Joseph Noci 1 | 19/01/2018 20:06:12 |
1323 forum posts 1431 photos | Finally put the finishing touches to my DIY Spot welder. I did post on this a while ago, and since then was waiting for the local powder coaters to reopen - which they only did this week! So, all assembled and done, and tested. Works very well indeed. Uses a Nucleo ( STM based uP) Arduino type processor module. Stepper driven upper pincer arm, with three pincer pressure ranges - 280kg/sq.cm, 350kg/sq.cm, 450kg/sq.cm. Auto-Weld Modes: 1 or 2 weld pulses per 'pinch', spaced 0.5sec apart. Pincers contact area is 3.2mm diameter 0.2sec up to 5.9sec weld timer. 1500amp, 2500amp, 3200amp and 4500amp settings ( on 2+2mm stainless) Foot pedal control. Manual Weld mode by pushbutton as well. Welds 2mm+2mm Stainless and mild steel with ease at 4000amp / 0.8sec timer setting Uses 40 amp 220V mains circuit - single phase - I have 3phase /60amp in the shop, so no problem... Front main panel controls Sub panel controls Foot Pedal control Moving Pincer Bus bar Heavy Wiring 2+2mm stainless Nugget 0.8+0.8MM Galvanised steel Nugget. The split is the nugget tearing a hole in the lower sheet. Only Space left in the Shop - Next to My NC Shaper..
Will maybe post a video showing the sparks flying... Joe Edit - Did try to attach a video - did not work - will do something maybe via utube.. Edited By Joseph Noci 1 on 19/01/2018 20:33:48 |
David George 1 | 19/01/2018 21:35:42 |
![]() 2110 forum posts 565 photos | Looks an amazing piece of tooling. Another piece of useful equipment. David |
Ady1 | 20/01/2018 00:11:25 |
![]() 6137 forum posts 893 photos | Great stuff Joe, amazing work
Did make me smile though Edit - Did try to attach a video - did not work you can build pretty much any tool imaginable, but the software in here defeats you |
clogs | 20/01/2018 08:24:03 |
630 forum posts 12 photos | Ice clean floor, easy to mop.....will look at ur previous post..... |
John MC | 20/01/2018 08:27:26 |
![]() 464 forum posts 72 photos | Impressive work! I've had a spot welder in the workshop for many years, its a very basic machines for which I had to make some parts for to get in to a usable state. Well worth the (little) effort. I used Copper electrodes initially, they would last for 10 -20 weld before needing to be reshaped. I then bought some proper electrodes, (Copper/Chrome alloy?), these will hold their shape a lot longer but still deform because they get so hot. The obvious way forward is to water cool the electrodes. Joe, have you considered cooling the electrodes? What material are your electrodes made from? I've just completed a job that required nearly 400 welds, it took all day, allowing time for the electrodes to cool and only 2 reshapings of the electrode! John |
KWIL | 20/01/2018 12:13:06 |
3681 forum posts 70 photos | If you have not done so already, look up and read about the "Noci's" work in conservation in Namibia, it will blow you mind. This is apart from what Joseph writes about on this Forum, which is also inspirational. |
Neil Wyatt | 20/01/2018 13:31:17 |
![]() 19226 forum posts 749 photos 86 articles | Very nice! But R2D2? It looks more like Huey: |
Joseph Noci 1 | 20/01/2018 18:47:01 |
1323 forum posts 1431 photos | Neil, That's a nostalgic kick in the butt! But, you are right - the shop is now so crowded I cannot see the wood for the trees...
Joe ps- Still working on a video - A steady hand is required so to scared to post something that may offend MichaelG... |
Michael Gilligan | 20/01/2018 19:21:07 |
![]() 23121 forum posts 1360 photos | Posted by Joseph Noci 1 on 20/01/2018 18:47:01:
ps- Still working on a video - A steady hand is required so to scared to post something that may offend MichaelG... . |
Muzzer | 20/01/2018 19:24:18 |
![]() 2904 forum posts 448 photos | No, it's Seasick Neil you have to worry about on the wobbly video front it seems! Merry |
MW | 20/01/2018 21:29:18 |
![]() 2052 forum posts 56 photos | Posted by Joseph Noci 1 on 20/01/2018 18:47:01
ps- Still working on a video - A steady hand is required so to scared to post something that may offend MichaelG... Ouch, That's a dig, not cool, not cool! Michael W |
Joseph Noci 1 | 21/01/2018 06:16:09 |
1323 forum posts 1431 photos | I apologise Michael. I did not mean to be rude. I posted a video some time ago, either on my Lathe ELS cutting a thread or on my shaper doing its thing, and I believe it was MichaelG twho commended the video for its stability. I tried to find that comment in all my posts but did not succeed - I have posted far to much junk. Anyway, I wanted to try live up to Michael's comment with a suitable video of the spot welder, but I sort of give up..To little space to move in the shop, always some distracting stuff in the background, panning between controls and machine business end, etc. The video is at best , nauseating.. Bah- Humbug! Sorry MichaelG.. Joe |
Michael Horner | 21/01/2018 08:46:26 |
229 forum posts 63 photos | Posted by Joseph Noci 1 on 26/03/2017 16:42:24:
I made a video, but the motion from one button to another and to the tool tip, and the thread start and end - makes me ill !!!!!
Joe I do so wish some of the other posters on here will take heed of Joe's words.
" To say that a lot of the members here can make such marvelous models and jobs the fact that the tripod was invented at least 400 years ago seems to escape them" . Hi Joe If the above is what you are referring to it was JS RIP. I just wish I had 10% of your energy! Spend far too long in the arm chair! Cheers Michael. |
Ian S C | 21/01/2018 09:04:15 |
![]() 7468 forum posts 230 photos | Don't worry too much about back ground clutter, that's half the interest in a lot of video, ie what does he have hidden under the bench, or in my case where is the bench, there must be one somewhere. Ian S C |
Michael Gilligan | 21/01/2018 10:27:56 |
![]() 23121 forum posts 1360 photos | Posted by Joseph Noci 1 on 21/01/2018 06:16:09:
[ ... ] Sorry MichaelG.. Joe . No problem, Joe ... I was just confused by the remark. Your work so far-exceeds my expectations, in both quality and quantity, that I doubt anything you produce is likely to offend me. But do feel free to prove me wrong MichaelG. . Edit: Further to Michael Horner's comment ... This appears to be the thread in questiion: http://www.model-engineer.co.uk/forums/postings.asp?th=126045&p=1 Edited By Michael Gilligan on 21/01/2018 10:44:37 |
Joseph Noci 1 | 21/01/2018 12:47:31 |
1323 forum posts 1431 photos | Oh Dear..My memory precedes me... It was John Stevenson's post I was trying to refer to. How I got the rest of this forum mixed up in the dig, I have no idea. Nuts. Sorry Chaps..
Regards Joe |
