Steve Withnell | 25/03/2017 13:34:55 |
![]() 858 forum posts 215 photos | I'm looking to silver plate some copper rods as part of an RF (1.3GHz) electronics project, and while I can find formulations for electro-cleaning the rods prior to plating, I can only find one source of silver plating solution which is £35 for 250mL, but I can't find any info on its formulation - cyanide free that is. The coating does not need to be a bright finish, which seems to be the difficult bit, but just a nice uniform coat of pure silver. Anyone got a formulation I could use make up to do some trial plating? TIA Steve |
Clive Hartland | 25/03/2017 14:41:23 |
![]() 2929 forum posts 41 photos | I seem to remember that RF runs on the surface of conductors so you do not need solid rod copper. I made lots of tuning devices for a certain department who monitored the ether, silver was the preferred choice of materiel and surface. It will give you some gain. I am sure there are some plating shops that will do it. check the internet for one. Clive |
Neil Wyatt | 25/03/2017 17:33:05 |
![]() 19226 forum posts 749 photos 86 articles | Try a Google for "silver plating solution MSDS" Neil edit: MSDS = Manufacturer's Safety Data Sheet Edited By Neil Wyatt on 25/03/2017 17:33:42 |
SillyOldDuffer | 25/03/2017 18:45:04 |
10668 forum posts 2415 photos | Hi Steve, This 2012 paper describes a cyanide free mix and how to use it. Also these chaps sell a cheaper commercial mix than the source you found. Their site also has a calculator for working out how much liquid you need and lots of other help re cleaning and voltages etc. Dave. |
Brian Oldford | 25/03/2017 18:49:33 |
![]() 686 forum posts 18 photos | Posted by Steve Withnell on 25/03/2017 13:34:55:
I'm looking to silver plate some copper rods as part of an RF (1.3GHz) electronics project, and while I can find formulations for electro-cleaning the rods prior to plating, I can only find one source of silver plating solution which is £35 for 250mL, but I can't find any info on its formulation - cyanide free that is. . . . . . . Please keep us informed of any success, or otherwise. Such a project at a 23cms is also of interest to me.
Steve Withnell | 25/03/2017 19:45:03 |
![]() 858 forum posts 215 photos | This is one I made earlier, without the silver plating... This one has a centre frequency of 1090MHz to stick on the front of one of those SDR TV sticks, to capture aircraft ADS-B signals. (Which when the moon is in the right phase, gets uploaded to Flightradar24 and gets me a free subscription!) Silver plating the rods should improve the filter performance, the interest is in measuring by how much. Steve Edited By Steve Withnell on 25/03/2017 19:47:46 |
mark smith 20 | 25/03/2017 20:13:34 |
682 forum posts 337 photos | Making your own silvering solution is not cheap . Despite the price of silver being quite low ,anything made out of it is expensive probably for market reasons . For instance 50gms of silver nitrate will cost you between £50-£100. Theoretically you could make that amount for around £20. |
Russell Eberhardt | 25/03/2017 20:28:57 |
![]() 2785 forum posts 87 photos | Can't help with the silver plating but I can give some pointers on high frequency performance: The resistivity of copper is 1.72 microohm/cm, giving a skin depth at 1.3 GHz of 1.83 micron. The resistivity of silver is 1.59 microohm/cm, giving a skin depth at 1.3 GHz of 1.76 micron. So, while the resistivity of silver is lower the current flows in a thinner layer and the improvement is less than you might expect. In fact the resistance will only drop by 4% and the Q factor of the resonators will thus only improve by 4%. Silver plating can give a long term benefit as the tarnish on copper can be semiconducting however a thin coating of lacquer is easier and cheaper to apply. Russell
Edited By Russell Eberhardt on 25/03/2017 20:31:37 Edited By Russell Eberhardt on 25/03/2017 20:34:00 |
Brian H | 26/03/2017 10:15:32 |
![]() 2312 forum posts 112 photos | would the rub on silver powder as used for clock faces be any use? It puts on a very thin layer of silver that is not shiny. Available from a number of clock parts suppliers. Brian |
