WARCO WM-250 lathe family and WM16 mill
Discussiona about the warco etc WM-250, 280 & 290 lathes and the WM series mills
Sam Longley 123/05/2016 13:25:48
965 forum posts
34 photos
Today I had a bit of a calamity & may have damaged my WM 250 lathe
I was using the powered drive to reduce some bar stock & had the topslide retracted so that the tool was over the centre of the unit to maintain max rigidity of the tool. As the tool approached the chuck I did not notice that the carriage hit the stop & jammed the leadscrew. I made the mistake of trying to disengage the drive rather than turning off the power so it was forced up hard before the motor stalled
This happened partly because my old Drummond M automatically disengaged at a set point & I was not used to having to make a special act to stop this
Is there a switch that can be fixed onto the bed to disengage the power or has anyone actually fitted such a thing or is there any alternative to avoid a repeat of such stupidity
John Rudd23/05/2016 13:40:45
1479 forum posts
1 photos
It should be relatively easy to incorporate a micro switch to prevent such events.
How electrical savvy are you?
Is your machine the dc motor or 3 ph motor version?
If yours has the dc motor, then there are a pair of connectors marked I1 and I2 on the pcb near the front. The switch can be wired to these terminals.
If its the other version, you would need to wire into the fwd/rev sw....
Edited By John Rudd on 23/05/2016 13:53:27
Sam Longley 123/05/2016 15:30:12
965 forum posts
34 photos
Posted by John Rudd on 23/05/2016 13:40:45:
Well I know it makes your hair stand on end when you poke your fingers in the plug holes
I did not know that there were 2 types of motor , I assume I have 240 V as i plug it into a 13 amp plug socket
Can you give some indication of where i find the PCB please
John Rudd23/05/2016 15:56:10
1479 forum posts
1 photos
Sam,
I dont know the WM series, my own lathe is from SPG and is probably the bigger brother, it does look similar.
Mine came with a 1.5kw dc motor, so if yours is the similar dc motor driven smaller version, then the pcb is located in the box attached to the rear of the headstock.( as if stood in front of the m/c). I think its mounted on the right side as you look into the box....
Can you post pictures?
Sam Longley 123/05/2016 19:06:38
965 forum posts
34 photos
I think it is different. It is a 1.1 Kw delta Inverter drive Ac induction motor.- Whatever that is !!!
I removed the chuck guard almost immediately & that has a mounting bar with a switch somewhere along the line that disables power when the guard is raised.. If that has 2 wires to it then I could divert them to another switch on the bed. That would mean i would not have to touch any PCB etc.
I just need someone who has had one of these apart to give me the heads up on how best to go about it & if it is possible
Gray6223/05/2016 19:53:00
1058 forum posts
16 photos
Hi Sam, I've got the same machine, Your machine has a 3 phase AC motor driven by the Delta inverter not a DC motor/pcb setup.
You could re-use the chuck guard interlock connections, if memory serves me correctly, these can be accessed by removing the rear cover of the headstock, this is where the inverter is housed. Whilst you have access to the inverter there are some parameters that can be changed which improve the machine, I found that the speed ramp up and ramp down times were set to long, and also the DC braking settings were sub-optimal. If you are going to rely on a interlock switch to stop the lathe before it crashes, you will need the spindle to stop a bit quicker than it currently does. If you want more detail, send me a PM and I will provide more detail. I'll be back home at the end of the week, happy to give you a call if you include your number in the PM. Where in the country are you?
Sam Longley 123/05/2016 20:38:36
965 forum posts
34 photos
Thanks --Essex, CM0 7LY
But I am off sailing to Channel Islands & then to Brest for the next couple of months starting in next couple of days
However, if i could find which wires to use I am sure i could work out how to rig a switch. I could just extend them.
Then I need to find a suitable switch. I am assuming 240 V. Is that correct ?
Gray6223/05/2016 20:53:51
1058 forum posts
16 photos
Hi Sam,
All of the interlock circuit is low voltage, 24v dc IIRC. Any medium/heavy duty microswitch with NC contacts should do the job fine.
Enjoy the sailing and if you need any assistance with the lathe when you return please feel free to get in touch.
