Member postings for Nick Hughes
Here is a list of all the postings Nick Hughes has made in our forums. Click on a thread name to jump to the thread.
Thread: Winter Storage Of Locomotives
03/10/2023 22:52:48
Just a thought, maybe flushing the cylinders through via the bastpipe, with this might help
I've not tried this, but the wipes that they do, work well.
Thread: Trying to identify a bird-feeder thread.
21/09/2023 10:57:39
Could be one of a couple on here:-
Obscure Threads
Edited By Nick Hughes on 21/09/2023 11:01:03
Thread: Another Mystery Object
27/08/2023 12:50:34
Set of genuine pins available here
27/08/2023 10:38:14
Missing the "pins", but it is an Adjustable Pin Spanner
Thread: Locktite allowance
22/08/2023 10:24:46
What metals are involved, as some don't work well and may need the use of an activator/primer, to improve the final joint strength.
Edited By Nick Hughes on 22/08/2023 10:30:49
Thread: I particularly enjoy the recent Myford restoration articles
21/08/2023 10:36:21
The photo on here is clear enough to count the input gear teeth (I count 18) :-
lathes.co.uk
Also some taken during a rebuild here (about 7 min in):-
YouTube
Edited By Nick Hughes on 21/08/2023 10:52:37
Thread: Stephensons valve gear
21/08/2023 10:09:42
Posted by Howard Lewis on 21/08/2023 08:39:37:
GWR used Stepehenson gear on all its locos, inside the frames, opereating the valves for the outside cylinders, of four cylinder locos via rocking levers.
Incorrect, the GWR Stars, Castles and Kings (All 4 cylinder) had Walschaerts, after trials with Scissors on the prototype Star.
Thread: Recommendations sought for a non-shrinking, non-spill oil pot.
12/08/2023 14:24:31
Dropping a decent sized button magnet into my simple plastic pot, has prevented accidental knock over spills for me (obviously only when the pot is on a ferrous surface though).
Thread: Stagger toothed S&F milling cutter regrind
11/08/2023 21:53:18
This (and the next page) may point you in the right direction:-
Thread: What is it and what is it for
29/07/2023 10:02:58
Thread: Lake & Elliot hydraulic bottle jack seals
16/07/2023 11:34:55
These guys might be in a position to help:-
Commercial SuppliesLtd
Thread: Vintage Austin Brake Adjuster
09/07/2023 14:47:53
Part shown here (BK20):-
Thread: Professional Machine Fettling
01/07/2023 15:27:44
Have a chat with
Blue Diamond
They should give you an idea of the cost, so that you can make an informed decision.
Thread: Lathe/VFD/DRO issue
22/06/2023 17:58:32
In my case, I just crimped all three earths into one insulated ring terminal and then mounted this on to the earth point in the motors terminal box.
Edit:- Used the same method at the VFD end.
As for the shield grounding, I'm in the:-
If trying to stop the noise "escaping" out from the cable, then ground at both ends.
If trying to stop noise getting into the cable, then only ground at one end.
Edited By Nick Hughes on 22/06/2023 18:13:26
22/06/2023 17:11:52
Explained here:-
Reason for Symmetrical cable use
22/06/2023 16:41:39
For the VFD to Motor wiring, this is the type of cable that you need and the correct gland:-
Cable
Gland
Also ask them to recommend which of there mains filters would be suitable for your VFD
Thread: M6 x 0.75 LH metric thread
10/06/2023 17:52:04
Have you checked out the replies to your earlier posing for a die supplier?
If not, have a look!
If you have and the replies are not suitable, then a reply stating this in that post, would be appreciated (at least by me).
Thread: M6 LH die
09/06/2023 14:31:57
How about this (first on the list in my Google search for "M6 Metric Fine LH Dies" ) :-
Edited By Nick Hughes on 09/06/2023 14:35:13
Thread: CAD Doodlings.
29/04/2023 12:23:25
Yep done using Alibre Expert.
Edited By Nick Hughes on 29/04/2023 12:38:47
Thread: Leak from pressure pump/nut
29/04/2023 11:50:05
Give Base-Camp a call or e-mail, to see if they can help.