Martin Whittle | 26/03/2017 20:46:10 |
102 forum posts 12 photos | Further to the excellent quidance from Russell: For loss in synchronously tuned filters, in the time when I was (less) gainfully employed, a couple of extremely useful reference works were written by Seymour Cohn, specifically see ‘Dissipation Loss in Multiple-Coupled-Resonator Filters’, Proc. IRE August 1959 if you can find access. I don’t now have access to my paper copy, but I remember something close to: Filter loss in dB = 4.343*(reciprocal of fractional BW)*sigma(gi/Qi) Where Qi is the Q factor of the i’th resonator, and gi is the normalised value of the i’th resonator (for the low pass prototype at a frequency of 1 radian/sec and impedance 1 ohm). I cannot remember whether the fractional BW relates to the half-sided BW or the full BW as a ratio of centre frequency. But anyway, the passband insertion loss in dB is directly proportional to the inverse of the resonator Q factor (simplifying to assume the resonators are all the same). The stopband performace is not significantly affected by the Q factor. Note that silver oxide is electrically conductive (hence silver use in switch contacts and general electronic use), but copper oxide is significantly less so, see use in copper oxide rectifiers, **LINK** I agree that coat of lacquer will give much of the long-term benefit of silver plating Martin Edited By Martin Whittle on 26/03/2017 20:53:29 |
Harry Wilkes | 26/03/2017 21:35:10 |
![]() 1613 forum posts 72 photos | Maybe a daft suggestion but could you 'guild' them ! H |
Enough! | 27/03/2017 01:34:17 |
1719 forum posts 1 photos | Has it actually been established that any silver plating solution uses cyanide? I used to be involved with plating tubular spacecraft antennas in the 70's using both gold and silver. I distinctly remember cyanide being used in the gold-plating process but I don't recall it in the silver process. ..... but it was along time ago and I was only peripherally involved in the actual plating of the antennas. |
mark smith 20 | 27/03/2017 10:19:27 |
682 forum posts 337 photos | Silver plating has always used cyanide solutions particularly in industry ,there are alternatives but cyanides give the best results especially from a cosmetic point of view. Alternatives use thiosulphates etc.. Which interestingly can be used as part of an antidote for cyanide poisoning. Edited By mark smith 20 on 27/03/2017 10:20:21 |
peak4 | 27/03/2017 10:42:15 |
![]() 2207 forum posts 210 photos | Steve, from Henley's Formulas For Home and Workshop; 1907, rev.1927 reprint 1979,with suitable warnings on the frontispiece. 1) Nitrate of silver-30 parts by weight, Caustic potash-30 parts, distilled water 100 parts. Pour the nitrate into the water, one quarter hour after, add the potash. When the solution is done, filter, it is sufficient to dip the parts into the bath, moving them for 1-2 minutes at most; then rinsing and drying in sawdust. It is necessary to pickle the pieces before using the bath. To make the nitrate of silver ones self, take 30 parts of pure silver and 60 parts nitric acid, and when the metal is dissolved, add the caustic potash and the water, 2) Pastes for silvering; carbonate of lime-65 parts, sea salt-60 parts, cream of tartar-35 parts,nitrate of silver-20 parts. Bray all in a mortar, not adding the carbonate of lime until all other substances are reduced to a fine powder. Next add a little water to form a homogeneous paste, which is preserved in blue bottles away from the light. for use, put a little of this paste on a small pad and rub the article with it. Most of their other methods use cyanide. The book does make good bedtime reading though. |
Neil Wyatt | 27/03/2017 11:29:10 |
![]() 19226 forum posts 749 photos 86 articles | May be a silly question, but does the diameter of the rods matter? A 1% increase in diameter will give a 3% increase in surface area, bringinging nearly all the improvement silver would give (assuming Russell's calculation is correct). Neil |
SillyOldDuffer | 27/03/2017 11:29:40 |
