Enough! | 18/05/2020 16:52:04 |
1719 forum posts 1 photos | |
Geoff Theasby | 18/05/2020 18:17:43 |
615 forum posts 21 photos | I now found my Macro'ed photo, a notched screwdriver for scraping copper wires clean, using the macro facility on my Fuji X-20. |
Mark Easingwood | 18/05/2020 20:10:48 |
![]() 53 forum posts 16 photos | Posted by duncan webster on 18/05/2020 13:00:03:
Slightly off topic, but not far. My digital camera (Canon IXUS 230HS) doesn't have remote shutter release, which makes taking shake free close ups a bit hit and miss. I've been thinking of buying a bowden cable type device and making a bracket to support the business end above the button. They all seem to ave a very peculiar tapered thread, which presumably screwed into a similar thread on the camera (which mine doesn't have). Anyone else tackled this? It wouldn't be difficult ot make the whole bowden set up, but at ~£3 off ebay there is an incentive to adapt Hi Duncan, The bowden type ones have a tapered thread, and fit mechanical film cameras. Digital cameras require either a wireless or plug in type. The plug in type fit into a mini jack plug on the camera, the wireless type usually work via an infra red receiver on the camera. Bad news is they must be compatible to your model of camera. The shutter button is in effect just a two position electrical switch, half press activates focusing motor, full press activates the shutter. If your subject is fairly static, just use the self-timer, set it on it's shortest duration if it is possible to do so. PS To all those who don't know, never connect any self powered device, or flash, to your camera, unless it is deemed compatible, as any extra voltage going back to your camera, over it's safe limit, will fry it's brain...... |
Sam Stones | 18/05/2020 23:20:49 |
![]() 922 forum posts 332 photos | But for the scale, this might even be the Grand Canyon. This was the thread **LINK** Oh, and the colours are wrong for the Grand Canyon.. That's a brilliant grasshopper photograph, Brandersnatch. Looks like flash from the side, with fill in from above? By the way, with this one (below) ... You'll see it when you believe it. It's a brain teaser. Regards, |
mark smith 20 | 19/05/2020 00:42:47 |
682 forum posts 337 photos | passion flower |
Enough! | 19/05/2020 01:32:12 |
1719 forum posts 1 photos | Posted by Sam Stones on 18/05/2020 23:20:49:
Actually it was just available light, Sam. It was on the handrail of the stairs leading up to the condo we were renting in Florida (some years ago now when I wasn't persona non grata for medical insurance and used to drive down from Ontario in the spring for a few weeks). It was just "there" when I came back from the beach and I took the opportunity. The lighting is very bright - even harsh - in Florida so I can see where you might think it was flash. |
Daniel | 19/05/2020 06:25:26 |
![]() 338 forum posts 48 photos | Posted by Bandersnatch on 19/05/2020 01:32:12:
That's a brilliant grasshopper photograph, Brandersnatch. Looks like flash from the side, with fill in from above? ......... The lighting is very bright - even harsh - in Florida so I can see where you might think it was flash.
Bandersnatch, That's impressive for natural light. Great shot. ATB, Daniel
Daniel | 19/05/2020 06:34:49 |
![]() 338 forum posts 48 photos | A pair of Hollyhock Weevils having a cuddle .... And a spider ... Edited By Daniel on 19/05/2020 06:38:24 |
Daniel | 19/05/2020 06:43:50 |
![]() 338 forum posts 48 photos | Posted by Sam Stones on 18/05/2020 23:20:49:
By the way, with this one (below) ... You'll see it when you believe it. It's a brain teaser. Regards, Sam
Heating element ? My brain is being horribly teased ... Mind you, that doesn't take much. Are you going to tell us, Sam ? ATB, Daniel
Colin Heseltine | 19/05/2020 11:35:01 |
744 forum posts 375 photos | Following MIchael Gilligans comments about Achromatic Doublet lens giving good results I did a bit of googling and came across the NISI Closeup lens which is a Double Apochromatic Lens and with Multi-Nano Coating which had some excellent reviews. This looked like a good bet as did not want spend a fortune on a specialist macro lens. Turned up this morning so had a quick go before got on with some gardening projects. Hand held on Nikon D7000 with 70-300 zoom and the NISI lens. Quite pleased with results. Colin
Peter G. Shaw | 19/05/2020 12:44:55 |
![]() 1531 forum posts 44 photos | re Sam Stones, I think it's a submersible thermostat, possibly from a car. It's showing rust on both sides which implies permanent submersion. The two circular objects are springs, so I think it has a snap action to allow an increased water flow, eg the temperature in the engine block has reached normal so the thermostat moves to bring the radiator into play. Well, that's my thought. Probably totally and completely wrong! Peter G. Shaw |
Neil Wyatt | 19/05/2020 13:35:46 |
![]() 19226 forum posts 749 photos 86 articles | Posted by Sam Stones on 18/05/2020 23:20:49:
By the way, with this one (below) ... You'll see it when you believe it. It's a brain teaser. Regards, Thanks for the clue Sam, got it now Neil |
Michael Gilligan | 20/05/2020 09:57:50 |
![]() 23121 forum posts 1360 photos | Posted by Rod Clemett on 16/05/2020 00:04:23:
Those of you with more than a passing interest in fine optics, look away now!
