Nut & Bolt Sizes.
Mark Eisen11/03/2017 23:31:56
88 forum posts
68 photos
What are the most common Nut & Bolt sizes in both metric and imperial?
I have been trying to sort out my lifetime collection of Nut & Bolts, about 6 x 4 Lts container full, I keep finding these strange sizes, for me any way, like 9.5 mm, 6.75 mm, etc that will not match up with any of my thread gauges.frown
Willliam Powell11/03/2017 23:45:40
19 forum posts
18 photos
9.5 is just about 3/8 inch if that helps.
Nick_G11/03/2017 23:48:04
1808 forum posts
744 photos
Where do your interests fall.
General 'fixit' metric stuff if fairly straight forward. But go into :-
Motorbikes,
Cycles,
Old British cars,
Modern cars
Model making (British)
Model making (American)
Model making (European, metric but many fine pitches)
Clocks,
Old guns,
New guns,
The above just scratches the surface very, very thinly of the general ones. Then there lots of specialist ones.
............................................... We could go on ..................... There are. Zzzzzzzzzzzzzzzzzzzzz frown
Sorry I know that is of little help to you is it.? But there really is no simple answer. sad
Nick
Mike Poole11/03/2017 23:57:38
3676 forum posts
82 photos
9.5mm is about 3/8" so the tpi will decide if it is Whitworth, BSF, UNF, UNC,ME, brass thread. You will need a selection of thread gauges as whit and unified have 55deg and 60deg thread forms, metric is 60deg but pitch rather than tpi is the relevant measurement. There are many tpi, pitch and diameters that are defined in the standards so almost anything is possible. There are plenty of published charts of the preferred or common sizes but many apparently odd sizes fall within the standards. 6.75 sounds a bit odd but may be 7mm as threads alway measure under their nominal size due to crest rounding and truncation.
Enough!12/03/2017 01:18:59
1719 forum posts
Posted by Mark Eisen on 11/03/2017 23:31:56:
Depends which continent you live on.
Ian S C12/03/2017 10:04:03
7468 forum posts
230 photos
And if you are looking for a specific nut and bolt from your collection, they won't be there, you will find plenty that are too big, too small, wrong head, wrong thread, so you use the bolt for turning down to make something else, and the next time you are looking for a bolt, wouldn't you know it, the one you turned down to make a pin is the exact one you need today. Then again you buy a new nut and bolt, get home and find that you have a dozen of them hidden away.
Ian S C
Clive Foster12/03/2017 10:25:50
3630 forum posts
128 photos
Time to upgrade your sorting strategy.
Start by downloading a copy of the (nearly) all threads in order of size listing originally due to Andy Pugh and further refined by Ian Wright and Micheal Jones.
Text format here :- **LINK** in text format which may need bit of massaging for easy reading. Prettier version of the same data here with a link to an Excel file version **LINK** .
A PDF version arranged to print out on A4 here **LINK**.
Then roughly sort into suitable piles over a range of sizes. Maybe really tiny, up to 1/4 - 6mm, then up to 1/2 - 12 mm and a final pile for bigger ones. Pick over the piles and group out "looks the same" by eye. Now you are ready to start measuring. Set your thread gauges with a suitable selection of leaves pointing out and have at it. Odds are your looks the same sorting will have been good enough that one measurement covers a whole bunch of bolts.
Nuts you have to sort by size over flats then try a fit.
Should be all over by Christmas!
Clive.
Russell Eberhardt12/03/2017 12:16:15
2785 forum posts
87 photos
This page lists some of the more unusual thread standards: **LINK**
The engine of this car I restored used French Automobile Metric threads with Whitworth size hexagons!
Russell.
richardandtracy12/03/2017 15:21:52
943 forum posts
10 photos
In my workshop I try to standardise on M6 & M10 for tooling.
As for what I produce in the workshop.. No standards possible. M12.4x2.4, triple start... That sort of silly thread is needed when trying not to take too much meat out of pen barrels & caps. M7.4x0.55 is a thread moulded in by one of the nib manufacturers into a nib housing. Simply absurd, but have to live with it.
Richard.
Mark Eisen13/03/2017 09:35:01
88 forum posts
68 photos
Thanks for your replies,
At the moment my interests are General 'fixit' with a preference to metric, when I get a bit more practice I want to start making model engines etc.
