Metal cutting Mitre saw
Suggestions for cutting steel hollow section
ChrisB02/04/2017 12:32:33
671 forum posts
212 photos
I'm after a mitre saw for cutting steel hollow section, 2 by 2 inch at most, for a lathe and milling bench. The problem is there seem to be an infinite variety of types and prices.
I'm more inclined towards a TCT blade rather than an abrasive one (don't want too much sparks flying around in my garage!) but the saws I'm seeing all seem to be wood saws. There must be metal cutting saws as the metal cutting blades seem to have lower speed than their wood cutting versions...can someone point me to a good mitre saw without breaking my budget, ( £250 or there abouts) thanks
Curtis Rutter02/04/2017 12:36:34
133 forum posts
14 photos
I've got this one which I used mainly for building my workshop bench out of wood but I've cut a couple of pieces of hollow square bar and angle plate albeit very thin and they came out fine
Edited By Curtis Rutter on 02/04/2017 12:37:18
Edited By Curtis Rutter on 02/04/2017 12:37:55
Frances IoM02/04/2017 12:42:33
1395 forum posts
30 photos
if you have a lathe + a mill then I'd have thought a small metal bandsaw would be the third purchase very shortly afterwards unless you are into pop-eye like muscles from hacksawing - the small ones from chester tools H180 work ok and are under your budget - they will do mitre cuts up of that size + straight cuts to about 90mm dia
John Rudd02/04/2017 12:51:08
1479 forum posts
Chris,
Private message sent to you.
Edited By John Rudd on 02/04/2017 12:53:54
ChrisB02/04/2017 13:53:36
671 forum posts
212 photos
No I'm not hacksawing anything! I'm past the "pop-eye like muscles" age, so I'd rather have a machine do it for me! cheeky
Will check local tool shops for something similar to the one you linked Curtis, from what I can understand from the specs, it's blade is good for steel up to 6mm so it should be fine.
The bandsaw won't fit in my workshop John, have to share with two cars. Would have been a good addition tho
Neil Wyatt02/04/2017 15:32:51
19226 forum posts
749 photos
86 articles
Plenty here, using TCT and abrasive blades, but not cheap compared to wood cutting ones.
www.machinemart.co.uk/c/cut-off-saws/
Journeyman02/04/2017 16:47:54
1257 forum posts
264 photos
Chris, there are small benchtop bandsaws about that take up no more room than a mitre saw. See this **recent thread**
Mike Poole02/04/2017 18:08:45
3676 forum posts
82 photos
Have you considered the evolution rage saws?
Frances IoM02/04/2017 19:03:37
1395 forum posts
30 photos
I bought a 'rage' saw prior to the bandsaw mistakenly thinking it would serve same purpose - extremely noisy but also throws out small bits of metal at high speed - needs to be used outside - the bandsaw is quiet, makes just a small neat pile of easily hoovered filings - I mounted mine on a turntable so could fit fairly close to a wall then swung thru 90deg to allow long stock to be cut - the supplied legs work but take up too much valuable space
ChrisB02/04/2017 19:17:16
671 forum posts
212 photos
Hi Mike, Initially I was considering circular type saws, but after going through the thread linked by John I'm not sure anymore. The bandsaw makes sense as I will cut bar stock as well as tube, where as the circular saw will cut tubes only. So now I need to decide which way to go...
JohnF02/04/2017 19:25:43
1243 forum posts
202 photos
Chris, As Journeyman says I would look at the Femi bandsaw, it will take up less space than a mitre saw and in my opinion do a better job. You can cut up to 4" dia or square it has a very small footprint, is easy to lift onto a shelf for storage if need be. I have had mine for quite a few years and never regretted the purchase. They are available from several suppliers in the UK just google Femi
peak402/04/2017 19:30:23
2207 forum posts
210 photos
I used to use one of these at work before I retired, Noisy, metal chips everywhere, but fast and reasonably accurate. I regularly used it on heavy duty 2 1/2" angle and unistrut, but be warned replacement blades are quite expensive, so you need to factor that in.
egAAOSwzJ5XanZU">http://www.ebay.co.uk/itm/DeWALT-DW872-355mm-METAL-CUTTING-CHOP-SAW-110v-including-TCT-BLADE-/351766077458?hash=item51e6e46012:gegAAOSwzJ5XanZU
JasonB02/04/2017 19:40:04
Posted by ChrisB on 02/04/2017 13:53:36:
My Femi bandsaw has a smaller foot print than my chop saw and is small enough to lift off the bench and put under it if you are tight for room.
charadam02/04/2017 20:51:24
185 forum posts
6 photos
I bought the Rage mitre saw a few years back.
It cut all kinds of mild for me, but it was noisy and the chips (red hot and supersonic) inconvenient to say the least.
I lost teeth on 2 blades through hitting inclusions in rebar - with blades a £40 a pop.
It is now fitted with a blade for wood and a 6" bandsaw has taken over the duty.
ChrisB02/04/2017 21:33:20
671 forum posts
212 photos
Ok, from what I can gather the general consensus is in favor of the bandsaw. I have found a local Maltese shop who imports Femi, so I asked for a couple of quotes for the 780XL and 782XL...will see if it's worth buying local or abroad - my guess is it will be cheaper to get one from Italy. Thanks for all the input given from all.
Paul Lousick02/04/2017 22:09:21
2276 forum posts
801 photos
If you do not have the space for a small bench/floor mounted bandsaw, you could use a hand held bandsaw.
Paul
Neil Wyatt02/04/2017 23:35:43
19226 forum posts
749 photos
86 articles
Posted by Paul Lousick on 02/04/2017 22:09:21:
Paul
<checks date>
peak402/04/2017 23:57:38
2207 forum posts
210 photos
The date's fine Neil, When I was reinforcing the bench that came with our new house I used an older Milford one to cut the 40mm box section to size before welding it together.
They're a cracking but of kit, but they do wander sometimes when the blade starts to get older.
Unfortunately, ready made blades are hard to come by, so I have to braze my own to length 49 1/2", though there are firms who will make custom sizes.
I am/was considering shortening the saw slightly to take the normal sized Makita ones.
Bill
JasonB03/04/2017 07:11:59
You can get a couple of saws of similar design to the Femi that can be removed from the base and used handheld like the one Paul shows I think Flex (Portacable) are one. Downside of a handheld would be you are only hand holding so will not get a consistant angle like you would with a fixed saw.
Flex saw
Edited By JasonB on 03/04/2017 07:57:16
Michael Gilligan03/04/2017 07:53:20
23121 forum posts
1360 photos
Posted by Neil Wyatt on 02/04/2017 23:35:43:
<checks date>
Check Milwaukee website:
https://www.milwaukeetool.com/power-tools/cordless/2629-22
