Gareth T | 22/12/2016 09:27:54 |
![]() 12 forum posts | Hi all, I am in the progress of rebuilding a Colchester Student mk2. I am thinking about bluing some of the metal such as the tool post and other bits, they all had light surface rust and are currently in an oil bath after rust removal and I was thinking of oil bluing some of the parts to give them some rust protection. What are your thoughts for and against doing this please? |
Mike Poole | 22/12/2016 09:36:05 |
![]() 3676 forum posts 82 photos | If it is a Dickson tool post I would be disinclined to heat it again after it has been finish ground. Mike |
Roderick Jenkins | 22/12/2016 09:46:18 |
![]() 2376 forum posts 800 photos | Probably best to bear in mind that oil bluing means heating the item up to temperatures in excess of those used for tempering carbon steel, so if the pieces have been hardened they will soften. You might be better of using a blacking solution such as this. HTH, Rod |
Gareth T | 22/12/2016 09:51:04 |
![]() 12 forum posts | Posted by Roderick Jenkins on 22/12/2016 09:46:18:
Probably best to bear in mind that oil bluing means heating the item up to temperatures in excess of those used for tempering carbon steel, so if the pieces have been hardened they will soften. You might be better of using a blacking solution such as this. HTH, Rod I like the idea of the cold blue a lot better |
Mike | 22/12/2016 10:00:34 |
![]() 713 forum posts 6 photos | You can buy cold blacking and blueing solutions from almost any gun shop. The secret is thorough de-greasing (including finger prints), then follow the instructions to the letter. Experience indicates that most are good on small components (in gun terms, things like trigger guards and top levers) but if used on large areas the finish can be blotchy. |
KWIL | 22/12/2016 10:12:33 |
3681 forum posts 70 photos | You will also find that items subject to handling will eventually loose their "blacking", good for cosmetic use but a lightly oiled item will probably be just as good. |
Chris Evans 6 | 22/12/2016 10:17:04 |
![]() 2156 forum posts | One tool room I worked in specialised in small mainly form ground injection moulds. They would "Black" some items on the tool to give a nice contrast to the ground finishes. A great sales aid from presentation as a few customers thought they where getting special coatings on the tool to enhance tool life. |
Nick Hulme | 22/12/2016 10:55:32 |
750 forum posts 37 photos | Posted by Mike on 22/12/2016 10:00:34:
Experience indicates that most are good on small components (in gun terms, things like trigger guards and top levers) but if used on large areas the finish can be blotchy. The finish is also less durable than the "Hot Caustic" process, it's easy to google Hot Caustic Blacking, I'll not post a recipe here as it's "Scary" for the H&S obsessed and will avoid the usual wailing and moaning
- Nick |
pgk pgk | 22/12/2016 11:55:27 |
2661 forum posts 294 photos | Would it be daft to suggest ordinary stove blacking? Gives a nice clean finish once polished in and easy to re-apply. |
Mike | 22/12/2016 12:01:42 |
![]() 713 forum posts 6 photos | pgk you're ahead of me - I was just Googling for black metal finishes, and came across some stuff called Stovax Colloidal Black. Never tried it, but it reminds me of some stuff called Zeebo my grannie used on her kitchen range. |
pgk pgk | 22/12/2016 12:21:20 |
2661 forum posts 294 photos | I just bought a tube of whatever they had in the local hardware shop.. everyone has wood burners and old stoves in this backwater part of wales |
Roderick Jenkins | 22/12/2016 12:45:27 |
![]() 2376 forum posts 800 photos | Am I not right in thinking that stove blacking is just graphite powder in some sort of carrier? I understand how it works on the porous surface of cast iron but would be surprised if it would stick to ground or machined steel; especially if it is receiving regular handling. Cheers, Rod |
Trevor Drabble | 22/12/2016 13:05:15 |
![]() 339 forum posts 7 photos | Gareth , As an alternative may I suggest you consider a company called BLACK-IT on www.black-it.co.uk and 01758 730356 . I have no connection with the company . Trevor . |
Harry Wilkes | 22/12/2016 13:49:30 |
![]() 1613 forum posts 72 photos | Ok this requires some heat but worth taking a look link Merry Christmas to All H |
Saxalby | 22/12/2016 14:04:38 |
![]() 187 forum posts 33 photos | I have used the cold blacking from www.black-it.co.uk on the bare steel parts of my Boxfords and my tool grinder (ball handles and the like) and while not as durable as hot blacking it is still quite durable. Did mine a couple of years ago and only now are some handles showing signs of the black fading. And it certainly helps to stop rust forming. Surfaces must be TOTALLY degreased for the blacking to work. Regards Barry |
Mike | 22/12/2016 14:21:28 |
![]() 713 forum posts 6 photos | Harry, this looks like oil blacking, which does work on steel. Motor oil doesn't seem to work very well, probably because of its composition these days. I've oil blacked lots of gun screws, and have found cheap supermarket own-brand margarine to be very effective, although it does make the workshop smell like a fire in a chip shop! |
Douglas Johnston | 22/12/2016 14:31:33 |
![]() 814 forum posts 36 photos | Rapeseed oil (cooking oil from the supermarket ) works well for heat blacking, but not a good idea for hardened objects. |
Russell Eberhardt | 22/12/2016 15:08:55 |
![]() 2785 forum posts 87 photos | When at school in about 1960 we were made to rub a few drops of oil into our hands on entering the metalwork shop. I still do that and have very little problem with rust. A thin film of oil on your toolpost should be all that's needed. Russell. |
Emgee | 22/12/2016 15:15:42 |
2610 forum posts 312 photos | Posted by Douglas Johnston on 22/12/2016 14:31:33:
Rapeseed oil (cooking oil from the supermarket ) works well for heat blacking, but not a good idea for hardened objects. .. Douglas, do you mean use rapeseed oil for quenching the heated part ? Emgee |
Bob Rodgerson | 22/12/2016 15:27:28 |
612 forum posts 174 photos | Russel, I rub Barrier Cream into my hands and don't have a rust problem either. |
