Joe McKean | 07/04/2018 20:23:55 |
60 forum posts 3 photos |
I am in the process of restoring a older motorcycle and need to machine new pistons to fit into the fork sliders, unfortunately I am having trouble measuring the internal bore of these as I only have telescopic bore gauges and I'm not getting consistent measurements, as the pistons need to be 3 thou under the size of the bore I need help in getting the correct measurement so is there anyone within a hours drive of Corby in Northamptonshire that could accurately measure these for me. The internal diameter of the sliders is approximately 31 - 32mm. any help with this would be very much appreciated Joe
Alan Waddington 2 | 07/04/2018 21:06:37 |
537 forum posts 88 photos | Just a thought Joe, could you not turn up a plug out of Ali or similar that is a snug fit in the slider and then mic that up. |
Mick B1 | 07/04/2018 21:20:32 |
2444 forum posts 139 photos | If you're getting inconsistent measurements, do you think the bores are actually round and parallel, or are they worn unevenly? Is it practical to ream to a known diameter and make a piston to suit that? |
John Reese | 08/04/2018 00:17:20 |
![]() 1071 forum posts | As Mick B1 said the bores may no longer be round or straight due to wear. Try to borrow a bore gauge with a dial indicator.. Use it to explore the bore to see what condition it is. It may no longer be round or cylindrical. It may be necessary to hone them to make them cylindrical. |
thaiguzzi | 08/04/2018 09:44:31 |
![]() 704 forum posts 131 photos | Posted by John Reese on 08/04/2018 00:17:20:
As Mick B1 said the bores may no longer be round or straight due to wear. Try to borrow a bore gauge with a dial indicator.. Use it to explore the bore to see what condition it is. It may no longer be round or cylindrical. It may be necessary to hone them to make them cylindrical. What he said. Machine DRO on this page sell bore guages at very reasonable prices. |
Hopper | 08/04/2018 10:10:04 |
![]() 7881 forum posts 397 photos | You don't share the make or age of motorcycle with us, but generally speaking, many old bike tele forks were made from seamless tubing. The inside diameter was not machined, merely left as rolled. So they may well not be perfectly round nor perfectly parallel. Mostly the pistons were made a loose fit and relied on the piston rings, or O rings in later years, to seal. +1 on make an ali plug that you can fit the end of the fork leg over while plug is still in the lathe and size it that way. Then bung it on the end of a bit of rod and run it up and down both fork legs to check it will slide all the way up and down without binding. If it binds, knock a couple thou off and try again etc. Then turn your pistons to that final size. |
Bob Astill | 13/04/2018 09:23:12 |
![]() 114 forum posts 20 photos | Where are you i use digital and analog bore gauges all the time and have several maybe i can help i am between Grantham and Newark. Bob |
not done it yet | 13/04/2018 11:35:17 |
7517 forum posts 20 photos | Bob, Joe has no profile in his settings, but did say ‘within an hour of Corby, Northants’ in his opening post. |
Chris Evans 6 | 13/04/2018 11:50:18 |
![]() 2156 forum posts | I do a lot of motorcycle fork work, they are never very good for being round. Go with the Ali plug idea, you don't want them that tight that they won't slide. I now use glass filled PTFE rod to make the bushes and they slide well. |
Joe McKean | 14/04/2018 08:35:10 |
60 forum posts 3 photos | Hi Bob I have sent you a message. Joe |
old Al | 14/04/2018 11:43:55 |
187 forum posts | I think Joe is making his life hard for himself. If it were manufactured in imperial measurements, it makes sense to measure in imperial measurements. Then at least the start measurement becomes obvious with simple measuring tools. |
Joe McKean | 14/04/2018 12:27:46 |
60 forum posts 3 photos | Italian motorcycle therefore manufactured in metric, maybe I should have said 0.07619 mm instead of 3 thou tolerance. Work in metric and imperial sometimes even at the same time with no problems just have to make use of a calculator now and again. |
Jon | 15/04/2018 14:59:33 |
1001 forum posts 49 photos | Wouldnt be Marzochis would they. He is referring to the bore in the aluminium precision machined legs (unless worn oval) not bore of the precision fixed harder steel tube that slides within, no play.
JohnF | 15/04/2018 15:53:44 |
![]() 1243 forum posts 202 photos | Joe why not consider a bore gauge see this link, not too expensive and useful afterwards , Another alternative measure best you can with the tele gauge then make a multi stepped plug gauge in 0.002" steps, the steps don't need to be very long, then when you are confident of being very close to the size make or alter the gauge to longer steps and test again, last make/alter the gauge to the final size and test. About 2" of aluminium bar should suffice. Edited By JohnF on 15/04/2018 15:54:40 |
