MW | 07/01/2017 13:51:59 |
![]() 2052 forum posts 56 photos | I found an old tap and die with just "WF" written on it, along side the TPi and dia. What does it mean? Thanks Michael W |
Emgee | 07/01/2017 13:54:46 |
2610 forum posts 312 photos | Firm or owner's initials ? Emgee
John Stevenson | 07/01/2017 14:23:50 |
![]() 5068 forum posts 3 photos | Whitworth Form |
Hacksaw | 07/01/2017 14:38:18 |
474 forum posts 202 photos | whitworth fred if it come from London !
I've got a 2" square die with R stamped on it ... A 99 year old guy , who if still alive would be 110 gave it to me Said it was his fathers who worked on the railways... Railway thread ? Edited By Hacksaw on 07/01/2017 14:40:31 |
Brian H | 07/01/2017 15:06:33 |
![]() 2312 forum posts 112 photos | I have a number of taps and dies with WF on them and it stands for Whitworth Fine. Brian |
MW | 07/01/2017 15:49:47 |
![]() 2052 forum posts 56 photos | Thanks, I tried searching for it but nothing came up. Hopefully my forum thread title will come up as a close result on a search engine to help others as well. Michael W Edited By Michael-w on 07/01/2017 15:52:14 |
John Stevenson | 07/01/2017 15:58:13 |
![]() 5068 forum posts 3 photos | It's definitely Whitworth Form.
I have some taps here 2" x 4.5 tpi, clearly marked WF and no way is 4.5 tpi classed as fine thread. |
Ian S C | 08/01/2017 11:34:38 |
![]() 7468 forum posts 230 photos | 2" x 4.5 is BSW, 2 x 7 is BSF, so WF Whiworth Form is my vote. Ian S C |
not done it yet | 08/01/2017 12:04:05 |
7517 forum posts 20 photos | Perhaps the OP might have listed the diameter and pitch at the beginning? Much less obscure discussion and more sensible outcome in fewer guesses (or without any) from the members. I expect JS is correct. |
MW | 08/01/2017 12:13:49 |
![]() 2052 forum posts 56 photos | It's 1/8 x 32tpi I think.. I was satisfied with JS's answer from the start. Whitworth form, makes complete sense. Thanks for the help. |
JA | 08/01/2017 12:46:15 |
![]() 1605 forum posts 83 photos | The term Whitworth form suggests that there was another thread form in general use at the time or earlier. JA |
JasonB | 08/01/2017 13:19:47 |
![]() 25215 forum posts 3105 photos 1 articles | 1/8" whit is usually 40tpi, so may not be a Whit thread but a 55degree thread so could be 1/8 x 32 ME. |
MW | 08/01/2017 14:07:18 |
![]() 2052 forum posts 56 photos | Posted by JasonB on 08/01/2017 13:19:47:
1/8" whit is usually 40tpi, so may not be a Whit thread but a 55degree thread so could be 1/8 x 32 ME. That sounds like I got a lucky find, so does ME have a common form with whitworth? Michael W |
Circlip | 08/01/2017 14:30:51 |
1723 forum posts | Posted by not done it yet on 08/01/2017 12:04:05:
Why make life difficult when with a bit of extra effort you can make it abso bl***y lutely impossible.
Regards Ian.
WhitworF Edited By Circlip on 08/01/2017 14:31:36 |
John Stevenson | 08/01/2017 14:38:11 |
![]() 5068 forum posts 3 photos | Posted by JA on 08/01/2017 12:46:15:
The term Whitworth form suggests that there was another thread form in general use at the time or earlier. JA Oh but there was. Every engineering concern had their own, even to the extent that one nut would only fit one bolt.
Whitworth was the first to standardise the thread system and so anything marked WF denoted it was to a standard. |
Ian S C | 09/01/2017 09:06:09 |
![]() 7468 forum posts 230 photos | The model engineers thread was BSEF/extra fine, there is a parallel to this in USA, the UNEF. Ian S C |
Rick Kirkland 1 | 09/01/2017 10:47:59 |
![]() 175 forum posts | Thank Goodness for the wisdom and accurate knowledge of John Stevenson. As I said in another thread on here there are too many with very little true knowledgeof anything. I sometimes wonder if John gets as angry as I do reading some of the stuff that gets posted. I also know someone who maintains that AF on any spanner next to the size stamping means American Fine. I truly despair. Edited By Rick Kirkland 1 on 09/01/2017 10:48:46 |
Michael Gilligan | 09/01/2017 10:49:14 |
![]() 23121 forum posts 1360 photos | Posted by Michael-w on 08/01/2017 14:07:18: ... so does ME have a common form with whitworth? Michael W . Yes ... or, to put it more correctly: the ME threads are 'Whitworth Form' MichaelG. |
