Nige | 05/07/2017 18:12:21 |
![]() 370 forum posts 65 photos | Looking to make my own T Nuts and wondering if they are just plain mild steel or are they hardened/tempered please? |
Vic | 05/07/2017 18:15:53 |
3453 forum posts 23 photos | I've made T Nuts for a couple of mills over the years out of plain mild steel. Not heard of anyone hardening them before but you could do I suppose if you wanted to. |
Nige | 05/07/2017 18:21:55 |
![]() 370 forum posts 65 photos | Thanks Vic, I don't want to harden them, plain mild steel is ok by me if that's the usual |
John Haine | 05/07/2017 18:28:32 |
5563 forum posts 322 photos | If you tighten them enough for hardening to help, they will be too tight! However, when I made some out of some square BMS bar, I started by milling down one dimension to suit, and when I took it out of the vice it had developed a banana-like bend due to stress relief! So you may find it a good idea (if you use BMS) to get it red hot for a minute or two and let it cool slowly before starting to machine it. Or use black bar. |
Nige | 05/07/2017 18:37:45 |
![]() 370 forum posts 65 photos | Thanks John. I have heard of BMS 'unstressing' when it is machined, Ill try for black bar when I come to it |
steamdave | 05/07/2017 19:43:48 |
526 forum posts 45 photos | Posted by Nige on 05/07/2017 18:37:45:
Thanks John. I have heard of BMS 'unstressing' when it is machined, Ill try for black bar when I come to it And bash the bottom thread with the ball of a hammer to deliberately damage it so that you can't run the bolt all the way through and possibly damage the slot. Dave |
AJW | 05/07/2017 20:09:31 |
![]() 388 forum posts 137 photos | I tend to used a variety of studs in T nuts then run a washer and but on. Alan |
Roger Provins 2 | 05/07/2017 21:12:06 |
344 forum posts | Made a handful by milling two corners of a strip of mild steel then chopped it into short lengths and drilled and tapped them. Edited By Roger Provins 2 on 05/07/2017 21:13:19 |
Mark Rand | 05/07/2017 22:34:31 |
1505 forum posts 56 photos | If you make T nuts of the small size needed for Myford lathes and such, then hardening them can be useful to avoid thread tearout. I ended up case hardening all but one of the ones I made. Tthe other one didn't have any threads left... |
Hopper | 06/07/2017 00:16:55 |
![]() 7881 forum posts 397 photos | I make my own, Myford size, and never harden them. No problems. |
Enough! | 06/07/2017 01:28:09 |
1719 forum posts 1 photos | Posted by Nige on 05/07/2017 18:12:21:
Don't forget that you can turn T-Nuts if it's more convenient - stepped diameters; drill/tap; cut off; then mill flats on the larger dia. I generally find it less fiddly. Probably gets around any BMS distortion issue too. If you don't mind interrupted cuts, you can even put flats on a length of bar, turn the barrel dia and part/saw off. Repeat as necessary. Edited By Bandersnatch on 06/07/2017 01:28:51 |
not done it yet | 06/07/2017 08:27:39 |
7517 forum posts 20 photos | I have a dozen in a row at the moment, machined, drilled and tapped, waiting to be cut into separate pieces. A dozen because my mill only has 12 1/2" traverse and they will be milled to ~22mm long (if the cuts are all square). There will be more as both mills use the same 3/8" size. I would have preferred a hardenable steel as the threads would be less likely to get damaged (tight studding in the threads is a bear), but these are from black iron bar and I am likely not going to case harden them (my wife complains when I use the kiln for hours on end - no, every time I use it, if she knows!). |
Chris Evans 6 | 06/07/2017 08:40:28 |
![]() 2156 forum posts | If you use studs and not bolts in to the tee nut the life of simple mild steel will outlast you. |
Mark Rand | 06/07/2017 11:42:47 |
1505 forum posts 56 photos | Posted by Hopper on 06/07/2017 00:16:55:
Do you use 1/4" or 5/16" threads? I use 5/16" and there isn't much meat left on the top part of the nut at that diameter. |
Neil Lickfold | 06/07/2017 12:24:07 |
1025 forum posts 204 photos | I leave T nuts soft. I don't want them harder than the bed or slide they are being used on. If they wear over time, just replace or use helicoils to recover the threads. I make them fairly long to spread the load over the most area that is reasonably possible. Neil |
Martin Kyte | 06/07/2017 12:35:04 |
![]() 3445 forum posts 62 photos | This site gives a clamp load of 700 odd pounds for a 1/4 inch bolt. Myford boring tables are a little on the slender side so gently does it. Milling tables are much more robust. regards Martin |
Mick B1 | 06/07/2017 13:47:31 |
2444 forum posts 139 photos | All the industrial T-nuts I've used have been as hard as a landlord's heart. When I wanted to shorten one by a few thou to stop it projecting proud of the table and defeating a clamp, I had no option but to grind it. I'd imagine gauge plate would probably work well unhardened for most ME uses, but I think you might need to remake MS ones quite often. Edited By Mick Burmeister 1 on 06/07/2017 13:49:15 |
Vic | 06/07/2017 14:03:05 |
3453 forum posts 23 photos | Posted by Bandersnatch
Don't forget that you can turn T-Nuts if it's more convenient - stepped diameters; drill/tap; cut off; then mill flats on the larger dia. I generally find it less fiddly. Probably gets around any BMS distortion issue too. Yes, I've made them like that as well. |
Enough! | 06/07/2017 14:39:52 |
1719 forum posts 1 photos | I have to admit that I only ever make the "specials". I buy standard T-Nuts .... they are so inexpensive and I have more than enough jobs in progress and planned that the time can be better spent on. Most of the ones I buy don't seem to be particularly hard. At least I've milled/filed them down for other purposes occasionally.
Edited By Bandersnatch on 06/07/2017 14:40:51 |
Nige | 06/07/2017 20:01:28 |
![]() 370 forum posts 65 photos | Resigned to having to make T Nuts as I am finding it difficult to find them to fit my Myford ML4; all the commercially available 3/8 threaded ones seem to be too deep in the base as the bottom slot is only 5/32 'thick'. 8mm versions seem to have the same problem. |
