Simon0362 | 23/01/2017 18:12:40 |
279 forum posts 91 photos | Posted by Emgee on 23/01/2017 16:54:07:
If anyone is fed up reading endless posts that seemed to be researched by the member as the post continues do as I did, use the Ignore member from the menu at the bottom of one of his posts, job done. It won't prevent quotes from his/her posts by others appearing but these are fast becoming less. Make sure you are always logged in or they will certainly appear, whichever topic you are in !!!!!!!!!!!!! Emgee Made my afternoon....... BR, Simon |
John Stevenson | 23/01/2017 18:13:06 |
![]() 5068 forum posts 3 photos | A Jonah W - 1
The rest of the sensible posters - 19 |
Enough! | 23/01/2017 18:17:33 |
1719 forum posts 1 photos | Posted by JasonB on 23/01/2017 15:50:26:
It's a bt like on here, several members have you on their avoid list, unfortunately as a moderator I can't blank out members posts from my screen.
Yet I can blank out moderators (at least the "ignore member" selection is there).
In fact the only member I can't ignore is me Edited By Bandersnatch on 23/01/2017 18:18:43 |
Ajohnw | 23/01/2017 19:57:45 |
3631 forum posts 160 photos | I'm all for people who want to do that. Save getting replied from people who think they are clairvoyant for one. John - |
Russ B | 23/01/2017 21:05:29 |
635 forum posts 34 photos | baaa, well I didn't read all this thread as it seemed to bend off on various tangents, but I use a significant amount of hose and pipe at work - I'm probably surrounded well over 1 km of pipe over 1" and up to 40", and many many more times that under an inch and I just thought I'd upset a few people tonight - firstly by using imperial measure rather than DN
so...
Pipe, is measured and ordered by OD, standard schedule pipe's have common OD's for fitting standard flanges and nylon/urethane pipe is sold in 6/8/10/12/16/20mm and they are referring to the OD because that is the critical dimension (for push fittings, olive type fittings etc) - fitting in to orifices using its external diameter means a theoretically step free transition give or take a little. Tube, is a measured by ID for pushing on too a barb of some sort or similar application. Mixing the two will result on much effort usually invloving welding of some sort or cups of boiling hot water and plenty of spit. go on then you lot, start whinging......... hang on, I forgot Hose....... Hose isn't pipe or tube, and is usually somewhere in the middle if you ask me but typically, always measured by its ID - done. Edited By Russ B on 23/01/2017 21:06:38 Edited By Russ B on 23/01/2017 21:09:15 |
Neil Wyatt | 23/01/2017 21:09:36 |
![]() 19226 forum posts 749 photos 86 articles | Posted by Russ B on 23/01/2017 21:05:29:
Pipe, is measured and ordered by OD, standard schedule pipe's have common OD's for fitting standard flanges and nylon/urethane pipe is sold in 6/8/10/12/16/20mm and they are referring to the OD because that is the critical dimension (for push fittings, olive type fittings etc) - fitting in to orifices using its external diameter means a theoretically step free transition give or take a little. Tube, is a measured by ID for pushing on too a barb of some sort or similar application. And what about hose? |
Russ B | 23/01/2017 21:13:19 |
635 forum posts 34 photos | Posted by Neil Wyatt on 23/01/2017 21:09:36:
John Rudd | 23/01/2017 21:30:03 |
1479 forum posts 1 photos | To quote...... " l need some ' ose....." "No..... Letter O's.....for Mon Repose..."......
