Tuna Can Blower
Making a steam raising blower from Tuna Cans
Stewart Hart22/01/2020 13:49:57
674 forum posts
357 photos
Why do they call steam raising blowers when they suck ?. laugh
On with the mater in hand, I've tired various blowers and I found the best to be the ones made from 24V ex-military radio cooling vans you could get these quite cheep at one time but with scarcity they are getting expensive. And as is my natural curiosity I've stripped a fair number of blowers down. Then when making myself a lunchtime Tuna sandwich I looked at the empty tin and had the idea of making a blower out of it, I took the empty tin with us when we next went to the supper market looking for a suitable tin to make the inner fan out of to me delight I found that the smaller tins of Tuna they sell would just fit the bill. 24V electric motors are easy to obtain of the net.
A few manufacturing shot
Material
Drilling the base of the fan the vanes were put in with a wood chisel whilst the inside was supported by a lump of wood.
The gap for the exhoust vent
The exhaust with its paper pattern
Soldering the exhaust
Machining the top and bottom plates these were made from 100mm dia ally blanks bought of the net.
Completed blower
And yes it does work I recon at that size it would be fine for smaller 5" gauge and 3 1/2, 2 1/2 locos
If you need a bigger blower you'd just have to find some bigger cans.
Stew
Edited By Stewart Hart on 22/01/2020 13:54:23
Brian Sweeting22/01/2020 14:28:30
453 forum posts
Great job, well done.
Brian H22/01/2020 14:37:55
2312 forum posts
112 photos
I'm impressed. The only problem I have is that I'm a vegetarian so no tuna cans!!
Bryan Cedar 122/01/2020 14:42:33
127 forum posts
4 photos
Hi Stew
I guess it works just as well with salmon tins, great job !
Bryan
Mick B122/01/2020 15:05:43
2444 forum posts
139 photos
Posted by Brian H on 22/01/2020 14:37:55:
Lidl sometimes sell Dolmades - Greek vine leaves stuffed with rice - in cans of similar size, shape and aspect ratio.
laugh
Edited By Mick B1 on 22/01/2020 15:07:02
Andrew Evans22/01/2020 16:23:12
366 forum posts
8 photos
Smells a bit fishy
mick H22/01/2020 16:50:33
795 forum posts
34 photos
Neat job. Well done.
Jeff Dayman22/01/2020 16:52:20
2356 forum posts
47 photos
Great design and build Stewart! Well done. I chuckled when I saw your soldering photo with the cotter pins / split pins used as sheetmetal clamps. I've used them the same way.
Usually it's too bad when something you made really sucks, but in this case it CAN be perfect! smiley
Ed Duffner22/01/2020 17:53:12
863 forum posts
104 photos
" If you need a bigger blower you'd just have to find some bigger cans. "
Watney's Party Seven? laugh
Ed.
Mike Poole22/01/2020 17:58:24
3676 forum posts
82 photos
Give the tuna to the cat and you have won a cansmiley
Bryan Cedar 122/01/2020 18:02:44
127 forum posts
4 photos
Looks like you are into making metal underpants at the same time, see photo number 4 !
Hacksaw22/01/2020 18:17:20
474 forum posts
202 photos
Granny knickers
Stewart Hart23/01/2020 08:05:14
674 forum posts
357 photos
Posted by Bryan Cedar 1 on 22/01/2020 18:02:44:
I had the same thought Bryan it does look like a pair of Y fronts smiley
Thanks for your interest gents and comments smileysadlaughlaugh
Lets see some veggie based blowers
Stew
Stewart Hart23/01/2020 08:11:47
674 forum posts
357 photos
Just to add a bit more interest to the thread, when drilling thin sheet with a normal drill you can run into trouble with a ragged hole or even worse.
I was shown this little trick when I was an apprentice, grind a drill up with a little teat and a slightly undercut flat, this way the teat acts as a pilot and the under cut means that only the edge of the drill cuts, it cuts out a washer out and you end up with a nice clean hole.
Stew
not done it yet23/01/2020 08:46:49
7517 forum posts
20 photos
Posted by Mike Poole on 22/01/2020 17:58:24:
Might be OK for a veggie, but def not for a vegan? They would only have vegetarian cats, at best (presumably).🙂
Paul Lousick23/01/2020 09:02:36
2276 forum posts
801 photos
Very neat Stuart, and a basic answer to "Why do they call steam raising blowers when they suck ? "
Called blowers because the air is pushed (blown) by the centrifugal action in this case, causing a reduction in air pressure on the inside of the rotor. The atmospheric pressure pushes air into this space to achieve equilibrium.
Paul.
Georgineer23/01/2020 10:27:28
652 forum posts
33 photos
That's a neat dodge, Stew.
Do you know - does anybody know - if it would work with a lip-and-spur drill as commonly used for wood, or are they too soft for metal?
George B
Windy23/01/2020 10:27:58
910 forum posts
197 photos
Recycling
Neil Wyatt23/01/2020 13:24:02
19226 forum posts
749 photos
86 articles
Posted by Paul Lousick on 23/01/2020 09:02:36:
Paul.
More likely because they take the place of a conventional stem blower which pushes steam up the chimbley to create a draught?
Howard Lewis23/01/2020 22:37:27
7227 forum posts
21 photos
Again, an Engineer showing his ancestry going back to the Greek root for Ingenious.
Definitely a Like!
