DMB | 24/06/2016 09:46:04 |
1585 forum posts 1 photos | Given todays news, presumably the requirement for a CE mark is now redundant on any goods sold in the UK? Including boilers? |
Bazyle | 24/06/2016 09:52:01 |
![]() 6956 forum posts 229 photos | Never wish for a regulation to go away. It will inevitably be replaced with something more onerous, more restrictive, and more asinine as the pen pushers in charge want to show how important they are. |
John Rudd | 24/06/2016 10:19:21 |
1479 forum posts 1 photos | Ok, So we are leaving the EU, as the op stated, the CE mark may/will no longer be required but ought to be replaced.... What was in place prior to us joining? If it was good enough then, surely its good enough moving forward? (British Standards perhaps? ) |
Simon Collier | 24/06/2016 10:32:47 |
![]() 525 forum posts 65 photos | I read my July EIM today. There was a very interesting add about why model engineers should vote to leave. It concentrated on the EU rules for boilers and the switch to more expensive, poorer performing 55% silver solder. I was surprised and delighted to see it. I doubt Neil would have allowed it in MEW. |
duncan webster | 24/06/2016 10:34:41 |
5307 forum posts 83 photos | Any pressure vessel built to British Standards would have no problem being CE marked, and any competent company would have no difficulty complying. If you doubt this go and read the European Pressure Systems Directive. Do not imagine for one second that the HSE or insurers will allow commercially produced pressure vessels to be used without proof of good design/construction. Something else will be brought in, and it will probably be more onerous |
MW | 24/06/2016 10:37:54 |
![]() 2052 forum posts 56 photos | I think it will stay or have atleast a british replacement, we wont see that for many years but maybe someday. The mark is good for trade so many will keep it even if they aren't obliged to use it. The B.S.I is and was an excellent institution that pretty much provided the the entire basis on standards we should be proud of. It wasn't in the pockets of cronyism like alot of other countries standards were, simply bent to their own purposes and obeyed/ignored at will. Our system stands alot more to reason and fact to protect the quality of the actual product and therefore it's users also. Alot of the I.S.Os seem like a carbon copy of the old BSI standards. But, all the more reason to be proud of just how good a system it was. Michael W Edited By Michael Walters on 24/06/2016 10:40:22 |
Circlip | 24/06/2016 10:41:49 |
1723 forum posts | Hopefully a return to the superior leaded soft solders for electronics, but don't forget, where money is the prime consideration, the social do gooders will retain the most lucrative rules.
Regards Ian. |
MW | 24/06/2016 10:54:18 |
![]() 2052 forum posts 56 photos | Posted by Circlip on 24/06/2016 10:41:49:
Regards Ian. I'm a little confused by what you mean by better. Perhaps leaded soft solder provides a superior bond but i haven't found it flows better, if anything the cored solder i've found to be the easiest to use, i think theres mainly tin in that. MIchael W |
Circlip | 24/06/2016 10:58:31 |
1723 forum posts | Unless it's changed, "Ersin multi core" was 60/40 tin lead in general use. How many of the far easts manufactory of products lie dormant due to brittle joints?
Regards Ian. |
Muzzer | 24/06/2016 11:08:56 |
![]() 2904 forum posts 448 photos | If you actually dealt with the regulations rather than read about them on the front page of a comic, you'd know that CE marking simply declares that you have met all the applicable safety standards that apply within all the countries in Europe. This is actually a Good Thing: Whether you talking about US, Canada, EU, Scandinavia, Korea, Japan, Australia or wherever, you are legally obliged to obtain any applicable safety certification before you may sell your products in that country. I know, because I've spent the last 30 years doing just that. Before the CE mark, it was necessary to get products approved in each of the EU member countries you wanted to sell in (UK, Germany etc etc ....). Now, one mark does it all (within EU) and the standards within Europe have been "harmonised" to cut down on the regulatory work. Doesn't play well with the EU bashers though, who like to present it as the exact opposite. Of course, you still need to have your products approved for all the other markets that aren't harmonised. It's expensive and time consuming and is far from just a formality, as you often have to make late changes to the product to comply. Unless we plan to completely stop selling products to Europe, we will still need to CE mark.And even if we get rid of the CE mark within the UK, any standards that replace it will be almost indistinguishable. Over the years, harmonisation has been a global process so that the requirements for the N American and European markets have converged. It's sensible really, as the requirements are based on decades of knowledge and experience, often based on actual death and injury.So for instance, the global generic electrical safety standard is arguably EN 60950 / BS EN 60950 / UL60950 / CSA 22 etc etc. Call it what you will but it's all based on IEC 60950 which has much of its roots in our old BS stds. The IEC that sets these standards was originally formed in the UK to coordinate international safety standards. Nothing to do with the EU, I'm afraid. Murray |
David lawrence 3 | 24/06/2016 11:09:19 |
51 forum posts | I used to repair a lot of European and uk made photographic gear as a living, all the Europe stuff was very well made, passed all the ce checks etc, the Chinese gear that started to come into the uk 6 years or so was cheap, poorly made, had no earth, wrong mains lead colours, all had CE stamped on the case, no chance of passing anything but we let it in the country. perhaps now we stop this rubbish coming in. The CE stamp made lots of UK companies spend lots of money to get approval, China bought a rubber stamp. |
Nick_G | 24/06/2016 11:11:20 |
![]() 1808 forum posts 744 photos | Posted by Michael Walters on 24/06/2016 10:54:18:
MIchael W . How long do you think cored solder has been around.? - It's certainly not a new product that was brought out to meet new regulations. I recall using it as a young lad in the early 70's. No doubt someone more senior to me will tell us when it was first introduced.