Ian that is a perfect description, If I need 4 bolts, I will only find 2 nuts and the washers will be either too big or to large.
Very nicely restored car Russell.
John Flack13/03/2017 10:27:48
171 forum posts
Checking on a link, we seemed to be overwhelmed for choice. Generally the choice is made for us by those who make whatever eqpt we use. When a bespoke is desired is there a specific criteria to be observed?. I simply look at what is to hand and think "that seems about right" and proceed from there. Assuming(?) fasteners are made to equal tolerances would a fine thread be preferable or non preferred to a coarse thread for general fastening use? If so why?
Chart sizes indicate that 20BA nuts are possible. Has any living soul ever seen a nut of this size, and where can I get some?
Neil Wyatt13/03/2017 10:37:40
19226 forum posts
749 photos
86 articles
Posted by John Flack on 13/03/2017 10:27:48:
Not without a hand lens...
SillyOldDuffer13/03/2017 10:37:54
10668 forum posts
2415 photos
I got so fed up searching my random collection of nuts and bolts that I 'standardised' on metric and bought a stock of the sizes I use most. It's wonderful: now when I need a nut and bolt I just reach for the right ones. Mostly!
Back in the real world, it's amazing what you have to cope with if you like repairing stuff. Cars I owned in the last century had odd mixes of Metric, UNF, UNC, BA, and some I never identified. It was and is a complete pain in the botty.
Strangely I've only come across Whitworth threads once. Dozens of nuts and bolts (about 3/4" ?) were left lying about after a railway line was dismantled near my school. No details unless Neil insists on a MEW Article but you can make a very satisfying bang with two ex-British Railways bolts, a nut and a certain domestic product.
Harry Wilkes13/03/2017 11:30:20
1613 forum posts
72 photos
John many years ago I was taught that fine treads are stronger than it's course version it was suggested up to 60% stronger but at the same time I was told a fine thread is more prone to seizing. Until metrification BSF & BSW were the more common fasteners on the shop floor with BA used on electrical parts.
H
Gordon W13/03/2017 11:37:18
2011 forum posts
My system, for what it is worth, Is just to put all the bits in the same bucket. For eg, dismantle a computer/ printer, all the bits including nuts and bolts go in a box or bucket. Tractor bits go in another, etc. etc. This may seem a bit rough, and it is, but seems to work well in practice.
Bazyle13/03/2017 11:53:04
6956 forum posts
229 photos
Nice link by Clive to lots of threads but doesn't include Model Engineer threads frown and more surprisingly UNEF (which you might need to know for a camping Gaz cylinder I think)
John Flack13/03/2017 12:03:25
171 forum posts
SOD
Used to do that at school with 1/4 inch items and "caps" my first intro to engineering!!!!!!!
Harry W
That perhaps explains why Mr Prestwich of N 17 used 26 tpi on his products, but why with a reduced hex sized nut??
Andrew Johnston13/03/2017 12:07:01
7061 forum posts
719 photos
Most of my older books have charts where BA sizes go down to 23, with an OD of around 0.3mm. I expect that the smaller sizes are no longer available, but may well have been used in the past for small instruments and watches.
John Flack13/03/2017 14:19:55
171 forum posts
I don't wish to annoy any body on this forum or to be annoyed by its members (I have the medical profession making a very good job of that) my contribution was to ask"what criteria determines the choice between a coarse or fine thread" informing me that you have standardised on M 8 or M 10 leaves me to ask is that fine or coarse thread. If the response is "Coarse of course"? That still leaves open my question WHY? This was a serious ask as many tyros will be using using historical designs where some understanding of retention strength may be critical when seeking alternative fasteners to that specified
I shall now return to usual state of Eunoia
SillyOldDuffer13/03/2017 14:49:21
10668 forum posts
2415 photos
Posted by John Flack on 13/03/2017 14:19:55:
First of all many thanks for 'Eunoia', which is a new one for me.
Let's see if I remember what I read correctly. The gist was:
  • In similar materials, fine threads are stronger than coarse ones.
  • A coarse thread will be stronger than a fine thread only when one material is softer than the other. (e.g. a steel stud in a cast-iron block.)
  • Coarse threaded fasteners are quicker to assemble and disassemble, which is a cost advantage in manufacturing.
  • A fine thread is harder to vibrate loose than a coarse one.
