Redundant 5 speed pillar drill
Alfie Peacock15/08/2017 17:33:33
55 forum posts
As I now have a new pillar drill and have the old 5 speed one in the shed are there any ideas what can be made or tooling that could be used from it, As I am reluctant to take it down the local recycling because of the scrap metal that could be made to good use.
larry Phelan15/08/2017 18:00:08
544 forum posts
17 photos
Hi Alfie,
Can,t think of anything right now but DONT DUMP IT JUST YET !!! No sooner will you have scrapped it than you will find that you could have used it for this,that,or the other,something that you,ve been planning to do for a long time. How do I know ? Been there,done that, cursed for two days solid,afterwards !
Like marriage,dont rush into it !!
Michael Gilligan15/08/2017 18:21:21
23121 forum posts
1360 photos
[depending on the size of the machine, and your interests] ...
The obvious conversion might be a Tapping, Broaching & Staking tool; generally along the lines of the 'GHT Pillar Tool'.
See here: http://www.hemingwaykits.com/acatalog/Universal_Pillar_Tool.html
and think how much work and money you could save
Edited By Michael Gilligan on 15/08/2017 18:24:18
JasonB15/08/2017 18:34:30
My drill press gets used for honing, sanding both drum and RoLoc discs, wire brushing, driving keyway broaches and the odd bit of non accurate drilling as I now tend to do most of the drilling on my mill.
Tapping is done on the mill, what better way to ensure your tap is vertically above the hole if you tap it in the same position that it was just drilled in.
Neil Wyatt15/08/2017 18:36:09
19226 forum posts
749 photos
86 articles
I agonised for a few months, then gave mine away to a happy recipient rather than horde it. That said, at the least there is a useful motor and a large steel pipe with a machined OD.
john carruthers16/08/2017 08:36:06
617 forum posts
180 photos
The motor for a tool post grinder or milling spindle?
The rest for tapping?
Cake mixer?
Hacksaw16/08/2017 08:42:13
474 forum posts
202 photos
Heath Robinson horizontal linisher laugh
Robin Graham16/08/2017 22:49:59
1089 forum posts
345 photos
Had a similar experience myself - after wracking brain for possible uses for the old machine I came to the conclusion that - well it's a drill, maybe not the best on the planet, but it sort of works for what it's designed for, and perhaps I should shouldn't hoard it for bits to fulfil some as yet unimagined need. So I gave it away - the guy was delighted, it was a an upgrade for him to have any sort of drill press.
Rob.
bricky17/08/2017 00:00:32
627 forum posts
72 photos
I was given a cheap drill which was not very good.I removed the quill to be made into a toolpost grinder,then Iremoved the column from the base which will become a platform for a jack on my floor standing pillar drill.The drill table has a 90 degree tilt ,I cut the column down and use this table on the mill to bolt large items that won't fit my tilting vise ,the motor will power the toolpost grinder.Hope this gives you some ideas.
Frank
John Reese17/08/2017 01:38:32
1071 forum posts
There is no such thing as a redundant tool. More tools is always better than fewer tools.
not done it yet17/08/2017 07:49:16
7517 forum posts
20 photos
Redundant is different to 'worn out'. It should be recycled as a pillar drill, not just taken to 'the local recycling' as that will likely mean 'scrapped'.
Jim Nic17/08/2017 09:46:53
406 forum posts
235 photos
I recently purchased from e-bay just such a drill which was honestly described as not very good and I got cheaply. I got it because I wanted to do some engine turning for my current project and did not want to get grinding paste on my mill/drill. When I got it home I cleaned it up, adjusted the belt tension and quill guide screw to remove some of the play and put it aside. In the few weeks it's been put aside I have used it regularly for woodwork and other less important jobs to save disturbing set ups on the mill. I've yet to use it for the purpose for which it was bought and it has now been transferred from "aside" in the garage to the corner of the workshop.
Long story short, don't be too hasty to get rid of it and if it really is not wanted put it on e-bay and get yourself the cash for something you do want.
Jim
Alfie Peacock17/08/2017 10:11:35
55 forum posts
Thanks for these good ideas, I shall keep hold of it.