. ... and can now feast your eyes on this: ... from a Zeiss brochure, recently re-discovered by someone on the microscopy forum. MichaelG. . Document is here: http://www.robarts.ca/confocal/Objectives.pdf Edited By Michael Gilligan on 20/05/2020 09:58:56 |
Journeyman | 20/05/2020 10:23:59 |
![]() 1257 forum posts 264 photos | Captured this on the phone whilst out riding the bike yesterday:- Rosa canina "Dog Rose" I believe. John |
Michael Gilligan | 20/05/2020 10:29:17 |
![]() 23121 forum posts 1360 photos | Lovely image that, John MichaelG. |
Michael Gilligan | 20/05/2020 10:36:49 |
![]() 23121 forum posts 1360 photos | Posted by Colin Heseltine on 19/05/2020 11:35:01:
Following MIchael Gilligans comments about Achromatic Doublet lens giving good results […] Quite pleased with results. Colin
. Phew ... that’s a relief, Colin [couldn’t really ask for better performance than that with a supplementary on a zoom] MichaelG. |
Raphael Golez | 20/05/2020 11:30:58 |
167 forum posts 153 photos | Very nice capture of flowers Colin and John.
Colin, if you have a 50mm lens you can try a reverse ring attachment to further magnify your subjects.
I didn't realise that some of the extreme macro shots of some insects are taken with a dead specimen. That explains how they can get extremely close to an ant without it moving about.
Its amazing to see how a phone camera compares to a dedicated macro lens. It might not be a 1:1 magnification but amazing how you can get very close to your subject and capture a remarkable amount of details. I'm very curious as to how much magnification a phone camera can handle. Maybe its 1:2 and above? Edited By RAPHAEL VAL GOLEZ 1 on 20/05/2020 11:32:50 Edited By RAPHAEL VAL GOLEZ 1 on 20/05/2020 11:36:00 |
Journeyman | 20/05/2020 12:17:39 |
![]() 1257 forum posts 264 photos | Raphael, modern phone cameras are very good, in fact often a major selling point. I am no photographer, strictly point and shoot but for anyone who can understand it (I can't) the exif data for the rose says: size:4096 x 3072px, camera: Motorola g7, aperture: F1.8, shutter: 1/180 seconds, focal length: 4mm Taken I would guess about 150 to 200mm away from the subject. I have cropped it slightly to remove some of the leafage! and centre the image. Biggest problem is that it is difficult to see the screen in bright sunshine and it's a bit hit and miss if the object is moving as there is some shutter delay and of course the phone throws a shadow if the light is behind you. John |
roy entwistle | 20/05/2020 12:44:56 |
1716 forum posts | Raphael The usual technique with small beasts is to freeze them or at least cool them down |
Michael Gilligan | 20/05/2020 14:05:29 |
![]() 23121 forum posts 1360 photos | Posted by RAPHAEL VAL GOLEZ 1 on 20/05/2020 11:30:58:
[…] I'm very curious as to how much magnification a phone camera can handle. Maybe its 1:2 and above? . It’s a potentially difficult concept, Raphael If you think in the same terms as we did for film cameras [substituting the physical of the sensor for the film frame size] then almost every image taken on a ‘phone is greatly “minified”. The more appropriate paradigm is probably to consider the screen size, rather than the sensor ... but even that bears no direct comparison with film, or with large camera sensors. MichaelG. . More about that emboldened word, later. |