10668 forum posts 2415 photos | I do like the way this forum challenges my perceptions. I've been a radio amateur since I was 16 and thought I knew all about silver plating RF components and why it's done. Now a bit of research reveals that all the alleged benefits are questionable. Arghh! The strange thing is that expensive well made RF gear 'always' contains silver, sometimes lavishly. It's not for show because much of it is shielded, hidden away in the works. The user doesn't know it's there. So why is it done? I'm starting to suspect that even engineers, who should know that "quality" is meaningless without a well specified purpose, may have fallen into "the expensive one must be the best" trap. Or is it just that the 'obvious' benefits of silver's low conductivity became 'industry best practice' and no-one's ever challenged it? But surely my paranoid logic can't apply to mobile phones. They're full of precious metals that their buyers don't know or care about... I'm thoroughly confused! Dave By the way, there's general agreement that powder applied silver doesn't help at RF. The silver has to be in a solid layer. The gaps between particles of powdered silver aren't conductive. |
SillyOldDuffer | 27/03/2017 11:42:40 |
10668 forum posts 2415 photos | Posted by Neil Wyatt on 27/03/2017 11:29:10:
May be a silly question, but does the diameter of the rods matter? A 1% increase in diameter will give a 3% increase in surface area, bringinging nearly all the improvement silver would give (assuming Russell's calculation is correct). Neil Not silly at all. Increasing the diameter of the copper rods (or wire in a coil), will increase the Q. As there's always a limit to the physical size of the component and how close it can get to the shield before capacitive and inductive coupling reduces Q, I wonder if the design logic is simply to make the copper as big as will fit and then silver plate it for best results. But as I said, I'm confused! Dave Edited By SillyOldDuffer on 27/03/2017 11:43:18 |
Michael Gilligan | 27/03/2017 14:12:42 |
![]() 23121 forum posts 1360 photos | Posted by SillyOldDuffer on 27/03/2017 11:29:40:
... So why is it done? I'm starting to suspect that even engineers, who should know that "quality" is meaningless without a well specified purpose, may have fallen into "the expensive one must be the best" trap. Or is it just that the 'obvious' benefits of silver's low conductivity became 'industry best practice' and no-one's ever challenged it? . I think that it's because electro-plated Silver is of consistently high purity and quality ... whereas the undelying Copper is almost certainly not super-dooper mono-crystalline stuff. MichaelG. |
Russell Eberhardt | 27/03/2017 20:17:19 |
![]() 2785 forum posts 87 photos | Posted by Neil Wyatt on 27/03/2017 11:29:10:
May be a silly question, but does the diameter of the rods matter? A 1% increase in diameter will give a 3% increase in surface area, bringinging nearly all the improvement silver would give (assuming Russell's calculation is correct). Neil Yes, the diameter of the rod matters but a 1% increase in diameter will only reduce the resistance by 1%. The current is flowing within a thin skin, the skin depth doesn't change with the diameter so the cross sectional area of the conduction region will also change by 1%. The length of the rod remains the same. So the resistance will drop by 1% and the Q will increase by 1%. The box size would also need to be increased to maintain the same characteristic impedance of the resonators. So, scaling the design up by 4% should give the same reduction in passband loss as the silver plating. Russell. |
Steve Withnell | 27/03/2017 21:09:03 |
![]() 858 forum posts 215 photos | Here is the design programme I'm using. Changing the rod diameter does not change the Q, so I'm assuming (!!) that the rod diameter does not make a material change to the overall filter performance, so the maths isn't included in the code. **LINK** Steve PS: I also have the BASIC code for this calculator, but there is a bug I can't find. Any wants a copy let me know! Edited By Steve Withnell on 27/03/2017 21:10:12 |
