to standards, which is what the linked news story is about. You can all calm down now. |
