Stuart Bridger | 04/02/2017 09:37:01 |
566 forum posts 31 photos | The demise of the rubber protective sheet on my Warco VMC has raised a question. Why do we protect the slideways on milling machines with bellows or similar, but we don't do the same on lathes? Is it just that it can be done on a mill, but is not practical a lathe? |
Hopper | 04/02/2017 10:18:56 |
![]() 7881 forum posts 397 photos | I do. A piece of vinyl cut from a worn-out women's handbag attached to the front of the carriage, merely tucked into the back of the felt wiper and metal retainer fitted by myself. It keeps most of the swarf away from the carriage. The felt keeps out the rest. Seen here operating under heavier than usual load, you can see how it works. For more normal sized model engineer type work, the swarf never gets near the ways and is swept off down the back between cuts. I added the metal guard over the leadscrew for the same reason. I run a similar "apron" but only about two inches long, on the back of the carriage and it works well too. I previouslyt tried a pair of small metal trays attached fore and aft of teh carriage, as per an old article by Duplex in ME decades ago, but found the front one needed removing too often because it fouled the four jaw chuck and face plate , and the rear got in the way of the tailstock. Edited By Hopper on 04/02/2017 10:19:43 Edited By Hopper on 04/02/2017 10:27:04 |
Nick_G | 04/02/2017 10:19:24 |
![]() 1808 forum posts 744 photos | . Some people do. I have seen (usually aftermarket) installs of bellows on lathe beds. Some users simply lay paper or cloth along the bed. - When cutting cast iron I usually lay an old shirt on the bed taking care that it is placed in a way that will not make friends with rotating parts.! I would imagine that the main reason they are not installed as standard more often is that they require a longer length and as such even when contracted may restrict the amount of movement on a small lathe. - Think they are quite common on big CNC machines. Nick |
JasonB | 04/02/2017 10:23:09 |
![]() 25215 forum posts 3105 photos 1 articles | And some of us don't cover our mill sildes If I'm doing a large iron casting I may cover the lathe bed with a bit of card or stiff paper but otherwise don't worry about it. |
Joseph Noci 1 | 04/02/2017 10:41:22 |
1323 forum posts 1431 photos | I feel rather sorry for the poor worn-out woman, what with nicking her handbag and all... J |
Hopper | 04/02/2017 10:54:10 |
![]() 7881 forum posts 397 photos | Posted by Joseph Noci 1 on 04/02/2017 10:41:22:
I feel rather sorry for the poor worn-out woman, what with nicking her handbag and all... J I was going to say an old woman's handbag but there is the off chance 'er indoors might be reading over my shoulder. Maybe I was just digging myself in deeper. At least I did not say I had an old bag that keeps the swarf under control for me. |
Chris Evans 6 | 04/02/2017 11:00:02 |
![]() 2156 forum posts | I tend to cover the lathe ways with stiff paper of card when turning cast iron. For general cutting steel just a lot of brushing off is done. I do always cover the ways using my plywood chuck changing board when using emery cloth on the lathe. The Bridgeport mill just gets brushed off in use. |
mark smith 20 | 04/02/2017 11:22:49 |
682 forum posts 337 photos | When the rubber cover on my small warco mini mill fell to bits , i made these up of rubberised kevlar sheet bought off a supplier on ebay ,stitiched on a sewing machine using kevlar thread. Tuff as hell and does the job . |
Journeyman | 04/02/2017 11:23:43 |
![]() 1257 forum posts 264 photos | I use a bit of leftover plastic DPC. Clamped to the carriage with a bit of aluminium extrusion using the travelling steady holes. Keeps the worst of the crud off the bed, easy to sweep / vacuum clean and folds up when it hits the headstock. John |
AJW | 04/02/2017 18:37:04 |
![]() 388 forum posts 137 photos | Likewise, I have a small sheet of rubber trapped under a piece of ally. If I am working the other side of the saddle I will have a piece of newspaper (screw it up and throw away regularly) Keep it clean and oil it regularly! Alan |
john carruthers | 05/02/2017 10:58:52 |
![]() 617 forum posts 180 photos | A bit of ally foil from the kitchen makes a handy temporary muck cover, it doesn't tangle or get wrapped up as easily as cloth. |
Neil Wyatt | 05/02/2017 12:13:30 |
![]() 19226 forum posts 749 photos 86 articles | Posted by mark smith 20 on 04/02/2017 11:22:49:
When the rubber cover on my small warco mini mill fell to bits , i made these up of rubberised kevlar sheet bought off a supplier on ebay ,stitiched on a sewing machine using kevlar thread. Tuff as hell and does the job . That looks like a bullet-proof solution |
dcosta | 05/02/2017 12:42:43 |
496 forum posts 207 photos | Good morning to all. Best regards
Edited By dcosta on 05/02/2017 12:43:13 |
norman valentine | 05/02/2017 15:00:40 |
280 forum posts 40 photos | I use a piece of steel sheet held on with magnets. It does stop me getting too close to the chuck but is quick to remove. |
Adrian Giles | 05/02/2017 15:20:38 |
![]() 70 forum posts 26 photos | I bought a way cover for my lathe from Amadeal, but I can't see it on their site now. Two magnets hold it to the headstock, and two to the saddle, concertina affair, very handy. Apart from the swarf sticking to the magnets!
bricky | 05/02/2017 15:25:12 |
627 forum posts 72 photos | I protect my mill with the silicon baking sheets bought for pence from the supermaket,they fold beautifuly.I attach mine with earth magnets so as to get at an concieled oil nipple and it is easy to remove. Frank |
Dave Barr | 12/10/2020 19:59:09 |
24 forum posts 3 photos | Cheers Norman you have just given me a great idea for material for my machine! Have a spare grey dog bowl mat in silicone gonna try cutting a rectangular sheet out of this. |
HOWARDT | 12/10/2020 20:28:17 |
1081 forum posts 39 photos | Slide way covers prevent swarf getting into larger gaps between moving elements. On grinding machines with small particles these are important and also use wiper seals, which need replacing as they wear to ensure they wipe away the coolant carrying the swarf away as it can get between mating surfaces. On high production machines they help direct the coolant with the swarf into channels to the swarf separator. As a model engineer I don’t bother on either the mill or lathe as the swarf is larger than the machine gaps and no wash coolant is used, most small volume lubricant burns off with the chips. But if fitting way covers makes a person happy then! |
Nigel Graham 2 | 21/10/2020 22:41:19 |
3293 forum posts 112 photos | I note Journeyman's use of d.p.c. as I have some remaining from replacing my workshop windows, and it would probably work very well on the cross-slide of my Harrison L5, where space at the back is a bit too limited for a rigid cover. ' My Myford VMC mill came incomplete with the bellows between the back of the cross-slide and the top of the column. After I had made the garden frog colony happy by building a deluxe pond especially for them, I tried a sheet of left-over butyl pond-liner, not sure how it would withstand oil and folding. It is not in bellows form but works well, seems oil-resistant, though does bulk up a bit at extreme set-ups (sets-up?) and travels, and I have had to remove it once or twice for such tasks. Those are rare though. To hold the top edge I used a piece of thin aluminium angle from B&Q, drilling the resulting ledge with several holes of various sizes to hold the centre-finder, drill-chuck key, screw-driver and such-like. |