Graeme
Sam Longley 123/05/2016 21:02:13
965 forum posts
34 photos
Graeme
Thanks for that
I will PM you on my return when I have confidently opened up the headstock & found I am lost !!!!!!!!
Enough!24/05/2016 01:03:47
1719 forum posts
1 photos
Posted by Sam Longley 1 on 23/05/2016 19:06:38:
Not sure how you mean "divert them", Sam. If you mean taking removing them from the switch on the guard and using them instead for the carriage switch (thereby losing the safety switch on the guard) it ought to be possible to have both by wiring the second switch in series or parallel (depending how the guard switch operates). That way you'd have both safety switches operational.
(Apologies if this is what you meant in the first place).
Sam Longley 124/05/2016 07:44:17
965 forum posts
34 photos
Posted by Bandersnatch on 24/05/2016 01:03:47:
What I have done is removed the guard & rotated the bar so the machine thinks the guard is in place.
I was considering just disconnecting the wires from the switch on the bar & re routing them to a new switch on the bed
Now Graeme has told me it is 24 V I assume I need a limit switch from someone like RS Components
I just need to sort out which one because Graeme has pointed out that the motor does not cut out instantaneously so I am not sure if that affects bed travel after it hits the switch so the switch may need to be a type of plunger or snap action & I have to determine which one
Edited By Sam Longley 1 on 24/05/2016 07:51:45
Ian Westlake18/03/2017 23:28:22
6 forum posts
Hello
I'm after a favour - Please would someone provide the following measurements:
  • Bottom of the chip tray to the centre of the spindle/chuck
  • Bottom of the chip tray to the top of the bedway
  • Bottom of the chip tray to the handle of the manual feed for the saddle (with the handle in the 6pm position)
I want to work out what height a bench will need to be for the lathe I plan to buy (I will be welding a bench, however need to know the dimensions so that I can cut the metal).
Ian
Edited By Ian Westlake on 18/03/2017 23:28:58
john kennedy 119/03/2017 08:27:28
214 forum posts
24 photos
Hi Ian,
Tray to spindle centre .. 309mm
Tray to flat of bed .. 182mm
Tray to saddle handle at 6pm ..80mm
A little tip, make it high to prevent backache.
SteveW19/03/2017 17:03:44
140 forum posts
11 photos
I made my bench 895mm O/A. to the top which is made from one layer 18mm ply and kitchen worktop to finish. I am 5' 10"" and the handle on the cross slide is about on a level with my elbow. I thought 'too high and I can stand on a box; too low and I'll need to dig a hole...'. Has worked out just right for me. No back problems.
Ian Westlake19/03/2017 18:07:54
6 forum posts
Thank you to both of you, that's what I was after as I don't want to make it too low. I'm 5' 8", so I reckon 900mm height is about right, and if it isn't, I can knock up a duck board to stand on.
Martin Botting 219/03/2017 18:39:32
93 forum posts
20 photos
Posted by Ian Westlake on 19/03/2017 18:07:54:
I built mine a tad to high but have now screwed 6" blocks of soft wood to my boots and its fine, apart from smashing my nut on the ceiling.
john kennedy 120/03/2017 08:38:05
214 forum posts
24 photos
You're about right there Ian. I'm also 5'8" and I made my stand 830mm from the floor so you can make your duck board to suit.
Bob Rodgerson20/03/2017 19:21:35
612 forum posts
174 photos
I used to get backache when I was working on my BH 600 because it was bit low for me. When I bought my CNC mill I put both my BH600 manual mill (Superlux) onto moveable trolleys with lockable wheels, they were made from 4" channel and the castors were a further 4 inches tall so I increased their height considerably.
As a result I no longer get backache when working at the lathe or the mill but I do get a lot more hot chips down my shirt from the lathe than ever before and I find it difficult to look over the top of the tool post.
mechman4806/05/2018 14:56:28
2947 forum posts
468 photos
Going back to this general thread of the Warco Family; have looked through this & done a search on 'oilers' & not having any results, could any one with a WM250V who has changed their oilers please let me know what size the ball oilers are on the saddle/ tailstock etc. A couple of mine need changing & rather than have to send back the wrong size or dig one out at the mo', I'd prefer if any member has the size to hand, or ref. link. IIRC somebody did mention the size 3/16 - 5mm, 1/4" - 6mm ?
TIA
George.
