Using Collet Blocks Correctly
martyn nutland | 12/07/2015 11:29:44 |
141 forum posts 10 photos | I think this very simple question might be a product of my mathematical inadequacies, but I’ve been trying to cut hexagons on a mill using a rotary table to turn the bar (bronze) through 60° six times. It’s been a frightful banjax of which I am deeply ashamed. Two nasties occur. Firstly the flats are not equally wide and secondly they are not true axially. I don’t think there is a problem with the rotary table, the chuck I’m using to hold the bar, nor the mill itself. Moreover, I think I may not be calculating the tangents correctly to ascertain the depth of cut (with an endmill) necessary to create equal flats. Thus I think a collet block set is the answer. But what I don’t understand with collet blocks, is, again, how to cut to the correct depth. Obviously the dimensions of the blocks themselves don’t vary. So, for example, if one wished to cut a hexagon on a bar 15 mm in diameter you would start by putting the stock in the appropriate sized collet and clamping it in the block. But when you have the block clamped in the vice on the mill, how do you know how much to machine off for the first flat, before you turn the block for the next? Do you take, say, a millimetre, turn over, take another millimetre, turn again and so on; and keep going until you have a perfectly even (hopefully) ‘hex’? |
KWIL | 12/07/2015 11:37:31 |
3681 forum posts 70 photos | Have you tried the other way, namely machining less than you think necessary? Take the first 6 passes, which leave you with 6 flats but with curved gaps, then take a little more etc. If the bar is in the centre of the rotating table the flats should all be the same. |
David Clark 1 | 12/07/2015 11:40:23 |
![]() 3357 forum posts 112 photos 10 articles | Hi there Take light cut then turn the hexagon over 180 degrees. Measure the thickness and deduct from af dimension. Divide result by two and take a cut this deep. All flats are machined to same dimension. Use the same method on the rotary table. If the chuck is true to the rotary table the flats will be the same. No need to buy collet blocks.
David Jupp | 12/07/2015 11:49:34 |
978 forum posts 26 photos | Cut depth from circumference of bar, to a hexagonal flat where corners of hexagon juts touch the original bar surface r (1-Cosine 30degrees) = 0.134 r where r = radius of bar stock. Substitute D/2 for r to get 0.067 D Hope that helps.
jason udall | 12/07/2015 12:03:24 |
2032 forum posts 41 photos | Maybe consider what might be the problem. Imagine your stock is over size and off center and not true verticaly. If you now machine to a stop ( say y axis).. thus having a flat in x axis at a given radius from the center of rotation of your rotary table. Now rotate to next facet ( or even 180 to check your a/f) Machine to stop. You might notice that these flats are not equal width nor utterly parallel to the axis of your part . Machine all faces..again to stop Now you will .barring .. something shifting. . have six faces equal and parallel to each other..but A not concentic to part And B not parallel to part. These latter are down to your patience is setting the part. |
Ady1 | 12/07/2015 12:06:45 |
![]() 6137 forum posts 893 photos | There's a small free computer app called Shopcalc.exe which you should find somewhere on the net According to that, you should go in 1.005mm, or basically, one mm Also, the max size of any flat should never exceed 7.5mm (A-B) Edited By Ady1 on 12/07/2015 12:28:01 |
jason udall | 12/07/2015 12:18:30 |
2032 forum posts 41 photos | Note to self.ready the Blo**y question What you are asking. Is what total depth to cut when using a horizontal axis rt . This is the challenge. Lets assume the part is to the dia. Required for the across corners ( normally truncated some but lets ignor that for now). What is the Across flats if the across corners is D? Flat width is D/2 A/F is Dx0.866 Depth of cut is c which is D- A/F all divided by two Or c =D (1-0.866)/2 c= Dx0.067 Working out available but I just look at zeus |
jason udall | 12/07/2015 12:21:09 |
2032 forum posts 41 photos | Btw the magic is 0.866... Which is the sine of 60 degrees ( to four decimals) |
Ady1 | 12/07/2015 12:38:34 |
![]() 6137 forum posts 893 photos | You will get shopcalc here |
