SX2 PLUS MILL
BOB BLACKSHAW09/02/2016 00:01:20
501 forum posts
132 photos
Hello
Before I start drilling and tapping on my SX2 P mill has anybody put stops on the table for the X and Y, I would of thought that stops would of been a essential part of this small mill. I am generally happy with the mill but before I do any modification on it my idea of stops may not be the best solution.
Thanks for any replies, Bob.
Paul Lousick09/02/2016 01:05:58
2276 forum posts
801 photos
Hi Bob,
I have an SX3 and it does not have physical stops. The X-axis power feed does have limit switches which can be moved to different locations. Have also fitted a DRO and use it to accurately control the travel.
Paul
Russell Eberhardt09/02/2016 10:33:57
2785 forum posts
87 photos
This article shows how it was done on an X1 mill. The X2 table arrangement is similar.
Russell.
BOB BLACKSHAW09/02/2016 15:37:29
501 forum posts
132 photos
Thanks for these ideas, the article given by Russell is of help and looks a simple solution which I shall adopt. A DRO will be the next step on my mill and lathe in the near future.
Bob.
Frances IoM09/02/2016 16:07:25
1395 forum posts
30 photos
I drilled supports for stops based on Mike Cox's scheme on my SX1 table but then decided that DRO was a much better scheme and haven't missed such stops since installing the relatively cheap DRO from ArcEuro - would be worth considering such future DRO in future when drilling the table even if you decide to use the stops pro tem - the real annoyance is that buried gib based screw that locks the Y axis - might also be worthwhile fettling the gibs at same time as even on a new SX1 table one of gib strips was banana shaped (see earlier discussion) - with good gib strips should only need hand tightening of less than half a turn but banana shaped gibs nake adjustment + travel a pain
Neil Wyatt09/02/2016 18:12:33
19226 forum posts
749 photos
86 articles
Posted by Frances IoM on 09/02/2016 16:07:25:
You have just given me an inspired idea - adapt a telescope 'handle on a cable' to fit a the gib locking screw!
No more scraped knuckles!
Chris Evans 609/02/2016 18:22:14
2156 forum posts
I use table stops regularly on my Bridgeport mill. They are a boon for milling slots and roughing out to a position, saves all that watching dials or read outs.
Vic09/02/2016 20:11:15
3453 forum posts
23 photos
Posted by Chris Evans 6 on 09/02/2016 18:22:14:
Agreed, I use the table stops quite a bit on my VMC as well.
BOB BLACKSHAW27/02/2016 20:51:58
501 forum posts
132 photos
If fitting a DRO on the SX2 plus, I have noticed on You Tube that a lot of these are fitted on the back of the table, another had fitted on the front. Both ideas have drawbacks, on the back limited on the axis as the DRO will hit the back, on the front you can not adjust the gibs or lock the table. Has anyone fitted a DRO to a SX2 and give advise on the best way of doing it. As past posts I have made all the parts for the stops this week so at the moment one part of me wants to put stops on and the other to buy the DRO.
Neil Wyatt27/02/2016 21:12:35
19226 forum posts
749 photos
86 articles
I have a scale on the back of the table on my X2 (not SX2) fitted under some 25 x25mm angle fitted flush with the table.
With the table wound right back it is still well away from hitting the column
Check the clearance between back of the table table and column on the SX2, I'm sure it will be more than 30-40mm.
BOB BLACKSHAW28/02/2016 01:59:39
501 forum posts
132 photos
Thanks for the information Neil, looks now I can do both. Certainly a must have is DRO as I am finding converting fraction to decimal then forgeting if divide 25.4 or multiply 25.4 to metric then either .025 for Z axis or .020 for X and Y then turning the handle the correct way rather confusing.
Bob
Dennis D28/02/2016 07:25:38
84 forum posts
Check this out **LINK**
Neil Wyatt28/02/2016 09:38:29
19226 forum posts
749 photos
86 articles
Ah, the SX2P clearly has much less room!
Zebethyal29/02/2016 17:14:46
198 forum posts
I never bothered with any stops on my X2 Mill, but wanted a cheap DRO to get me by until I convert it to CNC.
I added some Igaging scales to each axis (about £80.00 inc P&P), then made an interface board Link for under £5.00 to allow me to use Yuriy's DRO app Link on a cheap (£43.00 inc P&P) 10" Android tablet.
Similar conversions are shown on the link provided by Den24171 and other links from that thread.
fizzy29/02/2016 19:23:43
1860 forum posts
121 photos
you can buy decimal or fraction dials, about 4 pounds each - i now have both. I had the dro on the front but you have to adjust the gibs quite often so i ended up taking it off in the end.
Neil Wyatt29/02/2016 20:02:55
19226 forum posts
749 photos
86 articles
I keep meaning to replace the 75-graduation dials on my X2 with 60-graduation ones.
