Stuck drill chuck
Curtis Rutter18/01/2017 18:59:18
133 forum posts
14 photos
ive tried fully extending/retracting the tailstock but the chuck won't release from the tailstock of my ML7
Edited By Curtis Rutter on 18/01/2017 19:00:26
Journeyman18/01/2017 19:04:28
1257 forum posts
264 photos
On my old ML7 the tailstock was not self ejecting. You had to use a rod up the hollow tailstock barrel and tap the end of the morse taper shank to knock it out!
Lambton18/01/2017 19:08:10
694 forum posts
Cutis,
The tail stock on an ML7 is not of the "self extracting" type as used on the Super 7.
You will need to carefully knock the chuck out using a suitable soft (aluminium, hard wood or brass) from the rear end.
Eric
Curtis Rutter18/01/2017 19:19:33
133 forum posts
14 photos
Many thanks all!
Ian S C19/01/2017 08:25:29
7468 forum posts
230 photos
My wood lathe has a similar tail stock, and I made up a steel rod with an aluminium tip to knock out the chuck or center.
Ian S C
David Jupp19/01/2017 08:40:42
978 forum posts
26 photos
My lathe doesn't have a through bore on tailstock to allow 'knocking out' - When I use tools without a tang on the end of the Morse taper, I have to find an alternative way to remove from the tailstock. The thick jaws of a small Whitworth spanner I have can be placed around the exposed part of the Morse taper, then I wind the tailstock back in - the taper gets jacked out of the socket. The spanner jaws (or a custom made 'fork' ) has to be smaller across flats than the largest diameter of the taper to remove (say) a hard centre, if there is a larger 'head' attached to the taper, jaw size is less critical.
Edited By David Jupp on 19/01/2017 08:41:11
Edited By David Jupp on 19/01/2017 08:41:42
Ady119/01/2017 09:42:26
6137 forum posts
893 photos
My live centre has a collar on it which goes between the live centre body and the body of the tailstock core/ram.
I have cut this collar so that it lets the centre go in tight, but never too tight to be difficult to remove and it can be tapped out easily after doing a heavy job
Edited By Ady1 on 19/01/2017 09:44:13
John Haine19/01/2017 09:50:13
5563 forum posts
322 photos
A centre that doesn't have a tang usually has a threaded hole for a drawbar - just screw in a short length of studding and it will work. And given that if you do have a tang for self ejecting in an appropriate tailstock, and both the tang and what pushes it will be steel, I don't think one needs to be precious about using a soft bar to eject it.
Clive Hartland19/01/2017 10:27:26
2929 forum posts
41 photos
With the Myford ML10 you definitely need a rod to disengage an arbor from the tail stock, I see no reason why you cannot do the same with a bigger Myford.
Clive Foster19/01/2017 11:04:12
3630 forum posts
128 photos
Posted by John Haine on 19/01/2017 09:50:13:
A centre that doesn't have a tang usually has a threaded hole for a drawbar.
Not always. My rotating centre has a plain bore about 3/8" diameter and 1/2" long in the plain end. I simply loctited a suitable piece of rod in to act as an ejector.
My plain centres have spanner flats on the outer ends of the taper before the centre proper. Presumably these could be used in conjunction with a suitable spanner and spacer as an extraction device on machines with non self ejecting tailstocks. Or you could make up a simple U shaped tool with a lip to drop in the flats. Potentially handy for some of us but what are the flats really intended for?
Clive.
Emgee19/01/2017 11:44:29
2610 forum posts
312 photos
Clive, perhaps because the flats provide clearance for the tool when turning smallish diameters.
Emgee
Clive Foster19/01/2017 13:07:02
3630 forum posts
128 photos
Emgee
Good suggestion but probably not in this case as mine have a full cone centre in front of the flats, not a partial one as in a half centre. That said I have seen similar with what might be called a 3/4 centre where the narrow side of the centre was midway in size between a half and full centre and the wide side ran right out to the full diameter. Extended centre style so the centre proper was on a cylindrical projection. Piece of grinding machine kit I think. Possibly a conversion from a standard extended centre for a special job.
Clive.
Martin Newbold19/01/2017 16:45:42
415 forum posts
240 photos
Are you sure it does not have a bore through the tail stock i have a ML10 tail stock that I converted for my drummond it has a hole all the way through. Perhaps it has an after market tail stock as my other tail stock had one too?
Martin
Enough!19/01/2017 17:30:27
1719 forum posts
I certainly don't. On my ML7 I use a drawbar lightly nipped up to retain the chuck/arbor in use. To remove the chuck I clamp the tailstock to the bed, remove the drawbar, insert a piece of steel bar and whack it. The steel bar has a flat end and the arbor end has a flat annulus of decent area around the drawbar hole. It ain't likely to do any damage (and in fact hasn't done so in 10 years on three drill chucks).
Perko720/01/2017 06:27:02
452 forum posts
35 photos
My old Ideal lathe does not have a hollow tailstock, so if a chuck or live centre gets stuck in the taper the only way to loosen it is to insert a suitable spacer between the body of the tailstock and body of the chuck or live centre and wind back the tailstock until it comes loose. Don't know what i'd to if a dead centre became stuck though.... frown
Ian S C20/01/2017 09:26:34
7468 forum posts
230 photos
Its all right using a wedge to remove a stuck drill chuck IF the chuck is permanently mounted on the taper, a lot of chucks with MT shanks are fitted together with a Jacobs taper, so you take your luck and hope that the MT will lit go before the JT, or you will have found another problem to solve.
Ian S C
Lambton20/01/2017 10:36:14
694 forum posts
I can't see any reason why any solid tailstock cannot be drilled through to allow an ejector rod or drawbar to be used.
old Al20/01/2017 11:05:43
187 forum posts
I see Curtis has not replied to the latest comments. It would be interesting to find out what he did wrong. Getting a 1/2 decent model maker from his local club would sort the problem in seconds. It is likely to be an easy mistake done by a beginner playing with new toys. So much to learn!
187 forum posts
old Al20/01/2017 11:07:11
187 forum posts
As is pressing the buttons on this computer twice!
