Rob Manley | 22/12/2018 18:15:33 |
![]() 71 forum posts 14 photos | I'm asking the ME collective for a recommendation as my searches haven't found anything I would trust. A casualty of my workshop move was my donated wall mounted storage unit, that contained taps, dies, reamers, screws etc, weighed a ton when fully loaded and was just about big enough. The plastic drawers have started to crack with age and being overloaded. So, I am after a suitable replacement. I would like to have around 28 drawers of 4"x3"x6" and be wall mounted. My previous one was a sheet metal unit but I'm open to suggestions. Thanks all, Rob. |
Dalboy | 22/12/2018 18:50:45 |
![]() 1009 forum posts 305 photos | Have you considered making one from wood that way you can make it whatever size you want. It would not be difficult to construct. |
Robert Atkinson 2 | 22/12/2018 19:24:07 |
![]() 1891 forum posts 37 photos | I'm a big fan of Really Useful Boxes. They are available in a wide range of sizes. They stack neatly so shelves with 2 or 3 stacked on each and the occasional full depth vertical "divider" to the floor or extra shelf support on the bottom shelf to stop sagging if you have heavy contents. http://www.reallyusefulproducts.co.uk/uk/html/onlineshop/fullrange_rub.php They are tough (you can stand on small one or corner of a large one) and while not sealled (a good thing in my mind) they keep dust and dirt out. Not completely clear but easy to identify most contents. Robert G8RPI. |
Ian Parkin | 22/12/2018 19:32:24 |
![]() 1174 forum posts 303 photos | Bisley *. multidrawer filing cabinets 15 drawer ones I use I have about 20 of these scattered around you can get them for about £20 upwards depending on condition Ian * other brands available Edited By Ian Parkin on 22/12/2018 19:51:50 |
JC54 | 22/12/2018 21:25:26 |
![]() 154 forum posts 14 photos | I often see Bisley at autojumbles I bought a couple for £10.00 each a couple of years ago. Well made and take some "hammer". |
Chris Evans 6 | 22/12/2018 21:35:57 |
![]() 2156 forum posts | Plus 1 for Bisley |
Ady1 | 22/12/2018 22:48:44 |
![]() 6137 forum posts 893 photos | For strength and compactness, Bisley You can also pull a drawer right out, giving you a metal tray for inspecting bits or moving to another Bisley unit Comes in 5 10 15 up to 30 drawers |
Pete Rimmer | 22/12/2018 23:25:20 |
1486 forum posts 105 photos | I also use the Bisley drawer units. For taps, dies and fasteners etc I use home made drawer dividers. I had some strips of 18 or 20g steel cut about 45mm wide, then cut them into sections some equal to the drawer inside length and some to the width. Then I just decide how many dividers I want in a particular drawer and use a mini-grinder with a 1mm disc to cut notches half way across each divider at the appropriate centres. You just slot the short ones into the long ones to make a grid in the drawer. |
thaiguzzi | 23/12/2018 05:22:12 |
![]() 704 forum posts 131 photos | Posted by Chris Evans 6 on 22/12/2018 21:35:57:
Plus 1 for Bisley Make that +2 for Bisley. |
Mike Poole | 23/12/2018 09:12:15 |
![]() 3676 forum posts 82 photos | **LINK**Have a look at these units they seem close to your spec. Mike |
Ady1 | 23/12/2018 11:18:17 |
![]() 6137 forum posts 893 photos | A look at a single drawer Spanners 20 to 32mm go longways under 20mm widthways |
Pete Rimmer | 23/12/2018 11:52:54 |
1486 forum posts 105 photos | Here are the dividers I make for Bisley drawers, as described above. Simple to make and very effective: Edited By Pete Rimmer on 23/12/2018 11:53:25 |
Bazyle | 23/12/2018 12:35:07 |
![]() 6956 forum posts 229 photos | Unless you have a heated and dehumidified workshop metal boxes spell rust both for them and the tools. I would suggest adjustable shelves to allow adaptation and various plastic food boxes. |
Vic | 23/12/2018 12:42:09 |
3453 forum posts 23 photos | I used Bisley drawers at one time but due to the construction it’s inevitable that the bottom of the drawers will go rusty unless you have a completely dry workshop. I’ve had a couple of garage workshops so the bisley drawers eventually went to the dump when some of the tools in them displayed signs of rust. I instead invested in a variety of sizes of clip lock food containers. These keep tools dry in even the most damp conditions. I did put anti rust paper in some just in case but this has proved not to be necessary. These containers are stored in a couple of multi shelf steel cabinets I bought from Ikea. Small tools can represent a large investment so nobody wants them to go rusty and can you be sure that they will always be kept in a damp free environment? |
Vic | 23/12/2018 12:57:01 |
3453 forum posts 23 photos | These are the cabinets I bought from Ikea. They come with lots of shelves which I lined with thin MDF to prevent scratching. |
mechman48 | 23/12/2018 13:06:36 |
![]() 2947 forum posts 468 photos | +3 for Bisley drawers; I bought a 15 drawer one from an auction house for £20... |
SillyOldDuffer | 23/12/2018 13:10:35 |
10668 forum posts 2415 photos | Posted by Bazyle on 23/12/2018 12:35:07:
... Used to be dead common second-hand round here - and cheap. Not so nowadays. I think a lot of offices dumped their Bisleys over a 30 year period as computers took over and that source has dried up now. Might be a regional thing, but after a long search I had to buy a new one! Dave |
Pete Rimmer | 23/12/2018 13:41:00 |
1486 forum posts 105 photos | Posted by Bazyle on 23/12/2018 12:35:07:
Unless you have a heated and dehumidified workshop metal boxes spell rust both for them and the tools. I would suggest adjustable shelves to allow adaptation and various plastic food boxes. There is a third option - good insulation. My workshop only has an infra-red heater that is only on when Im in there. No dehumidifier either and I don't suffer rust issues. It is however an insulated building which keeps a stable temperature, or at least a slow-changing one. |
Vic | 23/12/2018 14:48:02 |
3453 forum posts 23 photos | Bisley shut their factory in Surrey about five or six years ago. I think they moved to wales? |
clogs | 23/12/2018 15:30:35 |
630 forum posts 12 photos | mechman48, hope those oil heaters are the oil in rad sort as burning parafin etc actually make moisture....... |
