Member postings for Robin
Here is a list of all the postings Robin has made in our forums. Click on a thread name to jump to the thread.
Thread: U Tube
21/09/2023 10:05:43
Posted by Benedict White on 20/09/2023 15:52:13:
I'm not sure of the value of CNC unless you are making either a production run or making something complicated. Joe Pie shows what you can do both with and without and knows how to use both.
I too enjoy Joe Pie, it all works when he does it. Sadly I need CNC to get the same results. I don't have enough years left to get the practice in and do it his way.
Those Americans all seem to be using pre-hardened steel stock, usually from McMaster Carr. It can only be cut with carbide insert tooling giving an instant mirrorlike finish.
humph dont know
Robin
20/09/2023 15:41:41
Abomb can be fun because he was given that enormous gantry mill with full CNC and just about manages to drill a few holes so long as the factory send someone to program it for him nerd
Which Vevor tool would you choose given the opportunity? That mag drill sure looks like fun.
best
Robin
Thread: Warco Major milling machine
18/09/2023 10:03:27
Nothing wrong with the mighty RF30.
The only complaint against it is that the round column is not keyed to the head so you lose position when you wind it up and down. That is really easy to work around.
The best modification for it is a flashing neon sign fixed to the start button. This should read, "Have you tightened the bolts? smiley
best
Robin
Thread: Runout on a collet chuck?
15/09/2023 10:55:16
Posted by Pete on 15/09/2023 03:56:15:
You asked if ER 40 were better than the 32 Robin. Not really, for qualified collets that have some kind of guarantee you can depend on, there pretty...
I have bought junk on occasion but hope springs eternal so it is easy to get caught out. Probably best not to risk buying a new set of ER40 collets then, unless I am feeling flush and can afford high-accuracy sad
best
Robin
14/09/2023 11:17:26
I just bought a Chinese MT5 ER40 collet holder for a specific job on my lathe and after much cleaning of the spindle taper it is the most accurate collet I have ever had the good fortune to meet.
The shank through hole looks like a rough casting and is as hard as the top of Gods' head but I cannot detect any run out at all on the collet.
So is this sample of one typical?
Are ER40s actually better than ER32s?
Do these things get less accurate as they diminish in size? As I descend into the "hobby" market and start counting the pennies?
Have fun,
Robin
Thread: Advice on choosing a tool cutter/grinder
14/09/2023 10:51:30
Have you looked at RDG tools recently? I am feeling tempted by their universal cutter grinder because of the price tag and the big pile of accessories it comes with.
This is not a recommendation, I am no expert on this stuff, I am actually just fishing for clues myself smiley
Thread: WHERE ARE THE SHAPER USERS ?
12/09/2023 11:03:20
Posted by Dave Wootton on 12/09/2023 07:44:40:
Ok Tony I'll tidy up a bit and take some pictures today!!
If you tidy up, how will we know if you are using it? smiley
Thread: Beginners First Mill
22/08/2023 22:00:02
Posted by Vic on 22/08/2023 12:22:14:
I used an Alexander Master Toolmaker at work which is similar? Lovely little mill and very versatile. I’ve never been that impressed with the Bridgeport apart from the fact some have long tables which can be very useful. I’ve seen a number of old European Universal Mills that I’d far sooner have than a Bridgeport if I had the space and money.
'scuse my ignorance, 'Universa'l meaning you can rotate the table in the Z axis?
So much to learn, so little time left smiley
Robin
22/08/2023 11:02:09
Has anyone ever played with a Deckel?
Might you trade some of that American Bridgeport solidity for a bit of Continental, double-jointed flexibility?
When Gotteswinter starts twisting his Deckel horizontal table through all its' degrees of freedom I go a bit slack-jawed and drooly nerd
Thread: Safety
18/08/2023 16:59:22
Posted by Chris Pearson 1 on 17/08/2023 22:39:40:
How many of you have an emergency stop switch and brake on your lathe?
(Mine stops in 2 sec, which is 33 revolutions at 2,000 rpm.)
When you say "Emergency stop switch and brake" do you mean dumping the kinetic energy to a resistor bank or physically applying a brake?
I have a brake pedal that stops it dead from 800 rpm, haven't tried faster just in case it explodes.
I want to fit a VFD to fill in the gaps between the gear selections, but what about the brake? Can you get an instant off, stop doing anything, from a VFD? Don't want it to work against the brake rather than just letting it happenface 22
Robin
Thread: Just how good is AI?
09/08/2023 11:56:30
I don't think AI will be a problem.
