jimmy b | 19/04/2018 07:17:18 |
![]() 857 forum posts 45 photos | I need to case harden a few small items, (6mm dia x 30mm). They only need hardening on one end. Normally I'd just use silversteel, but I just used mild steel, it's all I had at the time. So I've bought some of this stuff off Ebay
The instructions say to heat to 800-900 deg C and put in the powder, leave for half hour and quench. I was expecting to have to reheat and quench.
Has any one used this powder?
Thank you
Jim |
JasonB | 19/04/2018 07:24:28 |
![]() 25215 forum posts 3105 photos 1 articles | I have the same stuff. Usually heat to bright red and dunk in the powder and stirr it about, lift out and heat back up then quench. You can heat & dunk more than once if you want a deeper case as each time adds more carbon. I don't leave it for that long, no point on a small item as it will have cooled after a min or so. and certainly would not need quenching. Best to put it in a metal tin so you don't melt the pot if the part touches it. Edited By JasonB on 19/04/2018 07:26:47 |
Martin Johnson 1 | 19/04/2018 08:20:17 |
320 forum posts 1 photos | I had some cheap(ish) nondescript case hardening powder from one of the well known ME suppliers. I could not get any case hardening with it. I even tried making a box out of large screwed pipe fittings, filling with item + powder, heat ad nauseam, then dunk - but still no joy. Purchased proper Kasenit and had no further problems. This needs heat to bright red, dip in and it forms a sort of crust over the item. Heat a bit more, then dunk. Repeat as required. You get what you pay for I suppose - Caveat emptor. Martin |
jimmy b | 19/04/2018 08:25:28 |
![]() 857 forum posts 45 photos | Thank you! Pretty much what I was I thinking Jason. I'll have a go later and report my findings!
Thank you too Martin, hopefully it'll work out! Its one of those annoying little jobs that, if I'd made it from the proper stuff, it'd be done now!
Jim |
Douglas Johnston | 19/04/2018 09:43:02 |
![]() 814 forum posts 36 photos | Is proper Kasenit still available, I thought the health and safety people had that banned a long time ago. |
Russell Eberhardt | 19/04/2018 10:04:01 |
![]() 2785 forum posts 87 photos | Posted by Douglas Johnston on 19/04/2018 09:43:02:
Is proper Kasenit still available, I thought the health and safety people had that banned a long time ago. I believe it was banned some time ago by H&S people who were ignorant of chemistry. It contained Sodium Ferrocyanide which is not poisonous and is available in food grade! They confused it with the very poisonous HCN, NaCN, etc. It should still be available as food additive E535. Russell Edited By Russell Eberhardt on 19/04/2018 10:07:19 |
colin hawes | 19/04/2018 10:14:27 |
570 forum posts 18 photos | My understanding is that the second heat is to refine the grain structure of the component. The part would be allowed to cool after the carburising and then hardened in the usual way .Colin |
David Taylor | 19/04/2018 10:45:19 |
![]() 144 forum posts 39 photos | Posted by Russell Eberhardt on 19/04/2018 10:04:01:
It should still be available as food additive E535. Are you saying food additive E535 is usable as Kasenit? I've never figured out where to get Kasenit. |
Roderick Jenkins | 19/04/2018 11:01:10 |
![]() 2376 forum posts 800 photos | The great thing about Kasenit was that you could heat your mild steel item up, roll it in the Kasenit which would stick and melt around the item heat to red and quench. The Beta product doesn't stick like Kasenit and my guess is that is because there is no ferrocyanide in the mix. Possibly mixing E535 with Beta might bring us back to the convenience of Kasenit. Rod |
Neil Wyatt | 19/04/2018 11:13:30 |
![]() 19226 forum posts 749 photos 86 articles | Add sugar or molasses. Careful with ferrocyanate in larger quantities, it can release cyanide if exposed to acids. Not enough to be an issue in food quantities. |
Russell Eberhardt | 19/04/2018 11:18:39 |
![]() 2785 forum posts 87 photos | Posted by David Taylor on 19/04/2018 10:45:19:
Are you saying food additive E535 is usable as Kasenit? I've never figured out where to get Kasenit. It should work on its own but I suspect the original Kasenit recipe also included some form of free carbon such as carbon black or ground charcoal as I seem to remember it being a grey colour. Russell |
Russell Eberhardt | 19/04/2018 11:22:04 |
![]() 2785 forum posts 87 photos | Posted by Neil Wyatt on 19/04/2018 11:13:30:
Careful with ferrocyanate in larger quantities, it can release cyanide if exposed to acids. Not enough to be an issue in food quantities. Hmm - doesn't the stomach contain hydrochloric acid?? Russell |
JasonB | 19/04/2018 13:12:23 |
![]() 25215 forum posts 3105 photos 1 articles | Posted by Neil Wyatt on 19/04/2018 11:13:30:
Add sugar or molasses. Careful with ferrocyanate in larger quantities, it can release cyanide if exposed to acids. Not enough to be an issue in food quantities. The beta contents are Molasses, Charcoal and Sodium Carbonate Solution so why add more molasses? |
Fowlers Fury | 19/04/2018 14:05:10 |
![]() 446 forum posts 88 photos | Wasn't LBSC's advice for case hardening something like this? nuff said?
Martin Johnson 1 | 19/04/2018 16:20:08 |
320 forum posts 1 photos | Just been to look out the good pot of case hardening compound. It is Blackgates own brew, and the tin says it contains Ferrocyanide. Can't remember just when I bought it, but less than 10 years ago for sure, probably more like 5 years. Apologies for claiming it was Kasenit, but it does handle just like Kasenit. Martin |
jimmy b | 19/04/2018 16:33:36 |
![]() 857 forum posts 45 photos | It's worked! Bit mixed results, but definitely case hardened! The powder sticks quite well. I heated the parts, shoved them in the powder for a bit and then reheated before quenching. The powder stuck better than expected! I'll be investing in a bigger tub for sure! Thanks for the input. Jim |
mechman48 | 19/04/2018 17:50:20 |
![]() 2947 forum posts 468 photos |
Brian G | 19/04/2018 18:00:00 |
912 forum posts 40 photos | Posted by mechman48 on 19/04/2018 17:50:20:
Wow. Do people really pay nineteen quid for an empty tin? Brian |
Robin | 19/04/2018 22:35:17 |
![]() 678 forum posts | It would seem I have kept mine too long, the can is strating to dissolve
David Standing 1 | 19/04/2018 22:49:43 |
1297 forum posts 50 photos | Posted by Robin on 19/04/2018 22:35:17:
Can't be much cop, if it can't protect its own tin |
