Lee Griffiths | 13/01/2017 09:47:46 |
19 forum posts 26 photos | Hi all, I need to make some replacement axle boxes for a MW 14xx kit that I am putting together and improving on the way. The axle boxes are brass as you may know so I want to make some CI ones but finding it difficult to locate 1/2" think CI machines plate or block - I'm being a bit lazy and not wanting to go machining a big chunk of CI down. Is brake disc material suitable CI for axle boxes ? (assuming I can find a solid disc 1/2" or more thick) ? ta Lee |
John Haine | 13/01/2017 09:56:25 |
5563 forum posts 322 photos | Try College Engineering Supply - they can cut slabs down for you to a bit thicker than 1/2" for some machining allowance. Once I got from them an as-cast slab about 3/4 thick, 8 x 4 with bevelled edges, made as test pieces for CI welding. Once through the scale it machined beautifully. I suspect brake discs will be a different grade, made and heat-treated for toughness, might not be easily machinable. |
Hopper | 13/01/2017 10:03:56 |
![]() 7881 forum posts 397 photos | Most brake discs are ventilated and have been for many years. And are usually work hardened at least on the outside faces so my not be ideal. |
Brian Wood | 13/01/2017 10:10:32 |
2742 forum posts 39 photos | John and Lee, Another source of supply is M-Machine that I can recommend from experience.
Michael Gilligan | 13/01/2017 10:22:06 |
![]() 23121 forum posts 1360 photos | Someone [maybe Rik Shaw] mentioned Vauxhall Nova solid brake discs being available very cheaply on ebay. Sorry ... can't find the relevant thread. MichaelG.
Roger Provins 2 | 13/01/2017 10:35:58 |
344 forum posts | Vauxhall Nova solid brake discs - eBay item 301833633434 - £7.34 (inc post) |
not done it yet | 13/01/2017 10:39:10 |
7517 forum posts 20 photos | Brake discs? Go to your local automotive trade supplier. Preferably a supplier with someone who has been there a looong time (rest can only cross reference for registration numbers!). Or try a local heavy goods haulier that employs a mechanic for service/repairs.
Most rear discs are non-ventilated, I would guess. Edited By not done it yet on 13/01/2017 10:40:31 |
Ian S C | 13/01/2017 11:13:10 |
![]() 7468 forum posts 230 photos | I'v used brake disc CI for piston rings, good stuff. If you can get one(or 2 or 3), get an automotive fly wheel, old truck one are good. Ian S C |
Neil Wyatt | 13/01/2017 11:25:34 |
![]() 19226 forum posts 749 photos 86 articles | I bought one of the Nova ones linked above for tramming the mill.
Thor 🇳🇴 | 13/01/2017 11:41:59 |
![]() 1766 forum posts 46 photos | Like several other contributors have said, the brake discs i have used machine very well. I mostly use them as sacrificial plates mounted on my faceplate, drilling and tapping holes where needed. I get them for free from a local garage. Thor |
Lee Griffiths | 13/01/2017 12:19:54 |
19 forum posts 26 photos | That's great guys and nice and cheap too! Solid discs aren't too difficult to find tbh, but I just wanted to hear opinion on the material |
Lee Griffiths | 13/01/2017 12:21:40 |
19 forum posts 26 photos | oh and good thought about the flywheel too, although I think many are steel aren't they ? |
JasonB | 13/01/2017 13:17:14 |
![]() 25215 forum posts 3105 photos 1 articles | Are ther many solid brake discs tthat are 1/2" thick? Could just by a bit of square or rectangular CI bar and slice that up And don't hit it too hard when riviting them to teh frames |
John Flack | 13/01/2017 13:27:02 |
171 forum posts | A source of cast iron is the weights used in gym equipment. Comes in a range of sizes for obvious reasons....jf |
Enough! | 13/01/2017 18:17:58 |
1719 forum posts 1 photos | I tried a cast-iron gym weight to turn a small flywheel but never did succeed in breaking through the skin. |
vintagengineer | 13/01/2017 18:44:15 |
![]() 469 forum posts 6 photos | Be careful with cast iron from cheap sources like gym weights and garden furniture as the contain all sorts of crap. New brake discs are a good source of high quality cast iron. |
Chris Evans 6 | 14/01/2017 10:37:47 |
![]() 2156 forum posts | I keep a few solid brake discs around the place, they make good sacrificial jig plates. Easy to work and very stable. |
Ian S C | 14/01/2017 11:01:18 |
![]() 7468 forum posts 230 photos | The car flywheels that I have are cast iron, older engines ran a bit slower, so a F/W from an older 4 cylinder engine from a truck, or a tractor is a good one to target, you might have to take off the ring gear. Ian S C |
Lee Griffiths | 14/01/2017 11:24:20 |
19 forum posts 26 photos | Thanks all, I ordered a Nova disc yesterday from ebay and it arrived already. Looks to be perfect with a ground finish to 1/2", well 12.6mm so ready to go! I'll update once on the job Lee |
Ed Duffner | 14/01/2017 12:34:47 |
863 forum posts 104 photos | I have previously seen on this forum, recommendations to use sash weights from windows, albeit there is a particular type (or age) to use. Ed. |
