Rockingdodge | 07/07/2019 12:21:01 |
![]() 396 forum posts 111 photos | Hi, these were amongst some items bought and I'm not sure of their purpose. Gentleman was an engineer and clock maker. Item 1: Left hans one has BA sizes on it. Item 2: Made in USA, Industro Item 3: I don't know if this is complete, about 3" is size, one part is hinged but certainly not a knurling tool for the lathe, but could be wrong Thanks Roger |
not done it yet | 07/07/2019 13:52:31 |
7517 forum posts 20 photos | If you had said a mechanics tool box, I might have suggested that the two on the right of the first pic were part of a tube flaring kit (as in brake pipes in common sizes). |
Clive Hartland | 07/07/2019 13:58:44 |
![]() 2929 forum posts 41 photos | The first 3 items are for cutting short screws and then dressing the ends square and clean. |
Rockingdodge | 07/07/2019 14:16:15 |
![]() 396 forum posts 111 photos | That did cross my mind and might be right for the 2 on the left but haven't seen pipework in as large sizes as that though |
Rockingdodge | 07/07/2019 14:18:56 |
![]() 396 forum posts 111 photos | Posted by Clive Hartland on 07/07/2019 13:58:44:
The first 3 items are for cutting short screws and then dressing the ends square and clean. Wouldn't they have have needed to have threads in them for that purpose though? |
Swarf, Mostly! | 07/07/2019 14:30:44 |
753 forum posts 80 photos | In a ribbon microphone a metallic ribbon is suspended between the poles of a permanent magnet. To give the ribbon compliance in the appropriate axis, it is usually corrugated. The gizmo with the two gear wheels hinged together could be used to form suitable corrugations. I believe that there was also a ribbon loudspeaker offered on the hi-fi market at one time. Best regards, Swarf, Mostly! |
peak4 | 07/07/2019 14:41:43 |
![]() 2207 forum posts 210 photos | I've no sense of scale for No.2, but it looks like a punching or embossing tool, for a series of dents or holes along the middle of a strip of something. Bill |
Rockingdodge | 07/07/2019 14:52:46 |
![]() 396 forum posts 111 photos | Sorry, never thought Regards Roger |
Michael Gilligan | 07/07/2019 15:01:45 |
![]() 23121 forum posts 1360 photos | Indestro : **LINK** https://www.madeinchicagomuseum.com/single-post/indestro-duro-metal MichaelG. |
Rockingdodge | 07/07/2019 15:34:29 |
![]() 396 forum posts 111 photos | Haha Michael beat me to it Thanks everyone, 1 down, i possible, 1 to go. Roger |
Hopper | 08/07/2019 08:23:28 |
![]() 7881 forum posts 397 photos | First pic looks like typical apprentice projects: stud clamps for holding threaded or non-threaded studs while end is filed or by the look of the hacksaw marks, screwdriver slot is cut in the end of the stud. No thread is needed to hold threaded studs in the split type clamps on the right. Clamp is held in the vice while stud is filed or cut. Can be used to hold studs or punches while the end is shaped etc for special jobs. Edited By Hopper on 08/07/2019 08:25:02 |
Russell Eberhardt | 08/07/2019 09:59:53 |
![]() 2785 forum posts 87 photos | The second two items in pic 1 are clockmakers' split stakes. Commercial ones are usually made of brass. The first one is probably for slotting screw heads. https://www.amazon.com/Clockmaker-Split-Stake-Watch-Wheel/dp/B000RB5KUC Russell Edited By Russell Eberhardt on 08/07/2019 10:03:55 |
KWIL | 08/07/2019 11:59:58 |
3681 forum posts 70 photos | I have a ribbon microphone but the corrugations are not as fine as Swarf, Mostly suggests. |
Watford | 08/07/2019 14:34:23 |
![]() 142 forum posts 11 photos | Are the two on the right possibly for drawing down wires? M |
Russell Eberhardt | 08/07/2019 15:51:29 |
![]() 2785 forum posts 87 photos | Posted by Watford on 08/07/2019 14:34:23:
Are the two on the right possibly for drawing down wires? M They are used for supporting clock parts while working on them. For example while staking new trundles into a lantern pinion. Russell |
jason udall | 09/07/2019 08:05:45 |
2032 forum posts 41 photos | Item three.... knurling tool of some scale
Neil Wyatt | 09/07/2019 16:43:35 |
![]() 19226 forum posts 749 photos 86 articles | Not necessarily specific to clock making, they are just a way of holding thin rods in a vice without damaging them. Neil |
Russell Eberhardt | 09/07/2019 20:50:07 |
![]() 2785 forum posts 87 photos | Posted by Neil Wyatt on 09/07/2019 16:43:35:
Not necessarily specific to clock making, they are just a way of holding thin rods in a vice without damaging them. Neil True, I've found lots of other uses for mine when working on small parts. Russell |
