Member postings for Curtis Rutter
Here is a list of all the postings Curtis Rutter has made in our forums. Click on a thread name to jump to the thread.
Thread: New member in Cumbria
07/10/2022 07:55:04
Hi all just moved to Workington Cumbria and after having to sell up shop due to divorce quite a few years back I’m now in a place to start rebuilding an albeit smaller workshop with aim of model engineering rather then building motorbikes
Thread: Worktop suitable for small mill
08/08/2021 08:55:16
Posted by Ron Laden on 08/08/2021 06:57:45:
Re a swarf/oil tray I found a shallow baking tray which the mill base sits in, saves having to make one. If you search around you can find quite large ones that fit larger type ovens.
Ron
Good idea
07/08/2021 22:00:58
Posted by Howard Lewis on 07/08/2021 21:04:05:
I was going to suggest reinforcing either with thick ply, or with steel plate., (3mm steel will reinforce the worktop quite well ) If you could clamp some thin Ali or steel bent upm into man angle (16 gauge or thinner, around the edges, that would make the steel reinforcement into a swarf tray as well.
That’s a great idea, better than having the swarf and any cutting fluid/Lubricant going all over the worktop!
Edited By Curtis Rutter on 07/08/2021 22:01:28
07/08/2021 22:00:03
Posted by old mart on 07/08/2021 20:39:12:
If you are worried, why not reinforce the entire top with a single fitted piece of 19mm plywood.
Perfect that’s good to know
07/08/2021 15:50:43
Posted by Roger Best on 07/08/2021 15:41:58:
I was looking at this problem last year, metal cabinets are good for about 100kg each, however they can rattle and wobble so I would advise that you brace the tops to the wall, and to each other very rigidly. your floor is wonderful so I won't mention levelling.
Thank you
Good thinking, can easily enough brace them to the garage brick wall with a bolt or two on top of them being bolted to each other already
07/08/2021 14:57:07
I’m looking at purchasing the Sieg SX2P mill but want to mount it on my current workbench, looking at the workbench that’s available from Arc Euro I’m wondering if what I already have will be strong enough.
Unfortuantely the user manual for the bench/drawers doesn’t give any information on load capacity.
This is the worktop/bench in question, was thinking it would be mounted on the worktop in between the 7 drawer and larger cupboard so would have the main support underneath from both cupboards. The Sieg weighs in at approx 70kg and I’m 80kg and have stood on it to reach something on top and no flexi on but obviously long term I’m unsure
Edited By Curtis Rutter on 07/08/2021 14:58:55
Edited By Curtis Rutter on 07/08/2021 15:05:00
Edited By Curtis Rutter on 07/08/2021 15:06:45
Thread: Any Chemists (rust)
23/02/2018 09:17:12
Have bought a small bottle of the evapo rust to try out as parts of my ML7 are showing light surface rust. Do you think it will work if wiped/sprayed onto parts and left?
Thread: Recommended lathe outside protection?
20/12/2017 08:37:59
Where about a are you? I have some left over aircraft grade Anti corrosive that I used on my ML7 for 4 months in a damp unheated garage whilst it was being stored. Will require a clean down after application but not a single bit of rust appeared in the time, I also covered in a dust sheet.
Thread: How can I keep a deeply drilled hole straight?
14/09/2017 16:03:51
I'm far from an expert but I've always drilled holes undersized then bored to correct diameter although deepest holes I've drilled/bored have been 50mm in depth, reamers are another possibility.
Edited By Curtis Rutter on 14/09/2017 16:04:39
Thread: Myford Users - DRO Request
12/09/2017 06:01:04
i hope they revised the instructions, i had one of the first ones made up for an ML7 around march, the instructions were next to useless as they were designed for the super 7, had to get assistance from one of their engineers and even he said he couldnt understand their instructions but fortunately he had the knowledge to fit it without the instructions.
Edited By Curtis Rutter on 12/09/2017 06:02:02
Thread: Book Dust Filtration
09/09/2017 11:11:13
I love reading and am in the process of building fitted bookshelves into my study to allow my book collection to grow. I have everything from the great English classics to engineering titles and medical journals. I just don't enjoy reading on an e-reader
Thread: Something Else Exciting is also on it's way
06/09/2017 18:32:36
Think we need a full inventory!
Thread: Hello from Essex
30/08/2017 12:16:08
This place is brilliant for all things model engineering. Might be worth looking at http://www.modelenginemaker.com specifically for model engines too
Edited By Curtis Rutter on 30/08/2017 12:17:13
Thread: Model motorcycles in 1/6 scale
30/08/2017 10:08:20
Where are you located?
30/08/2017 07:48:03
Still they're impressive, I too am into full bike builds, am 3/4 through a minitwin race bike just running short on time to finish it at the mo crying 2
29/08/2017 22:07:36
I'm envious, do the engines run?
Thread: What Did You Do Today (2017)
30/06/2017 22:54:36
Posted by Andrew Johnston on 27/06/2017 21:18:10:
Yesterday I was certified for another year. smile o Civil Aviation Class 2 medical that is, involving a drive to Stansted and back. The doctor told me in no uncertain terms that I need to take pictures of the workshop and of progress on the traction engines next year.
Yesterday afternoon, today and this evening I've been working. So much for the three day week I agreed, although it is better than the Ted Heath variety.
I notice you're cambridge based Andrew, when I move that way in a couple of months going to start my PPL, any recommendations?
Thread: Stirling Engine Tolerances/Clearances
25/05/2017 14:28:28
The respective diameters are 22mm and 18mm so will try it with the 0.5mm gap and at least if it doesn't work I can enlarge the bore and get bigger displacement cylinder/displacer. Because I'm using Borisilicate glass it's giving me limited options to the sizes
Edited By Curtis Rutter on 25/05/2017 14:30:05
25/05/2017 12:31:23
in regards to the displacement cylinder and the displacer how tight a fit/or loose should it be? I've only been able to locate the relevant sizes that give me a clearance of 0.5mm between the two, is that too tight?
Thread: Helooooo From Cambridgeshire
08/05/2017 19:19:23
Posted by Howard Lewis on 08/05/2017 18:41:13:
So are you closer to Cambridge, or to Peterborough?
Both have thriving M E societies, well worth joining.
I'm smack bang in the middle of both. Why won't you be going back to Cambridge ME Andrew?
