Micrometer Blues
Calibrating a Starrett Mic'
Simon Williams 312/04/2017 22:20:34
728 forum posts
90 photos
Good evening everyone, after some advice please.
x
I find this quite difficult to read, as the fiducial line is inside the thimble. This presently reads 7.50 mm, but the 0.5 line is obscured by the thimble sleeve. It can be quite confusing particularly at intermediate settings.
So is it possible to move the thimble about 0.2 mm to the right on the spindle? How is the spindle held in the RHS of the thimble?
How many heart attacks would I be responsible for if I took the angle grinder and took 0.2 mm off the left end (scale end) of the thimble, heretic that I am?
Thanks as ever in anticipation of The Knowledge!
Simon
Simon Collier12/04/2017 22:30:00
525 forum posts
65 photos
Looks perfectly normal and correct to me. If you really hate it, get a digital one.
Emgee12/04/2017 22:31:55
2610 forum posts
312 photos
Hi Simon
With your picture viewed full size in your album it is clearly seen reading as 7.50mm, don't forget you only see halve of the line width. I sometimes have to turn the thimble a bit to check exactly before turning back to the measured position.
Emgee
John Reese12/04/2017 22:31:56
1071 forum posts
I can just see the line peeking out from under the thimble. You might try disassembling the mike to see if the graduated skeeve can be slid toward the frame. On some mikes the sleeve is just a friction fit. It might also be possible to stone off the end of the sleeve to allow it to slide to the left (according to the picture). I like the Brown and Sharpe mikes with the slant line graduations.
David George 112/04/2017 22:50:36
2110 forum posts
565 photos
Hi Simon it is possible that the sleeve has worked is way to the right and using the adjustment C spanner rotate it and pull further to the right clean the gap then twist and push it back and adjust and calibrate to check size. It is tight fitting sleeve but only use the correct spanner.
David
AJW12/04/2017 23:43:17
388 forum posts
137 photos
All my mics look like that!
Always thought it was correct.
Alan
duncan webster12/04/2017 23:46:52
5307 forum posts
83 photos
Looks perfectly normal to me too, you can see daylight after the 7mm mark, so it's obviously not 7.0mm. Having said that, I hate metric mics, I've lost count of the number of times I've made something exactly 0.5mm wrong. Eventually you'll get used to it. I''ve bought a digital mic, but I hardly ever use it.
I.M. OUTAHERE13/04/2017 04:28:16
1468 forum posts
Hi Simon,
While i have to agree with the other replies in regards to it reading correctly i i also understand where you are coming from !
Take a look at the youtube channel mrpete222 Shop tips #302 he stripped down a mic and lightly skimmed the end of the barrel opposite the thimble so more of the line was showing as he had troubles seeing it when most of the line was under the thimble .
Ian
jimmy b13/04/2017 04:37:04
857 forum posts
45 photos
If it makes it easier for you, just skim the barrel.
John Haine13/04/2017 08:28:39
5563 forum posts
322 photos
I agree with others, this is normal. I have found over the years that it takes practice and a basic knowledge of how the things work to use instruments consistently, just keep using it and thinking about the reading until it becomes second nature.
Jon Gibbs13/04/2017 08:32:45
750 forum posts
Hi Simon,
MrPete222 on YouTube has a video on rectifying this issue here... **LINK**
[Edit: Sorry Ian seems to have beaten me to it.]
HTH
Jon
Edited By Jon Gibbs on 13/04/2017 08:35:25
Speedy Builder513/04/2017 08:34:28
2878 forum posts
248 photos
Go back to IMPERIAL, You don't get the same problem!
BobH
not done it yet13/04/2017 08:51:46
7517 forum posts
20 photos
Looks spot on to me.
Send it to me and I will replace it with something which would be easier for you to read. I think I may have something that reads to the nearest 0.1mm with an accuracy of about one digit.
As there appears to be only one reading among so many that troubles you, I think there is no reason whatsoever to consider potentially destroying such a precision device. Live with it and learn how to use it, is my advice. You clearly know where the 7.50 reading occurs, so what is the real problem?
Nick Hulme13/04/2017 08:55:07
750 forum posts
37 photos
If you can find one at a decent price the Mitutoyo Combimike is worth a punt, the white numbers on a black background are very clear, variants were available with an imperial spindle combined with a metric mechanical digital readout and vice-versa. Mitutoyo also did all metric and all imperial spindle/mechanical digital combination micrometers, other brands did them too.
Tony Pratt 113/04/2017 09:51:09
2319 forum posts
13 photos
I have had mikes worse than this but it is annoying, skimming the barrel end is about the best option if it bothers you that much.
Tony
Bob Stevenson13/04/2017 10:04:17
579 forum posts
7 photos
.........So, if I have got the gist of this, you want to make an accurate micrometer 'inaccurate' in the interests of increased accuracy...(?)
Tony Pratt 113/04/2017 10:29:29
2319 forum posts
13 photos
Posted by Bob Stevenson on 13/04/2017 10:04:17:
The gist is that the OP wants to see more of the spindle lines, no mods suggested will affect the 'accuracy' of the micrometer.
Tony
Bob Stevenson13/04/2017 10:58:58
579 forum posts
7 photos
If you shorten the thimble to make the line more visible you have built in an inaccuracy becasue the line placing will no longer by true (accurate)...especially with the OP's main problem of "intermediate settings"
.....unless the OP is planning to measure exactly how much he is going to remove from the thimble and then adds this number to any measurements he makes in future (to 'correct' the measurement and keep things 'accurate'
mechman4813/04/2017 11:18:50
2947 forum posts
468 photos
... 'How many heart attacks would I be responsible for if I took the angle grinder and took 0.2 mm off the left end (scale end) of the thimble, heretic that I am'?
​I guess you're speaking metaphorically... If you think can take off 0.2 mm with an angle grinder you're a better man than I am Gunga Din, steer well clear of any 'adjustment', get a loupe or magnifier to view the line better, or better still get a digi mic, ( Mitutoyo if you can afford it )... leave well alone it's fine as it is.
​George.
Jon Gibbs13/04/2017 11:56:01
750 forum posts
Posted by Tony Pratt 1 on 13/04/2017 10:29:29:
Tony
+1
Few people seem to understand how a micrometer works.
Jon
