Vic | 08/05/2017 20:09:23 |
3453 forum posts 23 photos | I've been trying to source some 8" long bits of 1/4" round HSS and saw this: 6.5 mm is close enough although it does go on to say it's .25" I nearly ordered some until I also noticed it say it's unhardened. I've not seen unhardened HSS for sale before and got the impression it's not really possible to harden it in the home shop properly. Any ideas of where I can get some 8" long pieces of 1/4" HSS that's ready to grind? |
Roger Provins 2 | 08/05/2017 20:21:14 |
344 forum posts | Search eBay "round bar 200mm hss" |
David Standing 1 | 08/05/2017 21:05:24 |
1297 forum posts 50 photos | Also look for HSS drill blanks. You'll have to look for long series if you need 8" length. |
Vic | 08/05/2017 21:32:57 |
3453 forum posts 23 photos | Posted by Roger Provins 2 on 08/05/2017 20:21:14:
Search eBay "round bar 200mm hss" I tried that and the only hit was unhardened again. |
Nick_G | 08/05/2017 21:47:26 |
![]() 1808 forum posts 744 photos | . I cannot help you in your search quest. - But curiosity has got the better of me. What's it for.? Nick |
Vic | 08/05/2017 21:59:18 |
3453 forum posts 23 photos | Posted by Nick_G on 08/05/2017 21:47:26:
. I cannot help you in your search quest. - But curiosity has got the better of me. What's it for.? Nick Wood turning tools. I've found and ordered some 10mm X 200mm for £2.44 a piece inc shipping but can't find any 1/4". |
John Stevenson | 08/05/2017 22:11:57 |
![]() 5068 forum posts 3 photos | What about 1/4" Stellite? |
Clive B | 08/05/2017 23:09:02 |
46 forum posts 21 photos | You can purchase 6.5mm x 200mm HSS from CTC Tools, but they only seem to sell this size in packs of 5. By coincidence I have also been trying to source long pieces of HSS for woodturning tools. Clive |
peak4 | 09/05/2017 02:11:32 |
![]() 2207 forum posts 210 photos | Here's some 6mm in China
Vic | 09/05/2017 13:20:41 |
Thanks, I've found another seller on eBay with some 6mm so I've ordered some but I'll bookmark that one as well. I've seen some 30" lengths of 1/4" in the US but it's not cheap and of course the postage would be silly money. |
Neil Wyatt | 09/05/2017 13:33:36 |
![]() 19226 forum posts 749 photos 86 articles | Well unhardened HSS is like hen's teeth but I suspect that seller may actually have silver steel... Neil |
John Haine | 09/05/2017 14:14:38 |
5563 forum posts 322 photos | IIRC, Martin Cleeve's book on screwcutting in the lathe has instructions for hardening HSS. |
Neil Wyatt | 09/05/2017 16:05:48 |
![]() 19226 forum posts 749 photos 86 articles | The problem is that there are many versions of HSS and as many different treatment procedures. It would be nice to know what version of HSS they were using in the 50s/60s that could be treated adequately by heating white hot, then quenching with an air blast. Neil
Nigel Bennett | 09/05/2017 19:25:28 |
![]() 500 forum posts 31 photos | I recently got some of the 6mm round HSS from China; I needed them for making some taper reamers for making injectors. I was quite surprised when one of them twisted in use, ending up looking like those olivers they put on showman's engines. So having realised they were unhardened, I simply heated the end of one of them up to cherry red and dunked it in some water. A gentle tap with a hammer had the hard end pinging off into the recesses of the shed, so at least it confirmed they were hardenable! **LINK** gives some useful information about hardening & tempering HSS. I shall have a go and see what I can do with the Chinese HSS and then make some more reamers! |
David George 1 | 09/05/2017 19:40:46 |
![]() 2110 forum posts 565 photos | To check the type of steel the sparks given off by HSS is different to silver steel when ground on an offhand grinder. Use a known sample as a guide. A red spark with HSS a brighter spark with silver steel. I was taught this as an apprentice. David Edited By David George 1 on 09/05/2017 19:42:18 |
Ian Welford | 09/05/2017 21:07:17 |
300 forum posts | get in touch with Ashley Isles , Tony Isles is probably your best bet over in Spilsby. They sell off cuts of the HSS bars they use to make wood working gouge. I ve had a few bits from them to make round skew chisels for wood turning and its excellent stuff.
Also had tools from CTC and they're very helpful too.
Good luck Ian |
Jelly | 09/05/2017 23:16:37 |
![]() 474 forum posts 103 photos | Neil, by the 60's most grades of HSS had been developed (the landmarks being Mushet steel in 1866, T1 in 1907 & M2 in 1936). M2 can be adequately treated by heating to 1040-1100?c in atmospheric conditions, followed with a combination of brine quench until equalised followed by air until cool. M42 will also harden that way, but as it won't reach its full potential (upto HRC70!!!) without salt or vacuum treatment at temperatures very close to it's melting point, it would be pointless buying the higher grade to then heat treat it like that. As I understand it the issue with all HSS is the need for controlled heating for good results... Initally in several stages followed by a rapid burst of energy to take it from ~900?c up to the final hardening temp of 1100-1200?c, and then multiple long tempering cycles in very a narrow temperature band... it would be hard and labour intensive to achieve that without building or buying specialist equipment. |
Ian S C | 10/05/2017 10:49:26 |
![]() 7468 forum posts 230 photos | For wood turning tools you probably would be best if it was hard and tempered at the cutting end, graduated to the soft state at the handle end. I'v got some HSS wood turning tools, but I have not checked the hardness handle end, but less likely to break if unhardened. Ian S C |
Neil Wyatt | 10/05/2017 15:41:14 |
![]() 19226 forum posts 749 photos 86 articles | Posted by Joshua Kelly on 09/05/2017 23:16:37:
Neil, by the 60's most grades of HSS had been developed (the landmarks being Mushet steel in 1866, T1 in 1907 & M2 in 1936). Indeed, but what was the grade that contributors to ME were using? They only ever describe it as 'HSS', but the characteristics were machinable with ordinary tooling and hardenable with a two step process of heat and air quench. Neil |
Andrew Johnston | 10/05/2017 18:41:37 |
![]() 7061 forum posts 719 photos | Probably D2, a high carbon and chromium tool steel that can hardened, air cooled and tempered in a similar manner to gauge plate, albeit the hardening temperature is rather higher at about 1000°C. That's perfectly doable in the home workshop whereas the 1200°C required for full hardening of HSS is not. Andrew |
