Here is a list of all the postings Neil Mccarthy 1 has made in our forums. Click on a thread name to jump to the thread.
Thread: ML10 Headstock mounts |
17/10/2021 16:35:01 |
Hi I have the part you need if it’s what @richard millington sold me I will on you now
thanks Neil |
Thread: Help needed with rifle stock duplicator |
04/09/2021 11:43:45 |
Thank you very much I will look into that |
03/09/2021 23:58:23 |
hi I have bought a incomplete air rifle stock duplicator it’s all done apart from the part that holds the wood and stock to be duplicated so they stay in the same place and turn identically as and when needed. The first pic should be what I have now the second pic show what I need or something similar has anyone any idea how I could do this please
thank you neil
Edited By Neil Mccarthy 1 on 04/09/2021 00:00:30 |
Thread: Help with lathe speed |
21/11/2020 00:13:56 |
I am in the middle of restoring my Drummond b lathe and I was wondering if you can have a speed controller on a 240volt single phase ac motor at all as I use to use a cj18a mini lathe and you could control the speed on that one
thank you in advance |
Thread: Drummond b lathe advice |
31/10/2020 21:32:32 |
Thank you I have sent you a message |
31/10/2020 20:34:18 |
I have bought a project Drummond b lathe and I was wondering if anyone has any pictures or advice to connect the motor to it. I know I will have to make a metal frame just after some guidance please if anyone can. I’m a long way off putting the motor on as I will be doing a full strip repaint and rebuild on this Thank you in advance https://ibb.co/VNjczZG |
Thread: Advice needed on filling a gap |
25/08/2020 14:44:23 |
Thank you I will take a look at it and it will be painted over at the end With cerakote or black paint for the finish
thanks |
25/08/2020 12:47:30 |
Hi all I am making an end silencer for an air rifle and I have joined the 2 pieces of metal together the top piece is steel and the bottom piece is aluminium. It has bolts securing it but I was wondering is there anything that’s like a mastic or filler that I could run a small bead of it along either side so that the screws in between can not be seen
Thread: Airbrushing advice needed |
11/08/2020 20:15:59 |
It just so happens in the bag I picked up is the badger 200 and also a badger 250 but the metal end is rusty on the badger 250 so will have to replace that. |
11/08/2020 17:40:32 |
I have just found a badger 200 with a cheaper one and some thinners and things for £35 so I have bought that but will also buy the 250 and I can see which is best for me
thank you alll for the advice it’s been great just need to get using it now |
11/08/2020 12:38:58 |
Hi all is this the right one as it’s a mind field looking through all different types
thank you
10/08/2020 17:07:02 |
Thank you very much everyone looks like I will be trying the badger 250 then
thank you very much for all of the input |
10/08/2020 14:27:32 |
Hi all I am looking for a airbrush is there a entry model or a decent one that I could get I have a compressor already but need the rest. If anyone could advise me that would be great. I will be using it to spray models, air rifles and probably everything in the house once I get going.
thank you in advice Neil |
Thread: Help with what metal lathe cutter needed |
25/02/2020 08:49:11 |
Thank you everyone |
25/02/2020 02:09:05 |
Thank you I will buy that and read up how to make them and it will teach me more things that I need to know as well
thank you for your advice |
25/02/2020 01:35:40 |
Hi thank you is it easy to make one I have a grinder I will have to look on YouTube I’m sure I will find out on there thank you for your advice if I could make a 5mm one would save me a lot of time
thank you |
25/02/2020 01:17:33 |
Hi all I am looking at a tool that can make a 5mm grove in different types of metal I am making some safeties for my air rifles I have attached a picture of the part I am struggling with is the gap between the 2 bigger bits which is 5mm wide the end bit of fine but I can’t get the other bit with my tools it needs to be a 12mm tool that’s what my lathe takes and something to do a 5mm gap
thank you
Thread: Mini lathe amadeal cj18a help needed |
15/01/2020 20:54:18 |
As you say I have always had good correspondence from them and I received a reply today they are sending me the part out free so a good service from these yet again I would buy from them again. Saying that I keep buying other parts for the lathe cutters threaders etc so without a doubt a good company to deal with
thank you everyone |
Thread: Help with finding or making router duplicator |
14/01/2020 14:30:09 |
Hi thank you that’s what I am after the manual type if there is anyone near Wirral Merseyside who wants to make one and I will pay you for it let me know otherwise I will try to design one using the link you have shown me
thank you very much |
14/01/2020 13:57:34 |
Hi I’m a beginner but all I was doing was reducing the size of a piece of delrin rod by doing 1-2mm off at a time and all of a sudden it stopped I am presuming it was the same thing happening again I will check it later on again. The lathe has only been used a few times for light work that is why I can not understand why it has done this. I got 2 off the plastic bits when I ordered one last time so if it is that again I will replace and see if it does it again. I have emailed amadeal when it first happened and got no reply and I have emailed again last night so see if they reply when I was looking to buy it they where very responsive with messages I just hope they get back to me now
thank you for your reply |
