Using compressed air on the lathe
BERT ASHTON30/09/2014 19:05:53
78 forum posts
59 photos
4-jaw.jpgSome years ago I was given a "Windy" type compressed air drill, I decided to use it along with my GHT Headstock Dividing Attachment. So I made up a right angle bracket, clamped it to the cross slide and bored a hole at centre height to suit the drill. I then drilled and tapped for a clamping screw. The photograph shows making a jig for making cylinder covers.More of GHT Tooling
Edited By BERT ASHTON on 30/09/2014 19:31:05
Edited By BERT ASHTON on 30/09/2014 19:32:01
Brian Wood30/09/2014 19:16:51
2742 forum posts
39 photos
Very nice Bert, but don't be tempted to use air blast to blow off swarf and turnings from the lathe; it is all too easy to force small swarf under wipers on the moving surfaces where they get up to mischief out of sight
I have always used a bannister brush to clean down machines after use, soft bristles in a longish handle about 3 inches wide, you can sweep away a lot of mess with it.
BERT ASHTON30/09/2014 19:35:26
78 forum posts
59 photos
The first photo shows drilling the holes for the 4 jaw chuck for the Stuart model lathe.
Kenneth Deighton30/09/2014 19:39:25
69 forum posts
Hi Bert, I agree with Brian , NEVER use an air line to clean your Lathe or any other machines,I brush down the heavy stuff then I use an old vacuum ( it has a very nice gentle mans name ) this I find is safe and adequate.
Ken.
frank brown30/09/2014 20:18:46
436 forum posts
5 photos
Francis of Assisi ? laugh
Frank
Boiler Bri30/09/2014 21:22:39
856 forum posts
212 photos
I like the drill idea.
I may have to down size my workshop and remove my milling machine, ending up milling on the lathe so I like threads like this.
Gives me hope that I can still mill.
Gray6230/09/2014 22:05:11
1058 forum posts
16 photos
well, I see the wanna be elfins are out in force already. Don't see any suggestion by the OP of using an airline to clean down his machine. Just a good example of how comp air can be used to advantage on a machine. Glad I've never mentioned that I use comp air all the time on mine, to run either a hilsch vortex tube or a fogbuster, cos then I'd have had the elfins on my back too!
BERT ASHTON01/10/2014 12:34:32
78 forum posts
59 photos
I agree that cleaning machine tools with compressed air is bad workshop practice, but after spending most of my working life in engineering I remember machine shops where most of the men was on piece work, time was money so everybody cleaned down with a quick blast of the air gun. how times have changed.
Gordon W01/10/2014 16:10:41
2011 forum posts
When I was a lad we had men come round to clean the machines, well the big ones. I use an old foot pump for air supply on the lathe. A bit of small bore tubing and you have an easily controlled blast for cleaning eg. chucks. Not enough puff to endanger anything.
maurice bennie01/10/2014 16:30:42
164 forum posts
Hi Bert . Please can you tell Me where you got the dividing machine from .It looks much simpler to make than others that I have seen , and I want to make one.
Thanks Maurice.
BERT ASHTON01/10/2014 17:31:10
78 forum posts
59 photos
Hi Maurice, nearly all the extras on my lathe are the designs of George H Thomas, in the UK kits and drawings are supplied by Hemingway Kits. www.hemingwaykits.com GHT also wrote a number of books on model engineering, well worth a read.
Ian S C02/10/2014 11:59:55
7468 forum posts
230 photos
There was an article In ME a few years ago for a low pressure air nozzle for use on machinery. I use a bit of plastic tube, and lung power, or a rubber bulb(solder sucker).
Ian S C
Neil Wyatt02/10/2014 13:27:24
19226 forum posts
749 photos
86 articles
You are probably thinking of Peter Spenlove Spenlove's 'puffer'. As i reacall it was for a short 'puff' and included an extra ring of holes to cerate an sir shroud and reduce blowback of swarf - goggles still needed of course.
Many commercial puffers have a long reach, one of the things the HSE advise for swarf blowers.Lots of sound advice on the topic on their website.
maurice bennie02/10/2014 16:13:00
164 forum posts
Hi Bert , thanks for the information. I Have now got the book and when I have some spare time will read it
clogs02/10/2014 17:35:43
630 forum posts
12 photos
HI all,
any chance of the ISBN no of the G.H.Thomas book please.....
many thanks Frank in France
Gray6202/10/2014 17:43:38
1058 forum posts
16 photos
The book you are looking for is Workshop techniques by G H Thomas
  • Publisher: TEE Publishing Ltd; Revised edition edition (Oct 1998)
  • Language: English
  • ISBN-10: 1857611063
  • ISBN-13: 978-1857611069
Available from Hemingway Kits or Amazon
Jon02/10/2014 19:57:00
1001 forum posts
49 photos
Posted by Brian Wood on 30/09/2014 19:16:51:don't be tempted to use air blast to blow off swarf and turnings from the lathe; it is all too easy to force small swarf under wipers on the moving surfaces where they get up to mischief out of sight
I can see what your thinking but logic says whilst machines in use those debris will do exactly the same without air blast.