Nick |
Roderick Jenkins | 24/06/2016 11:11:47 |
![]() 2376 forum posts 800 photos | Europe hasn't gone away Solder is a case in point - I don't suppose manufacturers are going to run 2 different production lines with differing solders. Anyway, traditional Ersin 60/40 resin cored lead solder is readily available in my local DIY shop for use in the home workshop. Rod Edited By Roderick Jenkins on 24/06/2016 11:13:52 |
MW | 24/06/2016 11:24:11 |
![]() 2052 forum posts 56 photos | Posted by Nick_G on 24/06/2016 11:11:20:
Nick I just was confused thats all, i have a reel of 60/40 pure tin/lead and it doesn't flow readily and presumably the better stuff i was referring to was just the roisin cored equivilent. Michael W |
Jon Gibbs | 24/06/2016 11:44:29 |
750 forum posts | +1 for Muzzer's comments. Jon |
Martin Kyte | 24/06/2016 12:08:22 |
![]() 3445 forum posts 62 photos | The reason for moving to lead free solder for electronics was and is to reduce the heavy metal leaching into the ground water around landfill. This became a problem with the high increase in dumping of consumer electronics. Lead in the environment is also the reason we are all driving on unleaded petrol. It's cleaner all round. There is no ban on selling 60/40 leaded solder only restrictions on sale/disposal of electronics built with it. We (our workshop) generally does not use lead free because we don't build stuff to sell and we operate by hand soldering assembly processes. The vast majority of joints in electronics are automated and lead free does not pose problems. regards Martin |
Ian S C | 24/06/2016 12:12:07 |
![]() 7468 forum posts 230 photos | Rosen cored solder has been around for quite a while, it was first patented in USA in 1929. It is not mentioned in my oldest ARRL Radio Amateur's Handbook, but in my copy of the RSGB The Amateur Radio Handbook 2nd ed 8th printing 1943 (1st print 1940) it is mentioned, and recommended, and I know that dad used it before the war when he worked after school repairing radios for a radio sales company in Dunedin (NZ). Ian S C Edited By Ian S C on 24/06/2016 12:14:54 |
Neil Wyatt | 24/06/2016 12:51:01 |
![]() 19226 forum posts 749 photos 86 articles | I just cut a strip off a small circuit board ... then realised I was probably breathing in lead dust This is interesting: www.quantumalloys.com/data/electronic/erzin.html Neil |
not done it yet | 24/06/2016 12:54:55 |
7517 forum posts 20 photos | The big joke is often that CE marks on chinese products simply stand for 'China Export' and nothing to do with european safety standards. Sure, there are good Chinese products, but there are also some really dodgy items which still need to be weeded out on arrival for sale.
The fact that the (genuine) EC marked products are up to, and often beyond, the old BSI kitemak system is to be lauded. |
Ajohnw | 24/06/2016 13:08:58 |
3631 forum posts 160 photos | Posted by Roderick Jenkins on 24/06/2016 11:11:47:
Europe hasn't gone away Solder is a case in point - I don't suppose manufacturers are going to run 2 different production lines with differing solders. Anyway, traditional Ersin 60/40 resin cored lead solder is readily available in my local DIY shop for use in the home workshop. Rod Edited By Roderick Jenkins on 24/06/2016 11:13:52 Nice and precise Rod. The same thing will apply to just about everything we might buy. In order to sell into the EU what ever standards they choose to have will still apply to all goods that are sold there. In the past this area has been used for protectionism and there may even be a growth in that now. John - |
This thread is closed.
