Machining acrylic
OldMetaller17/10/2015 09:29:32
208 forum posts
25 photos
Hi everyone, I've just bought some 10mm round acrylic rod to make lenses for two 16mm scale buffer stop lamps. If I was turning them in brass I wouldn't be troubling anyone, as I can happily create the shape I need. My concern is turning acrylic, as I've never worked with it before.
So my questions are: Do I need lubricant? Will sharp HSS tools do it? What speed do I run the lathe at? How do I get a nice finish?
I would be very grateful for your thoughts, please.
John.
Ian S C17/10/2015 10:20:58
7468 forum posts
230 photos
I,v been doing a bit of work on Nylon over the last few days, and trying a newly made carbide tool, but I think the HSS may be better.
Ian S C
Steve Pavey17/10/2015 10:30:03
369 forum posts
41 photos
Sharp hss is fine - I use a high speed and a light cut with a fine feed rate. Polish with fine grades of wet and dry, say 220, 400 and 1000 grit. Finish with a spot of Brasso on a soft cloth.
Gordon W17/10/2015 10:51:54
2011 forum posts
Just been making some washers from , I think ,acrylic. Just used same HSS tool as aluminium, no lubricant.
Neil Wyatt17/10/2015 11:24:00
19226 forum posts
749 photos
86 articles
Polish with finest grade wet & dry or sponge block, then polish with autosol on a thick tissue.
Alex Collins17/10/2015 11:27:56
147 forum posts
38 photos
Why not go and get some 10mm LED's from somewhere like Maplin ?
They come pre shaped and polished and the light will auto work..... ​
http://www.maplin.co.uk/p/10mm-white-led-n83kg
Edited By Alex Collins on 17/10/2015 11:30:00
Frances IoM17/10/2015 11:28:56
1395 forum posts
30 photos
there was an article in MEW (I think) sometime ago by Mark Neil who uses quite a lot of machined plastic in his various scientific instruments - I recall it as he had a lip salve applier to lubricate the cuts ! He also suggested the use of Red Leicester cheese as a lubricant (I've been on a short physical archeaology course run by Prof Neil and his instruments are extremely ingenious in using materials that you would never consider for the task in hand)
Edited By Frances IoM on 17/10/2015 11:56:30
Roger Vane17/10/2015 11:37:33
108 forum posts
18 photos
I've turned acrylic using an hss toolbit in my spherical turning attachment to make a lens for an optical centre finder. Found that material tended to 'pick-up' badly if it gets too hot, After some failures (experimentation?) I found that a fine feed, fairly low rpm and coolant gave a clean cut. I used WD40 as the coolant, and it seemed to work ok, with a much better finish than when machined dry - and no 'picking-up'.
This was followed by polishing with wet and dry of around 800 grit and then Solvol Autochrome metal polish. The metal polish transforms the finish and visibility through the lens.
David Clark 117/10/2015 11:44:56
3357 forum posts
112 photos
10 articles
I used to mill acrylic rod dry with a very sharp cutter no problems. Polished ends with fine wet and dry used wet followed by brasso. They were optical components so had to have a polished finish.i
Neil Wyatt17/10/2015 13:47:03
19226 forum posts
749 photos
86 articles
It's Mark Noel. Wait 'til his 'multigrinder' appears in MEW
Michael Gilligan17/10/2015 13:51:58
23121 forum posts
1360 photos
[presumably] not to be confused with the Tattoo Artist.
Speedy Builder517/10/2015 14:09:36
2878 forum posts
248 photos
Red Leicester sounds good Grommet!! Lets get some in, shall we?
Nick Hughes17/10/2015 14:14:20
307 forum posts
150 photos
A dip in pure Acetone will give the final polish to acrylic. Just in and out then let it dry naturally.
Frances IoM17/10/2015 14:28:06
1395 forum posts
30 photos
thanks Neil - catch with an old memory and no immediate access to mags.
He definately had a photo of some small cylinders of cheese and suggested that they would make a cheaper lubricant for cutting perspex than his first suggestion of lip salve
OldMetaller17/10/2015 16:25:54
208 forum posts
25 photos
Thank you all for that- I'll get stuck in tomorrow and see how I get on. I can't bring myself to waste *CHEESE* in the lathe, so it'll have to be WD40 or Lipsyl!
I would normally use LED's, but I'm using up my old stock of miniature bulbs as I can't bear to waste anything!
Thanks again all.
John.
Frances IoM17/10/2015 19:19:53
1395 forum posts
30 photos
just rememembered that I had my usually UK based camera with me here in IoM - on which I have photos of Mark Noel's article - pp26/29 MEW Dec 2013 - "The Lipsalve Lubricator" - Red Leicester is recommended for machining al alloys, brass + plastic - apparently a good lubricant, smells delicious and 'any spares make good snacks'.
The article is both funny and informative - rather like his lectures + demos on physical archaeology
Edited By Frances IoM on 17/10/2015 19:20:22
OldMetaller17/10/2015 20:13:58
208 forum posts
25 photos
Hello again everybody...well, I couldn't wait until tomorrow, so I got stuck in and made the two red lenses out of the red acrylic rod. Sorry it's not a great photo, I only had my phone to hand.
The acrylic machined beautifully, no noise, just pink ribbons of 'swarf' peeling off (that reminded me strangely of a favourite childhood confection), tending to hang about due, I imagine, to static electricity. I used no lubricant, sharp HSS and steady turning speeds and was delighted by the results.
Another string to my bow, and thanks again for all the great advice freely shared!
Here are the unfinished buffer stops with the buffer stop lamp illuminated. I just need to get on with the weathering and distressing now.
John.
Jens Eirik Skogstad17/10/2015 20:30:45
400 forum posts
22 photos
Polish with flame from torchlamp. **LINK**
