Here is a list of all the postings Dennis D has made in our forums. Click on a thread name to jump to the thread.
Thread: Harrogate Model Engineering Exhibition |
13/03/2023 08:04:27 |
Came across this youtube upload this morning Harrogate looks to be more models on show than the last Ali Pally one I went to. |
Thread: Bridge load calculations (for the inept) |
21/07/2022 10:57:41 |
How deep is the stream gully and does it carry a flow at any time. I've seen a few youtube videos where landowners have laid large diameter pipe in the flow then covered it with rubble to make a road |
Thread: FORUM DOWNTIME AND RESULTING ISSUES REPORTING |
15/07/2022 19:07:58 |
Eugene You should have had an email with your new ID. Check your spam folder thats where I found mine. It will be from Classic Magazines |
Thread: Is there a special tool for this? |
02/07/2022 16:13:24 |
I think what you need is an E5 security bit if you Google it you should get some hits. Tried to paste the link but for some reason it didn't work, could be the change over or the fact I'm using a android tablet |
Thread: Advice sought on buying a nature watch camera for my garden |
24/06/2022 06:58:53 |
Greensands One way of conserving battery life is to use the timer function so that the camera only becomes active during that period. Use of good quality batteries also helps. Mine uses 8 at a time so Duracell work out expensive but supermarket own brand are OK. Length of video recording is also something that will drain but 30 sec is long enough. IR light is another drain but most often you can set a delay between recording so you don't get 5 minutes of your cat chasing moths. |
23/06/2022 18:15:18 |
I have a Campark T85 model. Mine has wifi and Bluetooth so that with an app on your phone you can see exactly where the camera is looking. Being battery powered means can move it around your garden to find entry and exit points. |
12/06/2022 06:35:22 |
Logged me out overnight. Samsung Galaxy Tab A Android 10 |
11/06/2022 15:19:26 |
Keeps logging me out today, was on all day yesterday no problems. Login time seems long but probably only 15-30 seconds. No access to digital copies displays 404 - File or directory not found. |
Thread: model engineers work shop |
24/04/2022 18:43:30 |
Not showing on mine either so thought I would view it via the magazine tab but it only displays up to issue 312 (Feb). Didn't know the issues were missing as always use pocket mag to view as the display is better. |
Thread: HOW FAST - ANEMOMETER CALIBRATION ? |
18/02/2022 13:29:33 |
As Martin suggested but use the GPS spèed reading on one of the mapping apps such as Google maps or waze available on most smartphone. You may need to find a long bit of road where you can stay at a constant speed |
Thread: Controlled release of a Clarke Bottle Jack fitted to an engine building stand |
06/01/2022 12:54:14 |
As an alternative have you thought about a 12v electric scissor jack where you have button control of lowering speed. Search youtube and you can see them in operation most were rated at 3 tonnes. You could supply power from a laptop charger or a spare 12v battery. |
Thread: Little nuts.......big fingers. |
29/03/2021 13:04:34 |
Search for Jewlers prong pick up tool The one in my picture is holding a 10BA nut. They come in different number of prongs as well if I remember correctly Edited By Dennis D on 29/03/2021 13:11:14 Edited By Dennis D on 29/03/2021 13:12:29 |
Thread: Medical needles |
24/10/2020 13:13:17 |
You can get flat-tipped needles off eBay. They are generally sold for refilling ink cartridges. |
Thread: WM16 or SX2 |
19/09/2020 10:46:24 |
Whatever machine you decide on think about adding a DRO system to help with the positioning of the drilled holes. There are plenty of budget systems on the market and have been covered in threads on this forum. |
Thread: Today's delivery |
29/07/2020 12:56:38 |
I worked at a car dealership in the parts dept and spoke to the Wurth rep about why they sent small items in big boxes. He told me that it was cheaper doing it this way than taking the cost hit resending out the small item in a packet that had been lost in the back of the courier van, |
Thread: How to stop scam phone calls for good? |
21/07/2020 14:48:31 |
In the past I have used TPS **LINK** This blocked a lot of cold calls based in the UK but the foreign based ones sometimes slipped through. Your phone provider may have something to sign up with. I am with Sky and they have a screening service called Talk Shield which allows you to block numbers you don't want. |
Thread: Cigarette Papers |
13/07/2020 12:37:11 |
I served my apprenticeship at a company called Molins who made cigarette manufacturing machines and in all the workshops there would be a reel of cigarette paper to aid with setting up and we always used to work on 1 thou. Off-topic the same company during the war made the Molins 6 pounder gun fitted to the Mosquito fighter bomber
Edited By Dennis D on 13/07/2020 12:38:02 |
Thread: wiring |
15/06/2020 15:43:28 |
I have an sx2p from Arc and copied the build in this video from Andrew Whale using an Arduino board **LINK** There are 2 videos that cover the process |
Thread: Cross slide dial calibrations - opinions sought. |
15/05/2020 08:31:17 |
+1 for Pauls suggestion. I use a modified digital tyre depth gauge on my cross slide, Search Poor Mans DRO for plenty of different types. Just spotted Stuarts post further down the page https://www.model-engineer.co.uk/forums/postings.asp?th=162256&p=1 Edited By Dennis D on 15/05/2020 08:36:49 |
Thread: Yuriy's Toys DIY DRO |
27/04/2020 11:05:04 |
I built one the same as Stuart if you go to Yuriys site he has detailed instructions for wiring dro-build-instructions just scroll down to see the breakout board wiring and he has a YouTube video of final set up calibration |
