Another Mystery Tool
Michael Gilligan22/03/2017 18:04:29
23121 forum posts
1360 photos
This device was sold to me as a 'Stop-Tap Key' ... but I'm sure it is not.
Apologies for the quick & dirty photo, but hopefully it gives the essential information.
I think it is some sort of tensioning device; maybe for fencing-wire or strapping, but would appreciate [some] other suggestions:
... crossbow loader ?
Journeyman22/03/2017 18:14:51
1257 forum posts
264 photos
Looks like the middle out of an old shoe stretcher. The short cross-bar locks into the wooden wedges and the heart shaped metal bit pushes the wooden wedges apart as the handle is turned.
edit: add photo
Edited By Journeyman on 22/03/2017 18:28:52
Michael Gilligan22/03/2017 18:50:40
23121 forum posts
1360 photos
Brilliant ... Thank You
Robbo22/03/2017 19:03:56
1504 forum posts
142 photos
Plus 1 for Journeyman. I've just put a modern version into one of my new shoes. Do we all have one foot longer than t'other?
larry Phelan22/03/2017 19:37:43
544 forum posts
17 photos
I think you are all wrong. There is no doubt in my mind that that item is what is known as a "Wasim"
You may ask "What is a wasim?" Well a Wasim is something that no one knows what its for,but it looks too good to throw out. My place is full of them !
Mike22/03/2017 19:40:13
713 forum posts
6 photos
Can be the result of a stroke. Since mine, I have a size 8 right foot, and a size 9 right. One of these bits of kit might be the answer to my problem!
Michael Gilligan22/03/2017 19:48:37
23121 forum posts
1360 photos
Posted by larry Phelan on 22/03/2017 19:37:43:
... that item is what is known as a "Wasim" ...
smiley
I'll buy that, Larry
... in fact, I did.
Interestingly; it has a square thread; much coarser pitch than any of the shoe-stretchers I have seen. ... It may be very old and/or super quality, or just odd. ... but yes, it's certainly a "Wasim".
Neil Wyatt22/03/2017 20:18:41
19226 forum posts
749 photos
86 articles
The other object is also an interesting one.
When I was in school the label 'Shatter Resistant' was always seen as a challenge
Nick_G22/03/2017 20:20:55
1808 forum posts
744 photos
Don't mean to hijack Michaels thread. blush
But I was at my mates last week and saw this. - I meant to ask him what it was but forgot.
Nick
Michael Gilligan22/03/2017 20:29:11
23121 forum posts
1360 photos
At a guess , Nick ... it's a Barson Hammer Drift
Seriously ... I think it's a drift for extracting Morse Taper tooling: with a built-in slide-hammer.
Nice yes
Edited By Michael Gilligan on 22/03/2017 20:31:31
Nicholas Farr22/03/2017 20:32:27
3988 forum posts
1799 photos
Hi Nick, it's a tray of bits and bobs wink But I think you are referring to the brass thing, which at a guess looks like a brass mallet with the handle missing, perhaps that's what the lump of wood is for, but I'm probably wrong.
Regards Nick.
Michael Gilligan22/03/2017 20:40:58
23121 forum posts
1360 photos
Nick[s],
Just found an earlier thread **LINK**
http://www.model-engineer.co.uk/forums/postings.asp?th=108630
Looks like it's spring-loaded, something like an automatic centre punch.
Edited By Michael Gilligan on 22/03/2017 20:44:47
mechman4822/03/2017 21:53:39
2947 forum posts
468 photos
It's definitely a hammer drift, for releasing Morse taper drills from radial arm drills usually, remember using one of these when I was apprentice.. & later, The brass hammer bit was exactly that, a brass hammer for seating items in the drill vice much as we do with mill vices today, being brass it wouldn't mark the work piece, but also commonly when the sliding hammer action wasn't enough to release the taper you would use a separate drift & give it a 'good welly', especially when the drill was a big one, 1.1/2" +
​George.
David George 122/03/2017 22:49:51
2110 forum posts
565 photos
It is a Barson hammer drift I used them on a radial drill a few years ago, they came in three sizes and you used the brass hammer to knock in the drill to the morse Taper and the weight of the brass slides down to release the drill etc from the spindle.
David
Edited By David George 1 on 22/03/2017 22:50:13
Michael Gilligan22/03/2017 23:50:26
23121 forum posts
1360 photos
George & David
So ... was I correct in my first assumption, that it's just a slide-hammer action ?
The older thread that I linked to mentions a spring dont know
Grateful if you could clarify
mechman4823/03/2017 12:52:46
2947 forum posts
468 photos
The older thread that I linked to mentions a spring...
​Correct... the spring, iirc, was to assist the hammer to return to it's original starting position& to prevent the drift from sticking into the brass hammer... + possibly to ensure the drift did not 'bounce' & was kept in contact with the tang of the drill being ejected.
​George.
Edited By mechman48 on 23/03/2017 12:55:17
Michael Gilligan23/03/2017 13:21:07
23121 forum posts
1360 photos
Thanks, George yes
Muzzer23/03/2017 14:19:10
2904 forum posts
448 photos
I've got one of those Barson drifts. Don't use it very often as a drift, as I don't use MT very often and even then mostly in the tailstock which self-extracts. I use it more as a brass hammer.
The spring always struck me as being rather too stiff. And I always cringe at the thought of the blood blister that would result if you caught your finger between the moving parts....
Mike Poole23/03/2017 14:27:58
3676 forum posts
82 photos
Posted by Robbo on 22/03/2017 19:03:56:
No, I've got one foot shorter than the othersmiley
the artfull-codger23/03/2017 14:36:21
304 forum posts
28 photos
I picked one of those Barston drifts up for a couple of quid 20 odd yrs ago as the end was snapped so I just welded my M T drift that I used to use on it & i've used it on my meddings drill ever since, the best bit is you can hold the chuck with 1 hand & drift it out with the other,previously you hammered the drift with a hammer & ended up with it falling down or dropping the chuck.