Four candles anyone?....... |
Michael Gilligan | 23/01/2017 21:32:26 |
![]() 23121 forum posts 1360 photos | Posted by Ajohnw on 23/01/2017 14:45:41:
I mentioned buying an 8mm air line that wasn't. < etc. > . Russ, Just for the sake of completeness [since I doubt there is any other valid reason] ... How would you expect "air line" to be specified ? That was the term that Ajohnw used in his opening post, but it doesn't feature in your comments. MichaelG. |
peak4 | 23/01/2017 21:54:44 |
![]() 2207 forum posts 210 photos | La-Pla , my local hydraulic supplier has the following (or something very like it) pinned up behind the counter.; 1) All pipe is to be made of a long hole surrounded by metal or plastic centred around the hole. I'll get me coat Bye Bill |
Dod | 23/01/2017 22:03:56 |
114 forum posts 7 photos | Nice one Bill |
Russ B | 23/01/2017 22:33:50 |
635 forum posts 34 photos | Posted by Michael Gilligan on 23/01/2017 21:32:26:
I mentioned buying an 8mm air line that wasn't. < etc. > . Russ, Just for the sake of completeness [since I doubt there is any other valid reason] ... How would you expect "air line" to be specified ? That was the term that Ajohnw used in his opening post, but it doesn't feature in your comments. MichaelG. Air Lines! I'm glad you asked, but I can't speak for all manufacturers..... Basically, in the late 1940's Boeing assigned numbers to aircraft, 400's were military aircraft, 500 were turbines, 600 were missiles and 700 were passenger aircraft........
Edited By Russ B on 23/01/2017 22:37:42 |
Michael Gilligan | 23/01/2017 22:54:21 |
![]() 23121 forum posts 1360 photos | Thanks Russ That'll remind me not to ask serious questions once a thread has got out of hand. MichaelG. |
Hopper | 23/01/2017 23:06:24 |
![]() 7881 forum posts 397 photos | Posted by peak4 on 23/01/2017 21:54:44:
La-Pla , my local hydraulic supplier has the following (or something very like it) pinned up behind the counter.; .... Bill They forgot to specify that flanges are to be fitted only to the ends of pipes, not the middle. |
Ajohnw | 23/01/2017 23:15:19 |
John - |
Russ B | 24/01/2017 10:31:39 |
635 forum posts 34 photos | Posted by Michael Gilligan on 23/01/2017 22:54:21:
Thanks Russ That'll remind me not to ask serious questions once a thread has got out of hand. MichaelG. Michael, yep! But if I had to give a sensible answer............ I would say its an application or category to put a hose, pipe or tube product in to - obviously many application have specific requirements so it makes sense to give it a name that better describes its intended use but it's still going to be either a hose, pipe or tube. |
Bodgit Fixit and Run | 24/01/2017 10:58:23 |
91 forum posts 2 photos | Posted by Neil Wyatt on 23/01/2017 21:09:36:
And what about hose? Didn't Robin Hood wear hose? |
not done it yet | 24/01/2017 10:59:55 |
7517 forum posts 20 photos | It looks like this item on epay. Could wrong, but likely as it fits the thread title.
Item no.120704378011 |
Ajohnw | 24/01/2017 11:13:29 |
3631 forum posts 160 photos | If it was they removed the 8mm almost immediately and then put it back. I purposefully avoided mentioning the seller as all make mistakes at times. So if it was this one draw your own conclusions. I've made mine. Just out of interest if some one does buy a recoil air line I would suggest both this brand or at least this sort of listing. It tells people exactly what they want to know when air flows though a pipe. That's why they are often listed that way but unfortunately not always on ebay. Just stating 1/4bsp gives a clue but it looks like that may be 5mm bore. John - Edited By Ajohnw on 24/01/2017 11:21:04 Edited By Ajohnw on 24/01/2017 11:34:19 |
not done it yet | 24/01/2017 11:31:16 |
7517 forum posts 20 photos | I doubt the seller was at fault, so undeserving of negative feedback - as I see it.
I would buy from them, but would check out the spec, if at all unsure, first (probably like most sensible potential buyers would).
If you are now whinging about them declining to supply you with further items, I can't really blame them. They can obviously do without your business and retain their high feedback score (which may well be justified - I just looked at all the few negatives). They do seem to try to be helpful whenever a problem arises. |
This thread is closed.
