Stainless seamless tube
Carl Wilson 405/07/2015 13:03:42
670 forum posts
53 photos
Hello all,
I'm in the market for some 316(L) seamless stainless tube (ie hydraulic tube). Specifically I'm after metric, 10mm OD x 2mm wall. There are an awful lot of steel stockists in the UK, and I'm trying to find the most reasonable price as I need about 25 metres of the stuff.
Can anyone point me in a right ish direction?
Carl.
PS best I've so far found is Nero, about £20.50/metre. There must be better, surely?
Ian S C05/07/2015 13:50:50
7468 forum posts
230 photos
I wanted 3/16" stainless tube a few years back, when I first asked the only way I could get it immediately was to order in a box full(total 5000 ft), but fortunately someone else got some in, I only wanted 3 ft. No help to you , sorry Carl. You could try a boat builder, they use a lot of 316, don't know about 10 mm stuff though.
Ian S C
Brian05/07/2015 15:59:16
40 forum posts
No connection at all but try Metal Supermarket you may be lucky.
Nick Hughes05/07/2015 16:18:05
307 forum posts
150 photos
When I was after some "slices" of steel tube, to make the tyres for my Castle, Steel Express:-
http://www.steelexpress.co.uk/non-ferrous/stainlesssteel-seamlesstube.html
came out the cheapest (link should take you directly to the stainless section).
Nick..
Edited By Nick Hughes on 05/07/2015 16:21:44
Windy05/07/2015 16:33:51
910 forum posts
197 photos
I have bought 6metre lengths of seamless 316 and 321 from **LINK** it was some years ago.
The names of suppliers keep changing with time there was Tube-sales, Fine tubes and the above the last lot I bought was a clearance sale so no idea of cost now.
Paul
Neil Wyatt05/07/2015 21:07:11
19226 forum posts
749 photos
86 articles
I nearly bought some from here:
In the end I bought a second hand tripod for less than half the price of 3M of tube. Even a new tripod would have been cheaper!
Ajohnw05/07/2015 23:32:29
3631 forum posts
160 photos
I use these people for none ferrous as they are local. They don't show what you want as stock but it might be worth asking. Good / bad prices? No idea as I usually want cut to size and can just go and get what I want.
Also these people
http://www.rapidmetals.co.uk/
Edited By John W1 on 05/07/2015 23:34:48
Ian S C06/07/2015 12:12:16
7468 forum posts
230 photos
I found RS Components Ltd Birchington Rd Northants NN17 9RS UK, they sell in 2 m lengths, and it's expensive, 1 will cost 77.11 pounds, 10 is 64 . 77 ea. Grade 316L.
Ian S C
Carl Wilson 406/07/2015 12:20:06
670 forum posts
53 photos
Gents,
Many thanks for all the replies and the suggestions. Steel Express got back to me today. They do 6m lengths and it is £10.60 a metre. This is the best price I've found so far for 316L in the size I want. I knew that it would be expensive, just a case of trying to get the best deal.
It has to be 316L as I am going to weld it.
Thanks again for all your help,
Carl.
Bob Brown 106/07/2015 12:32:04
1022 forum posts
127 photos
Posted by Carl Wilson 4 on 06/07/2015 12:20:06:
Carl.
I think you will find most of the 300 series stainless steels can be welded so you are not restricted to 316
Bob
Carl Wilson 406/07/2015 12:51:52
670 forum posts
53 photos
Hello Bob,
What you say is correct however there are a number of provisos to welding 300 series stainless steels.
-316 is susceptible to carbide precipitation when welded, not so 316L
-The application involves high temperatures, and as above carbide precipitation can be a problem here, not so 316L
-Full corrosion resistance can only be achieved in 316 after post weld annealling, not so 316L
The application involves high temperatures in the presence of strong oxidisers and is welded. Ergo 316L.
316L is a bit easier to machine (well, ok, not much...)
Carl.
Chris Hembry25/04/2016 10:46:09
52 forum posts
Not sure what ^^^ has to do with 316L Stainless !!!
However, try Paul at millstainless.co.uk in Wisbech. I used to use steelexpress, but delivery got excessive, so changed to these guys. Just a satisfied customer.
Boiler Bri25/04/2016 13:18:57
856 forum posts
212 photos
TW metals in Southampton.
Minimum order £80 so be careful on the quantity that you need. They dont tell you if it is cheaper per mt. They just charge up to the amount.
michael darby25/04/2016 14:03:19
48 forum posts
Have you tried Stainless Metric Stock Lancashire. you can use grade 304 or 321 or 410 all are weldable dependent on your requirements
John Fielding27/04/2016 08:27:22
235 forum posts
15 photos
Has anyone sat down and thought about how "seamless tube" is made?
So called seamless tube isn't seamless at all when it is drawn.
Andrew Johnston27/04/2016 08:49:08
7061 forum posts
719 photos
Posted by John Fielding on 27/04/2016 08:27:22:
Yes thanks.
Edited By Andrew Johnston on 27/04/2016 08:49:24
Michael Gilligan27/04/2016 09:39:59
23121 forum posts
1360 photos
John,
A chap called Ray Miller seems to have thought aout it, when he wrote this article:
Edit: Here, for the pool of knowledge, is the Mannesmann patent.
Edited By Michael Gilligan on 27/04/2016 09:53:57
JA27/04/2016 10:47:52
1605 forum posts
83 photos
To make a tube first you have to make a hole. Easy if you are making it from strip, just weld to two edges together. More difficult if the tube is seamless. The methods described in the links from Michael Gilligan's posting are typical methods of starting seamless tube. During my time at Corby we did not commercially produce stainless steel tube but experimentally we tried. The method was completely unconventional, never patented and details never made public. It was not a success but I am sure it will be, one day, for tube made from exotic metals.
Although the API, and thus the whole oil industry, insisted on seamless tube for oil well casing and drill stems it was not really superior to high quality welded tube such as boiler tube. A main difference between the two types, other than the weld, is the wall thickness for welded tube is consistent. In other words the bore of a seamless tube wanders
JA
