Anybody seen this one before ?
Brian John | 09/11/2015 17:35:40 |
1487 forum posts 582 photos | I have just discovered this small lathe on ebay. I have not seen it before. I have no intention of buying one but it may be of interest to somebody. The base looks like it might be a piece of steel rail from a railway track. Edited By Brian John on 09/11/2015 17:37:25 |
JasonB | 09/11/2015 17:43:45 |
![]() 25215 forum posts 3105 photos 1 articles | Now that does make yours look like a "Premium" lathe |
David Clark 1 | 09/11/2015 17:51:54 |
![]() 3357 forum posts 112 photos 10 articles | It might be of interest to a scrap man. Or should that be minus the s! It looks total rubbish.
Ajohnw | 09/11/2015 17:56:55 |
3631 forum posts 160 photos | From the listing it looks like it takes 5 days to get the bits and bolt it together. John - |
ega | 09/11/2015 18:08:34 |
2805 forum posts 219 photos | "The base looks like it might be a piece of steel rail from a railway track." I have seen this very thing done and remember a knowledgeable friend explaining why it is not the best way to provide a very stiff foundation for a lathe bed. I think one of the pictures in the listing illustrates turning nuts! |
Ajohnw | 09/11/2015 18:18:10 |
3631 forum posts 160 photos | There is a much more interesting one here John -
Michael Gilligan | 09/11/2015 18:22:14 |
![]() 23121 forum posts 1360 photos | I know that you guys have said that lathes are scarce in Australia ... But you would have to be desperate to go anywhere near that. MichaelG. . P.S. ... John W1 ... Yes, that does look the business. Edited By Michael Gilligan on 09/11/2015 18:27:14 |
fizzy | 09/11/2015 18:36:31 |
![]() 1860 forum posts 121 photos | whats the flower head on the end of the piece of bar for? make it smell nice? |
David Clark 1 | 09/11/2015 18:40:21 |
![]() 3357 forum posts 112 photos 10 articles | The flower head is between drive centres, not mounted on bar. #shgts |
Boiler Bri | 09/11/2015 19:22:06 |
![]() 856 forum posts 212 photos | lol, looks - rubbish. I do like the accurately turned bar he has there being demonstrated !!!!!1
B |
Neil Wyatt | 09/11/2015 19:38:30 |
![]() 19226 forum posts 749 photos 86 articles | > Important note:Firstly the lathe you recieved probably is not exact same as picture in order to make high quality one, sometimes we change a bit for more effective woring,secondly, you should have a some knowlege about this lathe, though we may offer techinical support but it is limited I guess that really means "Firstly the lathe you recieved probably is not exact same as picture in order to make high quality one, sometimes we change a bit depending on what we can find in the skip" > It may works on ordinary steel, copper-based, aluminum, plastic, Timber, wooden materials, bead, prayer beads,etc
It may work -or it may not... I'm guessing that the prayer beads are an essential before you try any real turning. I recognise the steel bar in the picture - I used to hammer it into the ground and tie a boat up to it. I suppose they are honest, it does look like a DIY lathe, although if my workshop turned that out, I'd be ashamed to show it to anyone. I've seen a better lathe made in a WW2 concentration camp! I wonder if it comes with a CE mark and a test certificate? Neil
Edited By Neil Wyatt on 09/11/2015 19:42:41 |
duncan webster | 09/11/2015 20:47:13 |
5307 forum posts 83 photos | It's a clone of the Super Adept! |
Rainbows | 09/11/2015 21:08:19 |
658 forum posts 236 photos | I think it is entirely possible that a machine tool has never touched one of those components. Some guy is probably in his shed with a hand drill and a crate of factory spares to make this.
Duncan no need to be so mean, this apparently has a standard morse taper spindle and tailstock. Can't get that on the adepts |
John Stevenson | 09/11/2015 21:24:40 |
![]() 5068 forum posts 3 photos | It's been specially produced to keep the "Not fit for Purse" and "Distance selling Regulations" purists happy. |
Enough! | 09/11/2015 22:07:33 |
1719 forum posts 1 photos | Posted by Neil Wyatt on 09/11/2015 19:38:30: I've seen a better lathe made in a WW2 concentration camp!
I'm so sorry Neil, I hadn't realised. Explains a bit though Edited By Bandersnatch on 09/11/2015 22:07:46 |
Roger Williams 2 | 09/11/2015 22:26:05 |
368 forum posts 7 photos | At least you can adjust the tailstock to compensate for base wear after 50 years of use !. It could be the new Ard hinge....... |
Hopper | 10/11/2015 03:53:52 |
![]() 7881 forum posts 397 photos | Love the cross slide feedscrew nut: a piece of 3mm plate bent at right angles with a thread tappd through it and secured with whatever screw was lying on the floor at the time.
Neil Wyatt | 10/11/2015 08:43:22 |
![]() 19226 forum posts 749 photos 86 articles | On the plus side it does look as if everything is adjustable if only because its just bits screwed together! And to its credit, it managed to take cuts on that 'orrible bar using The Lathe Tool From Beyond Hell... Neil |
john carruthers | 10/11/2015 09:04:35 |
![]() 617 forum posts 180 photos | I believe the mystery tool is an apple corer and claim my 5/- |
Ajohnw | 10/11/2015 09:47:16 |
3631 forum posts 160 photos | Posted by Michael Gilligan on 09/11/2015 18:22:14:
I know that you guys have said that lathes are scarce in Australia ... But you would have to be desperate to go anywhere near that. MichaelG. . P.S. ... John W1 ... Yes, that does look the business. Edited By Michael Gilligan on 09/11/2015 18:27:14 It might be an amazing buy for final price - £800. John - |
