Enlarging Hole
Steve Crow23/12/2017 14:54:50
429 forum posts
268 photos
Hi, this is a picture of a standard aluminium shaft support. They come in a huge range of metric sizes and are used extensively in CNC machines.
My problem is I need some to clamp 1 inch diameter bar.
I have a number of 25mm clamps. Can anyone suggest a method of opening one out by 0.4 mm?
Bear in mind that I only have a watchmakers lathe and drill press so boring is out of the question. Also, I don't want to be buying reamers or anything else.
Any suggestions?
Many thanks, Steve
not done it yet23/12/2017 15:16:14
7517 forum posts
20 photos
A location posted might elicit help from someone local?
Sam Longley 123/12/2017 15:31:19
965 forum posts
34 photos
Kind of puts a different slant on the "A listing of potential helpers" thread that came up a little while ago. This the second request for help that I have noticed in 2 days & it is just the sort of thing a local hobbyist might do in a very short time for a pint of beer & start a new friendship
Edited By Sam Longley 1 on 23/12/2017 15:32:24
David George 123/12/2017 15:33:31
2110 forum posts
565 photos
Hi Steve if you live near to me you or I could drop them on my little mill and bore them out. Sutton in Ashfield, Notts.
David
Bob Stevenson23/12/2017 15:36:14
579 forum posts
7 photos
Use a piece of the 25mm bar with abrasive paper to 'work' the mounting to 1 inch...it helps to slightly taper the piece of bar for about 10mm....sit in front of the telly, put your mind where it can't be offended and get twisting the bar back and forth until it just passes into the mounting....you have effectively opened up the mounting by the thickness of the abrasive paper (which will probavly be good enough)
Chris Evans 623/12/2017 15:39:33
2156 forum posts
If you are close to the Lichfield area I would willingly do that for you.
duncan webster23/12/2017 15:56:05
5307 forum posts
83 photos
Posted by Chris Evans 6 on 23/12/2017 15:39:33:
Ditto North Cheshire
KWIL23/12/2017 16:30:31
3681 forum posts
70 photos
Another example of the "reason" to have at least a general location on your Public Profile.
HOWARDT23/12/2017 17:41:35
1081 forum posts
39 photos
Ream out.
Brian Wood23/12/2017 18:31:21
2742 forum posts
39 photos
Howard,
He has already said that he doesn't want to be buying reamers, his lathe is watchmaker size and he has a drill press so pretty basically equipped
HOWARDT23/12/2017 19:05:16
1081 forum posts
39 photos
Use hand tools to chamfer end of 1" bar and cut edges into it to full diameter. Use mole grip and bore the parts through by hand. Before boring, clamp parts with spacer and bolt otherwise they will spring apart with the cut. Or if you are feeling lucky merely file the bore, it will probable close enough for what you want.
mark costello 123/12/2017 19:06:08
800 forum posts
16 photos
Could He use a between centers boring bar? If a list of People willing to lend a hand is made, I would be available although I am "across the pond" this is a WORLD WIDE read forum and has tremendous reach and knowledge.
Brian Wood23/12/2017 19:11:36
2742 forum posts
39 photos
I am in Thirsk North Yorkshire and would be glad to help, either boring out the supports or reducing the bars to fit
Alan Vos23/12/2017 19:42:39
162 forum posts
7 photos
My first thought was a round file. The only indication of the fit required is 'clamp'.
HOWARDT23/12/2017 19:48:39
1081 forum posts
39 photos
The fit is achieved with the bolt clamp, bore size to a degree doesn't matter. The difference in bore size affects the centreline height of the bar but this can be got over by shimming if required.
not done it yet23/12/2017 20:54:54
7517 forum posts
20 photos
Doubtless ken whotsiname would do it for a tenner (or maybe a twenty note)....
I would ream it, if he was close, as I expect there is one lurking somewhere in the workshop.
Another alternative might be to contact the nearest model engineering society.
A hundred of us could offer locations, only to find out he is on some remote island....
JohnF23/12/2017 21:27:21
1243 forum posts
202 photos
Ditto everyone who has mentioned location -- why would you want/need to hide? Would help in north Lancashire
Michael Gilligan23/12/2017 22:03:59
23121 forum posts
1360 photos
Posted by Steve Crow on 23/12/2017 14:54:50:
... Can anyone suggest a method of opening one out by 0.4 mm?
Any suggestions?
Many thanks, Steve
Gentlemen
Although several of you have generously offered to do the work for Steve [if he lived nearby], may I point out: That is not what he asked for.
Addressing the actual question: I would say that the drill press is, with the use of a vice or clamps, quite capable of doing the job safely and effectively ... Just make up a little boring bar [not dissimilar to a flycutter] and feed it in.
Obviously some centering device will be needed, but that's pretty much just a washer.
Roderick Jenkins23/12/2017 22:09:24
2376 forum posts
800 photos
I'm with Michael on this although I would be inclined to fill the gap with a sliver of something and clamp the screw up tight.
Rod
Neil Wyatt23/12/2017 22:09:33
19226 forum posts
749 photos
86 articles
Posted by JohnF on 23/12/2017 21:27:21:
Perhaps he's worried about being burgled or is concerned about identity theft?
