Perko7 | 31/10/2016 02:20:03 |
452 forum posts 35 photos | Looking for a bit of advice on keeping the lathe and surrounding areas clean. Usually sweep and vacuum to pick up majority of swarf but there is still a lot of smaller stuff which stays stuck to various surfaces particularly if using cutting lube. I don't want to wash down with solvent/kerosene or other cleaners if possible. Although the lathe has a drip tray underneath it has no drain hole, so any liquid used to clean would need to be mopped up when finished. What do others do? |
Nick_G | 31/10/2016 02:29:55 |
![]() 1808 forum posts 744 photos | . Usually use a cheap paint brush to knock them into the tray. Nick |
I.M. OUTAHERE | 31/10/2016 04:22:53 |
1468 forum posts 3 photos |
I usually avoid using any fluid to clean my lathe i find it tends to wash dirt into places it would not normally get to and the same goes for compressed air - it blows loose swarf everywhere and into places you didn't even know your lathe had ! I wear some leather gardening gloves to bundle the bulk of the long stringy swarf out of the tray and dump it in the bin i then scrape the majority of whatever is left out into a bin ( a home made scraper consisting of a piece of inch wde flat bar about 6 inches long welded or screwed to a piece of 5/16 rod so it forms a T shape works well ) Then i have at it with a vacuum cleaner and use a paint brush to move the stubborn stuff - i find this gets most of what is left off the machine . If there is any oily residue i use cheap paper toweling to mop it up and i usually wipe the ways down also.Occasionally i will give it a wipe over with a rage moistened withe white spirits ( shellite ) or automotive wax and grease remover , i mainly do this after machining cast iron but if i feel the machine is dirty enough it gets a wipe over . If it gets a wipe with shellite or wax and grease remover i then re oil the ways and if the machine is going to sit for a while i wipe on some lanotec to stop rusting . Ian
JasonB | 31/10/2016 07:19:54 |
![]() 25215 forum posts 3105 photos 1 articles | Same as Nick, use an old or cheap new paintbrush to flick the muck off then scoop it up from the drip tray when the layer is too thick. |
John P | 31/10/2016 08:38:28 |
451 forum posts 268 photos | Posted by XD 351 31/10/2016 04:22:53 Chucked out the soluble oil from the cylindrical grinder and gone over to John
steamdave | 31/10/2016 11:00:53 |
526 forum posts 45 photos | A cut down plastic milk carton makes a good dustpan for awkward places. Dave |
Neil Wyatt | 31/10/2016 16:40:49 |
![]() 19226 forum posts 749 photos 86 articles | The brass swarf is almost up to my leadscrew at the moment - I find it does an excellent job of protecting the lathe from dirt Neil |
JasonB | 31/10/2016 16:49:40 |
![]() 25215 forum posts 3105 photos 1 articles | You won't be so pleased with your pile when you drop a small brass part into the ever increasing mound |
I.M. OUTAHERE | 31/10/2016 17:17:04 |
1468 forum posts 3 photos | Posted by John Pace on 31/10/2016 08:38:28:
John, i was alluding to the use of a spray bottle full of kero or the like that i have seen a lathe drowned in , all it did was wash the fine particles into the gibs and into the saddle drive mechanism . Then they took to it with compresed air to dry it off and this just pushed the crud in deeper . Ian.
kevin beevers | 31/10/2016 18:07:55 |
69 forum posts 43 photos | depending on the make of your lathes mine is a boxford and i use a paint roler tray underneath catches most of the swarf so i just brush of into that kevin |
Neil Wyatt | 31/10/2016 19:15:21 |
![]() 19226 forum posts 749 photos 86 articles | Posted by JasonB on 31/10/2016 16:49:40:
You won't be so pleased with your pile when you drop a small brass part into the ever increasing mound I'll fish it out with a magnet ... err ...oh.... I've worked out that making 3mm gears with a small 1mm boss and all gears less than full diameter of the bar and with a 2mm parting tool means >>50% of my beautiful brass is becoming swarf...
I.M. OUTAHERE | 31/10/2016 19:56:24 |
1468 forum posts 3 photos | Neil that is just plain cruel ! I would hate to think what is on the floor ! Ian. |
Alan Waddington 2 | 31/10/2016 20:27:58 |
537 forum posts 88 photos | Well, not nearly as impressive as Neil's slovenly pile, but funnily enough i was making a chuck backplate adapter tonight,and looking at the devastation around me, wondered why my lathe/workspace never looks like the lovely pristine ones i see in pictures and videos on tinterweb forums....... |
not done it yet | 31/10/2016 20:58:28 |
7517 forum posts 20 photos |
Neil's 'slovenly pile' at least has some possible monetary value! A coarse sieve, to fish out the lost pieces, and a magnet to gather up any ferrous waste might leave eough brass there for a good sized casting!
Neil Wyatt | 31/10/2016 21:02:03 |
![]() 19226 forum posts 749 photos 86 articles | Posted by XD 351 on 31/10/2016 19:56:24:
Neil that is just plain cruel ! I would hate to think what is on the floor ! Ian. I will let you know if I find it. If only I can find a way to smelt that back into something usable - must be a few dollar's worth there! Neil |
Robbo | 31/10/2016 22:04:40 |
1504 forum posts 142 photos | Neil, Presumably the dimples in the pile of swarf are from the weeping of the operator? |
Perko7 | 31/10/2016 22:51:52 |
452 forum posts 35 photos | Thanks for the replies. After picking up the bulky stuff i've been using an old paint brush followed by the vacuum cleaner for a final clean, but on the old lathe (1920's vintage) the coarse surface of the cast iron seems to trap a lot of the finer residue. I've been using thread-cutting lube in a pressure-pack can for turning stuff that needs lubricating, so i might try using that as a cleaning spray as well, but it's a bit expensive. Maybe i should strip the lathe down and repaint it so the unmachined surfaces are a bit smoother and less likely to collect grime. Sounds like something i could possibly do over the Christmas holidays Cheers. |
Ian S C | 01/11/2016 10:47:58 |
![]() 7468 forum posts 230 photos | I'm sure that some of the guys who send in photos have two workshops, one where they do all of their work, and another where they photograph the display item. Well maybe not, but the lathe often looks too clean. Ian S C |
Matthew Reed | 01/11/2016 13:09:23 |
41 forum posts | Workshops that are too clean.. it's a bit like seeing a really skinny chef. My two tips.. wrap a dog poo bag round a magnet on a stick, wave it all over, then pull it off straight into the bin. Felt a bit stupid when I failed to notice I was working brass once, but still a cheap alternative to the posh magnet sticks sold for the job. Lidl have an Ash Vacume cleaner in the specials this week for £30. Does a good job on general workshop crud including swarf ( and also does the living room fire, which is obviously why I used the household budget to buy it....) Matthew |
Michael Gilligan | 01/11/2016 13:46:05 |
![]() 23121 forum posts 1360 photos | Posted by Neil Wyatt on 31/10/2016 21:02:03:
- must be a few dollar's worth there! . You would be lucky to get much more than £2 a kilo for it. ... But prices seem to be rising, so it may be worth hoarding. https://www.greengatemetals.co.uk/scrapmetal/Brass.html MichaelG.
