Can anyone help me choose a Chinese lathe
Neil Mccarthy 1 | 01/09/2019 00:02:05 |
43 forum posts | Hi all I am new to this and I am looking at getting a Chinese lathe as I only have a small area for one so I need a worktop one. Instead of buying secondhand I want to buy new so a Chinese one seems the best way to go with it being my worst time using one. I am after making small parts that I am finding hard to source in rebuild old air rifles to start and them move on to other projects with it. There are a few on eBay going from 400-600 I want at least a 30cm distance between centres I think but I am lost at which one to buy so could anyone give any suggestions of which one and where would be best to get one.
thank you all in advance |
Old School | 01/09/2019 07:10:01 |
426 forum posts 40 photos | Have a look at Arceuro,s Seig SC2 or SC3, i have used the my sons SC3 its a nice small lathe capable of doing real work. I think anything smaller you would struggle making parts for air rifles. If you can visit Arceuro they have the machines on display and they are very helpful, i live local and use them regularly. |
Former Member | 01/09/2019 07:22:04 |
1329 forum posts | [This posting has been removed] |
jimmy b | 01/09/2019 07:36:39 |
![]() 857 forum posts 45 photos | +1 for Sieg lathes.
If you could stretch to a SC4, they are extremely capable, otherwise I would highly recommend an SC3, I feel the SC2 could be too small for your 300mm centre distance.
Jim |
David Standing 1 | 01/09/2019 09:30:27 |
1297 forum posts 50 photos | Have you done a search? This question is asked about twice a week........ |
not done it yet | 01/09/2019 09:34:50 |
7517 forum posts 20 photos | Not much support for the ebay route above. It is the way to go for the vey cheapest option ....maybe. Importation will cost extra in customs taxes, VAT, etc. What warranty do you get from an imported lathe? Return to supplier could be an expensive operation! What is the spares situation with one of these machines. Likely less than optimal. Very often it is better to pay an apparent little extra to buy from a UK supplier. Especially so, if the purchaser is new to the hobby. Buying from ebay can be closely akin to buying second hand in your situation. Arc Euro have several machines on display (lathes and mills) and can advise, supply and provide a good warranty for your purchase. They are my ‘go to’ for most of my bits and pieces purchases ( my main machines are all old English iron). Chester Machine tools are clearly closer than ARC, but my preference would be the latter for several reasons (mesage me if you really need them). Warco are even further afield for you. |
Roger Woollett | 01/09/2019 09:47:35 |
148 forum posts 6 photos | Since distance between centres is important to you remember that the quoted distance is with the chuck removed and plain centres in head and tail stocks. The maximum size of workpiece you can realistically turn may be a lot less. As has been said Arc Euro have an excellent reputation. Their range is smaller than many of their competitors but seems to be carefully chosen. |
Mick B1 | 01/09/2019 10:39:37 |
2444 forum posts 139 photos | +1 for Arc Euro. I went to Leicester to pick mine up from them. They tested it for basic function in front of me to ensure it was OK and Ketan (I think t'was he) spent 10 or 15 minutes answering questions and talking to me about it - and it was only a C0 baby lathe for a titchy space in some temporary accommodation. |
Howard Lewis | 01/09/2019 12:36:00 |
7227 forum posts 21 photos | The Seig SC2-300 would fit your requirement for 300mm minimum between centres. If you have the space, and the cash, the SC3-400 with 400 mm centres may be the better bet, in the longer term. Your horizons are bound to expand, so the larger machine would save changing later on. I know of at least one Myford ML7 located across the corner of a small lobby, if that would help your space problem, but it does inhibit having longer material being passed through the mandrel. Like many others on here, I have had only excellent service from Arc Euro Trade. If possible, do go and visit,them just outside Leicester., where you can see the machines running, and get first hand advice. Howard |
David George 1 | 01/09/2019 12:44:13 |
![]() 2110 forum posts 565 photos | Hi Neil have a look a Chester machine store not to far to visit and select! David |
mechman48 | 01/09/2019 12:50:04 |
![]() 2947 forum posts 468 photos | Have a look at Warco site; I have a WM250V-F & a WM16 mill, can't complain, they do what I want them to do so quite satisfactory for my needs. George. |
Neil Wyatt | 01/09/2019 15:18:17 |
![]() 19226 forum posts 749 photos 86 articles | Do look at the UK suppliers, you do get support, easy access to spares and a warranty, plus some of the machines online that appear a real bargain may be ones that failed QC or are lower specs - mini-lathes have evolved a lot over 20 years. Neil |
old mart | 01/09/2019 16:37:03 |
4655 forum posts 304 photos | There is an excellent web site dedicated to the small Chinese lathes, showing how to improve them and much more: **LINK** |
Neil Mccarthy 1 | 01/09/2019 17:54:18 |
43 forum posts | Thank you for all of the advice I will take it all on board and have a look in the Chester one first and get to grips with what I need
thank you all again |
Neil Mccarthy 1 | 01/09/2019 22:51:04 |
43 forum posts | Hi has anyone had a myford lathe m1 I have seen one local at a good price |
Former Member | 02/09/2019 08:43:35 |
Howard Lewis | 02/09/2019 11:43:19 |
7227 forum posts 21 photos | the OP looks for a new Chinese, presumably mini, lathe. In comparison, a Myford ML1 will be a lot less versatile, and much older, certainly dating from the early 40s, or before. The dial graduations are not a straightforward 0.001"/ division. Very much a training lathe, in my book. And would probably need some fettling to bring into really good order Some wear is bound to be evident, if only in the plain bearing Headstock, so a good project for some one.. Although, in the right hands, good work can be produced on them, not a good first choice for a newbie! Given the choice, unless money was very tight, I know which would be selected! Howard |
Neil Mccarthy 1 | 02/09/2019 19:35:05 |
43 forum posts | Hi
looks like a choice between these 2 at the moment
has anyone got any advice on which one would be best for a beginner to get please |
peak4 | 02/09/2019 20:04:54 |
![]() 2207 forum posts 210 photos | Whilst you may be daunted at the prospect of cutting threads on a lathe at the moment, you may well feel the need as you get more proficient and experienced. Some mini lathes may only supply the relevant gears for either one or the other, some may come with what's needed for cutting both. I can't advise what to buy as I've never used any of the Chinese Mini-Lathes, My stable has a Myford, a Warco Myford lookalike/cone, and a Warco gearhead; all are imperial, but I do cut metric threads as well, due to having British, Japanese and Italian motorbikes.. Maybe add Warco and Seig to your list. It's perfectly possible to cut metric threads on an imperial lathe, and vice versa, depending on what gears are supplied/available. I guess the choice between metric and imperial lathes themselves, depends on what measuring system you prefer, though I'm sure others will chip in with their own views on that one. Bill Edited By peak4 on 02/09/2019 20:07:43 |
Former Member | 02/09/2019 20:24:11 |
