Guillotine Problems
Andrew Johnston05/03/2017 22:29:05
7061 forum posts
719 photos
Never mind number of posts, the real task today was to try and find out why my guillotine has stopped working. sad
Last time I used it things were fine until the guillotine only clicked when the foot switch was pressed, but the blade didn't move. I suspected the foot switch as the wiring isn't in good condition - the rubber insulation is perished. I've put off looking at it for a week or several but now I really need to use it.
On starting up today the darn thing worked for a couple of cycles and then stopped. So that eliminated the foot switch as being the problem. Next I wondered about the limit switch not working. But, having examined it, it was clear the guillotine was overshooting at the end of the cycle. That turned attention to the electromagnetic brake, which did seem rather easy to turn when it was supposed to be on, the default. So I had a go at adjusting it to be properly on, and give more clearance when off. Still nothing when the foot switch was pressed, just a click. The motor was running with no problem so the only other electrical item was the electromagnetic clutch. In this picture it's the silver coloured disk bottom right, in front of the worm gearbox:
According to the manual it runs on 90VDC, so think brushes. The brushes are held by the green bracket immediately to the left of the silver disk. Sure enough they looked quite worn, and one wasn't making any sort of contact. There are four brushes in two parallel pairs. So even if one brush isn't making contact things should still work. Following the manual I decided to check whether I was getting 90VDC on the clutch. So round to the front of the guillotine and take the cover off the electrics box:
The circuit is pretty crude, basically just a rectifier. It can just be seen bottom right of the box - old school selenium with more fins than Helsinki. Being careful with the measurement, as there is 415VAC floating about, I measured 90VDC on the output to the clutch. And blow me down, the guillotine worked. smile o And continued to work.
All I can think of is that fiddling about with the brushes has made the clutch work again. At least for the time being.
The clutch is made by Warner, who are still in business. According to a supplement in the manual the clutches were PC type, which even more surprisingly are still made. I've found them online and you can order spares in general from the parent company in the US. But minimum value and payment terms are somewhat onerous for overseas orders.
So the question is do Warner have an outlet in the UK? And if so am I likely to be able to get spare brushes for the PC range of clutches? If not I have found a couple of companies that might be worth calling as they claim to be agents.
Peter Krogh05/03/2017 23:42:41
228 forum posts
20 photos
What is that machine? What does it do?
Ignorant yank here....
Pete
Martin W06/03/2017 00:30:08
940 forum posts
30 photos
As soon as I looked at the second picture I thought that's it the selenium rectifier has gone phut ! Then I read further in your account and realised how wrong I was blush . If I remember correctly we used to strip selenium rectifiers apart, heat a plate till the coating melted then wipe the surface to obtain a very rudimentary solar cell/light sensor but that is over half a century ago.
Martin W
Edited By Martin W on 06/03/2017 00:31:03
Nick_G06/03/2017 00:45:34
1808 forum posts
744 photos
Posted by Peter Krogh on 05/03/2017 23:42:41:
Originally used for chopping of naughty peoples heads with. ( as recently in france as 1977 it seems ) But in 'industry' the same principle for slicing metal, paper, leather. etc although with more of a shearing type of cut than for lopping off naughty garlic chewing frogs heads. laugh
Nick
Peter Krogh06/03/2017 01:07:55
228 forum posts
20 photos
Ahhh, what dumb yanky sheet metal workers call a shear...
Thanks!
Pete
Ian Parkin06/03/2017 04:54:44
1174 forum posts
303 photos
I have a quantity of brushes for Warner clutches if you get stuck
Neil Wyatt06/03/2017 08:09:32
19226 forum posts
749 photos
86 articles
Cripes, selenium rectifiers still working!
You would have known if they had gone pop, you woudl have been able to smell it half a mile away.
mgnbuk06/03/2017 08:36:43
1394 forum posts
103 photos
UK agent for Warner Electric clutches & brakes.
Nigel B
Andrew Johnston06/03/2017 15:34:38
7061 forum posts
719 photos
Sorry for jumping straight in without setting the scene. As explained it's a sheet metal cutter. Made by Edwards in the UK, probably in the late 60s. Capacity is 4ft by 1/8" mild steel. Small by industrial standards, but about as big as I could fit in. It's still built like a battleship though; the frame is welded from 3/4" thick steel plate and the flywheel must weigh over 200lbs. Shear is probably a better name, as that is what it does.
Nigel: Thanks very much for the link. Once I've identified the exact type of clutch I'll give them a call. Looking at the information I've downloaded from Warner it looks like my clutch is the smallest, the PC500, going on diameter. But it would be nice to find a label to confirm. There is a label on the brush holder, but it's just a generic manufacturers label with no indication of model number.
Ian: Thanks for the generous offer, I may contact you if the result of contact with Warner is "HOW MUCH?" and a need to sit down.
duncan webster06/03/2017 15:40:27
5307 forum posts
83 photos
Posted by Nick_G on 06/03/2017 00:45:34:
Nick
According to Wikipedia (tat always reliable source of information!) the beheading guillotine was actually first used in Halifax UK
Yet another British invention pinched by those pestilential foreignerswink
Gordon W06/03/2017 16:20:04
2011 forum posts
Supposed to have been invented by a Scotsman and used in Halifax. Must have been cheap. Andrew- if brushes are v. expensive can you not get some larger and file them to fit, are they some exotic material ?
Richard Marks06/03/2017 16:41:19
218 forum posts
8 photos
Posted by Neil Wyatt on 06/03/2017 08:09:32:
Years ago as a TV engineer one would hang a faulty EHT multiplier from the back bumper of the car as the smell of rotten eggs would not be welcome inside, sometimes a car would flash its lights as it passed and lo and behold another TV engineer with the same faulty part, the poor old customer would have the smell hanging around for days.
roy entwistle06/03/2017 16:47:20
1716 forum posts
Duncan. There used to be a replica in Gibbet Street, Halifax, last time I was there ( early 90's )
Roy
Mikelkie06/03/2017 16:52:26
135 forum posts
13 photos
I had the same problem with my Edwards Trucut some time back, replaced the rectifier with a modern
bridge rectifier and a series diode to take care of the back emf.. works perfectly
Andrew Johnston07/03/2017 10:37:06
7061 forum posts
719 photos
Posted by Gordon W on 06/03/2017 16:20:04:
That's plan C, not exotic as far as I'm aware.
Edited By Andrew Johnston on 07/03/2017 10:37:24
larry Phelan02/08/2017 11:27:31
544 forum posts
17 photos
Would love to have one of those machines,no better way to cut sheet steel.
David Standing 102/08/2017 11:56:29
1297 forum posts
50 photos
Posted by larry Phelan on 02/08/2017 11:27:31:
Apart, of course, from laser or water cutting wink 2
Meunier02/08/2017 21:23:18
448 forum posts
8 photos
AndrewJ, am certain I read a thread on here some while ago where somebody asked for obscure brush availability and was recommended a company, South coast way, that would make up brushes to your spec and they indeed came up with the goods - can't find it on initial search but perhaps someone can remember ?
DaveD
John Rudd03/08/2017 19:00:36
1479 forum posts
DaveD,
Is this the company to which you refer?
http://carbonbrush.co.uk
Meunier03/08/2017 19:15:28
448 forum posts
8 photos
Thank you John, that is indeed the one I was thinking of !
DaveD
(now book-marked)