If machines could take over the world it would probably be by ruining our economies with fake alarm stories on social media, promoting a cashless cryptocurrency base and tricking stupid Chinese lab workers in Wuhan to cook up plague pathogens.
A big alarm bell to listen out for would be when rich people started trying to leave the planet face 22
Robin
Thread: Ball turners.
08/08/2023 11:36:34
Posted by vic newey on 07/08/2023 20:46:25:
My 1895 vintage lathe has a powered ball turner, it can be set to turn ovals, spheres and even a ball in the middle of a length of metal bar. Here is a 90 second video powered ball turner
Exquisite smiley
There is a Holtzapffel lathe, with lots of the kit, up on that auction site. Made for a Victorian gentleman hobbyist wood turner, but who would want it now you can't get the ivory?
Robin
Thread: Mystery Gun Part?
06/08/2023 10:05:00
I have one very like that.
I keep it attached to a Baker rifle lock that was specially designed not to need one.
I have a strange sense of humor face 22
Thread: Travelling Microscope Query
26/07/2023 12:00:20
I wonder if it was to align the head on an RF30? smileysmileysmiley
Thread: Tony Seba’s Prediction
26/07/2023 11:34:20
Posted by Mark Rand on 26/07/2023 11:04:45:
Read, mark, learn and inwardly digest:- **LINK**
Is it really so hard to understand? frown
I will see your Wikipedia and raise you Jesus Christ, "You're far too keen on how and where but not so hot on why."
26/07/2023 10:47:06
Posted by Nigel Graham 2 on 25/07/2023 09:50:44:
That is the heading line. What do " world-renowned", "thought leader", " educator" and " angel investor" really mean?
This may sound like an ad hominem logical fallacy to some, but I have come to realise that "Climate Change" has nothing to do with the old-fashioned, experiment-based, fallacy-avoiding science, there is a science nouveau based on consensus, how many followers you have on social media and shouting a lot when you are asked where you got your numbers from'.
Everyone is hoping for a powerful El Nino this year to push the unco-operative satellite temperature record up above the pesky 2016 el Nino high. Nobody is to ask awkward questions like, "How did the heat get from the troposphere to the sub-surface Pacific?" We will just be jolly thankful when it does.
24/07/2023 01:04:20
I can't decide whether to be killed by global warming, Covid, Putin, AI, Super Volcano or stagnation of the Gulf stream.
So many to choose from my head is spinning.
I would buy a ticket to Mars from that nice Mr Musk if only dogs were allowed sad
Thread: Gluten Intolerance
21/07/2023 10:24:24
Posted by KWIL on 21/07/2023 10:01:32:
Cadbury chocalate has become like all USA choc ugh!
Cadbury's is okay, I am a button addict. Still have not forgiven Nestle for changing the taste of the Rolo though sad
I seem to remember Cadbury's shifted production to Poland sometime before Brexit. Wonder how that's going for them wink
Robin
Thread: Anyone any experience of a Chester Model T Super Mill
19/07/2023 23:10:05
Posted by Daedalus on 19/07/2023 17:51:08:
I assume with all the work you have done you got the HV in a used condition.
All new, I didn't want to get stuck with a lemon.
I understand that the rotating top slide is what makes it a "universal mill"? It certainly makes the slide very easy to remove smiley
It had heavy iron handles on the X and Y screws, sprung to disengage when not in use. I replaced them with lightweight 3D prints and lost the springs.
I have made 2 mistakes so far... The Y-axis motor gets in the way of one of the slide locks. I used overly powerful springs declattering the splines, makes the quill a bit stiff.
Robin
19/07/2023 16:51:43
Posted by Daedalus on 19/07/2023 15:46:54:
Just as a matter of interest how are you finding your HV, at least it is in stock?
I am having enormous fun with it. I removed all the wiring, replaced all the lead screws, added the missing Z-axis DRO, fixed a few niggly bits, and went a bit wild fixing the Z-axis handle.
I still have to finish the main circuit board, fit the central lubrication pump, and program in the pendant. I will then run out of fun stuff for a while and start on the more mundane bits.
Interesting to see the model T, wondering if the HV could be based on it. I can see them replacing the gearbox with stepped pulleys and a VFD. Unfortunately, instead of two VFD's they went for one VFD, 5 contactors, and a mile of wire. It did not last. When it arrived it was already pulling the earth leakage circuit breakers and pretty soon after it gave up altogether. I replaced one duff VFD in the cabinet with 2 new VFD's up on the ram and it works beautifully. The only thing left in the cabinet was the suds pump contactor. The only thing left in the big fancy switch box was the suds pump switch.
I ramble blush
