Sealer for bare steel - matt finish
Former Member | 07/12/2018 20:02:34 |
1329 forum posts | [This posting has been removed] |
JasonB | 07/12/2018 20:05:57 |
![]() 25215 forum posts 3105 photos 1 articles | Metal Guard, it is a much thinner coat than lacquer so you can't tell it's there |
Former Member | 07/12/2018 20:18:04 |
mike T | 07/12/2018 20:28:27 |
221 forum posts 1 photos | Lanolin is a very good long term preservative for bright steel and other metals. And you don't have to go to Arc to get it. Mike |
Neil Wyatt | 07/12/2018 22:35:28 |
![]() 19226 forum posts 749 photos 86 articles | Posted by mike T on 07/12/2018 20:28:27:
Lanolin is a very good long term preservative for bright steel and other metals. And you don't have to go to Arc to get it. Mike Indeed, just rub your Mamod on a passing sheep... |
mike T | 07/12/2018 22:50:49 |
221 forum posts 1 photos | Posted by Neil Wyatt on 07/12/2018 22:35:28:
Lanolin is a very good long term preservative for bright steel and other metals. And you don't have to go to Arc to get it. Mike Indeed, just rub your Mamod on a passing sheep... Quite so, proves the point. Have you ever seen a rusty sheep
Phil P | 07/12/2018 22:55:50 |
851 forum posts 206 photos | I just had to google it .............. http://kilchoan.blogspot.com/2015/07/rusty-sheep.html Phil |
JasonB | 08/12/2018 07:07:14 |
![]() 25215 forum posts 3105 photos 1 articles | Posted by mike T on 07/12/2018 22:50:49:
No, but have you seen all the fluff that gets stuck to them! Does the lanolin stay oily/waxy? as that may not be ideal inside where the item may collect dust, the metal guard dries so you don't get that issue. |
Andy_C | 08/12/2018 07:38:08 |
66 forum posts 13 photos | Renaissance Wax was recommended in ME some time ago for conserving clocks once polished. Worked for me - no links just satisfied customer. Also apparently used in antique metal conservancy by stately homes. |
John Paton 1 | 08/12/2018 15:27:20 |
![]() 327 forum posts 20 photos | Might be worth trying Owatrol or Ambersil. Ambersil is a great rust preventer but leaves a rather dull and slightly tacky finish. Owatrol leaves a very thin film but dries to a reasonably hard finish and can be overpainted. |
AJW | 08/12/2018 16:19:59 |
![]() 388 forum posts 137 photos | Dinitrol used to produce a wipe on type of lacquer. Alan Edited By AJW on 08/12/2018 16:20:20 |
Phil P | 08/12/2018 16:37:01 |
851 forum posts 206 photos | I am planning on using this product on the vulnerable areas of my Morris Traveller. https://www.bilthamber.com/corrosion-protection-and-rust-treatments/dynax-s50 Phil |
Andrew Evans | 08/12/2018 21:09:16 |
366 forum posts 8 photos | Dynax S50 is good stuff but it leaves a visible waxy coating. |
Mark Rand | 08/12/2018 22:28:32 |
1505 forum posts 56 photos | I would vastly prefer to see them in their original colours. If bare metal is preferred and the surface finish has been cleaned up to the point that it's acceptable, then get the parts nickel plated (not chrome). That will look good and will last longer than a varnish. |
pgk pgk | 08/12/2018 22:52:32 |
2661 forum posts 294 photos | My pet sheep enjoy being rubbed.. so available for hire.. just watch out for the burs and brambles they like to collect....
pgk |
Phil P | 08/12/2018 23:01:42 |
851 forum posts 206 photos | I was wondering about the merits of nickel plating the bright metal work on my model corliss engine, has anyone tried the DIY kits that are available with any success, and consistency of results ? Phil |
Chris Trice | 09/12/2018 02:12:52 |
![]() 1376 forum posts 10 photos | Not tried any home kits but have used this company a lot. They can plate 3D prints in copper (which strengthens them considerably) and then nickel giving a perfect chrome appearance as well as the more usual metal items. http://morganicmetalsolutions.com
Ian S C | 09/12/2018 10:36:59 |
![]() 7468 forum posts 230 photos | If the model is going to be display only, hair spray works ok, bit smelly. Ian S C |
