Strange metal
Neil Wyatt10/09/2016 18:55:30
19226 forum posts
749 photos
86 articles
I made a little version of a traditional tool today, something that appears to have barely changed, if at all, since the mid 19th century or earlier, except it is now factory made rather than blacksmithed.
I 'blacksmithed' mine as I wanted the same coarse appearance as a Victorian one.
The metal I used was rather odd. It was heavy as steel and had a few (apparently) rust flecks, but looked slightly greyish. It was magnetic, jumping off my hand when I waved a small speaker magnet over it. it could have been stainless but it was as bendable as mild steel, easy to bend and re-bend and showed no work hardening even when beaten with an 'ammer, yet when hit with the hammer it took a lot of bashing to create flats on it. I was able to drill it 1/16" where it had been flattened with no sign of work hardening. I tried oil-blacking it and instead it went grey-green. One or two spots picked up some silver solder and flux off the bit of tile I heated it on, very unlike stainless.
All in all i suppose it is stainless steel but it really doesn't behave much like one. It can't be a very hard aluminium alloy as it is so magnetic.
Any ideas?
Peter Krogh10/09/2016 19:03:16
228 forum posts
20 photos
That sounds like old wrought iron. Pure iron with fine carbon that is mechanically included, not in chemical solution. I hard to find the stuff anymore! If you acid etch the rod, fairly heavily, and it shows a linear structure like lots of wires bundled, then you've got wrought iron.
Pete
Vic10/09/2016 19:19:22
3453 forum posts
23 photos
A spark test may indicate what it is. Sounds like it may be some kind of 400 series stainless.
"400-series sparks are similar to 300-series sparks, but are slightly longer and have forks at the ends of the sparks"
https://en.m.wikipedia.org/wiki/Spark_testing
Edited By Vic on 10/09/2016 19:23:02
John Stevenson10/09/2016 19:45:07
5068 forum posts
unobtainium or scrapbinium at a guess.
Bazyle10/09/2016 20:49:35
6956 forum posts
229 photos
Perhaps nickel or a high nickel no chrome stainless as used for cutlery.
Rik Shaw10/09/2016 21:18:09
1494 forum posts
403 photos
Put us out of our misery Neil - what does your little tool do?
Rik
Roderick Jenkins10/09/2016 22:52:54
2376 forum posts
800 photos
Monel perhaps?
Speedy Builder511/09/2016 07:06:07
2878 forum posts
248 photos
Monel:-
"Cold working can increase the magnetic properties while solution annealling can render the item non magnetic until it is cold worked again."
not done it yet11/09/2016 08:14:15
7517 forum posts
20 photos
RJ may well be onthe right track. Green colour flagged it up for me as possibly a copper alloy.
According to goggle it should work harden - and its magnetic properties are interesting. Reaction with nitric acid is used to identify, or discern from
 stainless steel or steel.
Edited By not done it yet on 11/09/2016 08:15:30
Gordon W11/09/2016 09:18:25
2011 forum posts
Grinder test-- dullish red = wrought iron.
Neil Wyatt11/09/2016 09:55:06
19226 forum posts
749 photos
86 articles
Spark test is either wrought iron or stainless, a single long-thin 'leaf' from each spark. If there's any final fork (400 series) it's barely there.
But not wrought iron, it would black and show colours when heated.
It must be a stainless, but one that is remarkably easy to work.
As for the mystery tool, come to MEX and see it at work
MW11/09/2016 09:59:19
2052 forum posts
56 photos
Inconel or Nimonic?
Michael W
MW11/09/2016 10:17:37
2052 forum posts
56 photos
Posted by John Stevenson on 10/09/2016 19:45:07:
I take it those ores are not very nice to work with? I can't seem to find unobtainium anywhere. Scrapbinium always get a poor surface finish and odd sizes. I prefer machining sponge, as it is the only material that can be both round and square with a bit of heft. wink 2
Michael W
Neil Wyatt11/09/2016 11:19:15
19226 forum posts
749 photos
86 articles
You know what i think this is?
It looks just like Meccano axle, but 3/32" instead of 5/32". Which probably means it is a cheap stainless.
Geoff Theasby11/09/2016 11:30:27
615 forum posts
21 photos
Have you checked it for radioactivity?
Geoff
duncan webster11/09/2016 14:04:18
5307 forum posts
83 photos
Posted by Michael Walters on 11/09/2016 10:17:37:
Michael W
You should try quantonium, that can be round and square (or neither) at the same time
Raymond Anderson11/09/2016 15:32:14
785 forum posts
152 photos
If it is remarkably easy to work as Neil says then, it's certainly not Inconel or Nimonic. They are a lot of things but "easy " isn't one of them.smiley. I don't even know of a Stainless steel that is "remarkably easy to work " not even 303. Maybe even just a rubbish alloy used for parts of a toy. Don't suppose you will ever know for sure, need a lab for that.
SillyOldDuffer11/09/2016 17:02:46
10668 forum posts
2415 photos
Could it be a Maraging Steel, as used to make ultra-centrifuges and golf clubs?
No doubt Neil would think of an ultra-centrifuge as being a "Traditional Tool". They were much used in the past to make ye olde enriched Uranium.
mark costello 111/09/2016 17:46:26
800 forum posts
16 photos
North Korea for a source?
Vic11/09/2016 18:30:24
3453 forum posts
23 photos
Maraging steel was also used in the grabs that failed during the partial raising of the Russian Submarine K-129 in the 1970's.
