Lignum Vitae
Maurice27/09/2016 19:39:45
469 forum posts
50 photos
I have just saved a piece of lignum vitae, about 6" X 4" X 2", from going into the bin. Now I've got it, what might it be useful for please?
Maurice
Michael Gilligan27/09/2016 19:50:33
23121 forum posts
1360 photos
It would make a couple of nice small mallets
... Or lots of bearings.
Frances IoM27/09/2016 19:51:05
1395 forum posts
30 photos
a classic use for a lump is as head on a mallet for striking wood chisels.
densleigh27/09/2016 19:53:28
16 forum posts
Hi Maurice,
As you probably know it is one of the hardest and heaviest of woods to try and do anything with.
It sinks in water and not many woods do that!
If it is still green and not a really old piece you might be able cut it with a decent Tungsten blade,in a circular saw bench, it stalled a 2hp machine when I tried however if it is a seasoned piece it will be very difficult to cut it.
 it might turn ok but again its hard. I used to send bowls woods away to be remodelled, and if there was the smallest crack in them they (Thomas Taylors) would refuse to do anything to it.
It would make nice plinth for a model perhaps or if you can turn it a small ornament.
Or alternatively put on the Bay and let someone else hassle with it.
Finally if you do decide to put it on the fire (I know) it does not burn very well - coal burns quicker! It just smoulders.
Good luck!
Edited By densleigh on 27/09/2016 19:54:33
Roderick Jenkins27/09/2016 19:56:57
2376 forum posts
800 photos
Traditionally used for the bearings for ship propeller shafts. I bought a square from a turnery supplier once 'cos I thought it might come in useful. The only thing I've used it for so far is to make some new guides for my old B&D bandsaw.
Cheers,
Rod
Mick Henshall27/09/2016 20:46:16
562 forum posts
34 photos
Rods right, it's self lubricating in sea water
Mick
Maurice27/09/2016 20:48:10
469 forum posts
50 photos
Thanks for the replies gents, looks like I rescued a door stop!
Maurice
Ady127/09/2016 21:02:15
6137 forum posts
893 photos
Amazingly useful and tough, it's like a very hard plastic. You don't hear about it much now because of ecological reasons and there are other materials which can do the same job.
A bit about it here
IanT27/09/2016 21:32:57
2147 forum posts
222 photos
Hardwood and Ivory Turners ("Bone Grubbers" ) would probably have made a chuck with it Maurice - although they mostly used boxwood chucks, probably on the grounds of cost.
Tubal Cain (when describing Ornamental turning methods) suggested it could be used for chucks (and also small faceplates) on account of its stability. He also says that it "turns very well indeed and will accept deep cut decoration" - so I'd guess it would be valued by any ornamental turner as a workable 'material' in its own right.
By the way - anyone who wants to know about traditional hardwood and ivory turning (bone grubbers) should read Bill Jones' books on the subject. I'm not a wood or ornamental turner myself but I found them a fascinating and useful read. Bill was a professional turner and craftsman, following in his fathers footsteps. He was also an early member of The Society of Ornamental Turners, so possibly knew Tubal Cain (TD Walshaw) too. I think the books are based on Bills articles on turning published in 'Woodturning' over many years.
Bill Jones - Notes from the Turning Shop (and Further Notes from the Turning Shop) - ISBN 1-86108-017-4 (& ISBN 1-86108-036-0)
Sorry - drifting off topic I know - and a bit away from the metal torture I normally entertain myself with but if you can find a copy of either books (published 1996/1997) they are a very entertaining read.
IanT
Edited By IanT on 27/09/2016 21:33:21
Frances IoM27/09/2016 22:02:49
1395 forum posts
30 photos
if you haven't a wood lathe and don't think you will use it then maybe give it to a wood turner to make 2 small mallets (always useful - even in kitchen) - one each though you need to pay for a good handle to give good 'bounce' - one of the first things I made with my wood turning lathe.
Bob Murray27/09/2016 22:48:28
24 forum posts
Makes excellent tool handles (think Purdey turnscrews) and is easily cut with a fretsaw. Metalworking tools and techniques work better than woodworking until it's time to sand and finish.
Bob
Hopper28/09/2016 00:39:56
7881 forum posts
397 photos
It's still used for stern tube bearings in certain submarines. Sea water lubricated and quieter than metal bearings.
So you might have yourself the start of an underwater modelling project.
richardandtracy28/09/2016 12:15:30
943 forum posts
10 photos
It will take a thread.
Some quite nice pens have been made with it. A block could be cut up into quite a few pen size rods.
For ornamental turning it is supposed to be one of the best woods you can find. Take a look at TD Walshaw (Tubal Cain)'s book here **LINK**
Richard
Neil Wyatt28/09/2016 12:32:08
19226 forum posts
749 photos
86 articles
TC took a long piece and drilled a series of holes in it, then cut a split in it almost to the end. It could then be held in a vice and used as a 'non-marking jaw' for small round parts.
mrbuilder28/09/2016 12:44:22
71 forum posts
15 photos
Interesting timber. Have also seen it used in woodwinds as an alternative to African Blackwood and ebony.
Martin Kyte28/09/2016 13:44:09
3445 forum posts
62 photos
Harrison Clocks
Ian S C29/09/2016 12:16:47
7468 forum posts
230 photos
A friend was given a set of Lignum Vetae lawn bowls, I think most of them were cut in quarters, then converted into salt and pepper sets. Although a wood turner, he had difficulty handling the wood using carbon steel lathe tools, take a slice, sharpen tool, he ended up getting some HSS lathe tools.
Ian S C