martyn nutland | 12/07/2015 12:58:32 |
That's really brilliant everyone. Thank you very much. I should now be able to do this either by 'slightly trial and error' or if I get really clever using the maths so kindly explained. I do hope my old maths mistress is looking down on us and duly impressed Nutland, once a thorn in her side, has bothered to concern himself with this! Again thanks all. Martyn
Bazyle | 12/07/2015 13:12:32 |
![]() 6956 forum posts 229 photos | Sort of related so I will add to this thread if the OP doesn't mind. (too late if he does If you wanted a hex with an accurate centre hole eg to make a collet block, is it better to cut the hex first or the hole? |
Tony Pratt 1 | 12/07/2015 13:28:57 |
2319 forum posts 13 photos | Posted by Bazyle on 12/07/2015 13:12:32:
Sort of related so I will add to this thread if the OP doesn't mind. (too late if he does If you wanted a hex with an accurate centre hole eg to make a collet block, is it better to cut the hex first or the hole? Don't think it matters, for an accurate job it would be best to cut the hexagon oversize or bore the hole undersize & adjust if the two features are not concentric to another. Tony |
jason udall | 12/07/2015 13:57:42 |
2032 forum posts 41 photos | Making bore/hex concentric? Well . Either machine at one hit...ie not let work out of chuck and mount chuck on rotary table.. Or. Index on lathe ( after turning bore) again no removing part from chuck..but then not all have live tooling on lathe. . Or clock bore on mill to acceptable accuracy. .. . But in all cases do/finish bore then machine outside. |
martyn nutland | 12/07/2015 19:47:47 |
Dear David Jupp Sorry to be a real pain. Could you possibly work this through with me line by line? 15 MM bronze bar... Martyn
David Jupp | 12/07/2015 22:15:08 |
978 forum posts 26 photos | From earlier post depth of cut = 0.067 D , where D=15mm so depth of cut = 0.067 x 15 = 1.005 mm Probably check the actual bar diameter first and use the measured value - not sure how close it will be to nominal. Looks like your hexagon will be very close to 13mm AF (1.00 mm off each side). |
Enough! | 13/07/2015 01:51:07 |
1719 forum posts 1 photos | I usually find actually measuring the depth of cut (as opposed to simply relying on the machine dials/DRO) to be a relatively inaccurate process. In a case like this, I prefer to measure the piece that remains .... i.e. from the flat you just cut to the circumference on the opposite side which is a simple micrometer measurement. If D is the diameter of the bar and A is the desired AF dimension of the hex then that measurement should equal (D+A)/2 at the correct depth. |
martyn nutland | 13/07/2015 06:26:27 |
Thanks for the sums. I keep that formula to hand. Martyn |
jason udall | 13/07/2015 09:41:58 |
2032 forum posts 41 photos | Can I suggest something. It may be obvious but. Sketch out ( back of envelope if requjired ) the situation In this case it will allow you to work out what question you are asking the maths.. "Do I add or subtract the number from what I measure?" For instance it shows that the hex at maximum size has the same across corner "diameter" The flats of the hex, if you could measure them , will be half this diameter. Thus we have a triangle drawn in the bit machined off.. One size half a flat long The other ( long side) half of half of the diameter...ie a quarter of the dia Thus by trig we find the third side...0.067 times the original diameter.. Now this is the depth to machine off each side Edited By jason udall on 13/07/2015 10:11:49 |
Russell Eberhardt | 13/07/2015 11:35:04 |
![]() 2785 forum posts 87 photos | Posted by martyn nutland on 12/07/2015 11:29:44:Firstly the flats are not equally wide and secondly they are not true axially. I don’t think there is a problem with the rotary table, the chuck I’m using to hold the bar, nor the mill itself.
If you are cutting to the same depth for each flat one of those must be at fault. Try holding a piece of bar in the rotary table chuck, put a dial guage on it, and rotate the table. There should be very little movement. Russell. |
Ian S C | 13/07/2015 12:36:51 |
![]() 7468 forum posts 230 photos | I'v got a 1/2" UNC L/H thread nut to make for a mates old bench grinder. I'll make the hexagon first, then bore the hole and cut the thread, should be fun. Ian S C |
