Hand cleaner
frank brown21/06/2015 19:57:29
436 forum posts
5 photos
My problem with Swarfega and All Jobs Hand Cleaner is that after a couple of hours my pores ooze out more grimey oil. So finish "work" at 5, wash hands with Swarfega, wash them again at 8 in soap and again at 10 then finally when I retire at 11.
Years ago when I was an apprentice, we used barrier cream, what a pain, it dries out so I had a fine clay coating on my hands then you had to rehydrate it before it could be washed off.
I have been cogitating on this problem for years, this thread is prompting me into action, So John, your olive oil has no secondary ooze-out?
Frank
Neil Wyatt21/06/2015 23:25:44
19226 forum posts
749 photos
86 articles
Washing up liquid with a spoon of sugar in it. Rub in well before adding water.
Another effective way of getting the hands clean is washing your hair (where applicable). Alternatively, make some bread, but DON'T get caught
What I could do with right now is something that will get Leylandii sap off. After two days with a pole-chainsaw and a weedy twig-shredder I have many black marks that won't come off
fizzy21/06/2015 23:34:57
1860 forum posts
121 photos
barrier cream iant what it used to be...use dri-guard, no drying and it really works
martin perman22/06/2015 09:32:32
2095 forum posts
75 photos
Gentlemen,
I hate using gloves when working on dirty jobs as I find they get in the way but have found through my job that if my hands are still mucky after using hand cleaner I wear latex gloves for half an hour and my hands sweat themselves clean, at home I use Swarfiga Orange.
Martin P
John Stevenson22/06/2015 10:00:36
5068 forum posts
3 photos
Posted by Neil Wyatt on 21/06/2015 23:25:44:
Putty also works well, so that has to be the linseed oil ?
Muzzer22/06/2015 10:08:27
2904 forum posts
448 photos
Resin from evergreen trees, fibreglass, epoxy etc is a sod to get off. I used to have some "Emulan" which was a white waxy hand cleaner. It worked a treat when I was doing car repairs but seems to be no longer available.
There seem to be other resin hand cleaners such as Tufanega, Loctite / Henkel 7855 etc. Some people are happy to use Acetone but this dries out your skin, pushes resins into your bloodstream and causes dermatitis. I already have a eczema-like condition caused by use of solvents, petrol, strong hand cleaners etc. Once you have sensitised your skin, there's no easy way back. Best find and use the correct cleansers to start with.
Murray
Lambton22/06/2015 10:26:12
694 forum posts
2 photos
Over the years I have tried just about all commercial hand cleaners and some home formula ones but the best by far is Lidl's W5 Heavy Duty Hand Cleaner available in 500ml tins. Put a little into the palm of one hand and add a little water then rub with the other hand until a creamy consistency ( a little patience is needed here) is obtained then spread it all over both hands an work it in. It removes anything you are likely to use in the workshop.
Martin Kyte22/06/2015 10:52:05
3445 forum posts
62 photos
Make some pastry. Works a treat.
Martin
Russell Eberhardt22/06/2015 10:57:28
2785 forum posts
87 photos
Posted by alan smith 6 on 21/06/2015 17:25:00:Always buy the non powdered variety as some of the powder lubricants have been suspected of causing cancer.
The lubricant in these gloves is talcum powder. There has been an unproven scare that it can cause ovarian cancer: **LINK**. So perhaps you just need to be careful where you put your hands smiley
Russell.
Muzzer22/06/2015 12:12:59
2904 forum posts
448 photos
White cheddar cheese seems to work well too from memory.
Trevor Wright22/06/2015 12:51:43
139 forum posts
36 photos
L'Occitane liquid soap......came with a christmas pack for SWMBO.
It is superior to Swarfega, will not hurt the skin and even removes dried on paint. Not tried it on Leylandi goo but would not be surprised if it did. Thick grease is washed off with very little at one attempt, even fingernails.
It is expensive - but works better than anything I have used in my 40 years in industrial engineering - and I have tried a few.
Trevor - usual disclaimer, very very satisfied customer
Edited By Trevor Wright on 22/06/2015 12:53:01
Nick Moody22/06/2015 13:46:04
7 forum posts
I can heartily recommend 'Scrubs in a bucket' pre-moistened Hand Cleaner Towels for removing just about anything; super-glue, ink, epoxy resin, polyurethane glue, oil; I haven't found anything they won't remove. A bit expensive at around £20 for 72 towels but one towel is all you ever need. I cleaned the smoke box and chimney on a 7.25 Bagnall resulting in a tennis sized ball of oily soot, the really super black sticky stuff. One towel cleaned my hands enough to go straight out for dinner. Also leave you hands soft and smelling OK too!
NickM
Howard Lewis23/06/2015 08:07:02
7227 forum posts
21 photos
Gave up using Barrier Cream, (not that it was not effective) but it it gripped any non rotating handle or socket extension, so that it rubbed the skin.
Often wear industrial gloves, but they are not waterproof, (so your hands can become soiled with dirt carried through in the oil/coolant) and eventually become soft and start to sag or get trapped between the workpiece and the jaw as the vice is tightened.
Washing Up Liquid is good, (with or without sugar/sawdust - never tried salt. NOT if you have a cut!) but dries out my skin, and having had Dermatitis, try to avoid using it. Still using original green Swarfega, IMO, better than the more expensive Orange version.
Hopper23/06/2015 08:53:51
7881 forum posts
397 photos
The only barrier cream I remember from years ago was pretty much pure Lanolin, I would have thought. Never experienced the clay layer mentioned by some.
These days I just use that squeeze bottle handwash from the supermarket plus Solvol soap. Not sure if Solvol is available outside Australia? It is a pumice powder-based soap that is abrasive as well as a soap.
In worst case scenario - machining cast iron or working on stinking dirty old diesel engines - WD40 does the trick. Then wash the WD off with soap afterwards. Probably some highly carcinogenic aromatic solvents in the WD so I try to use it only in desperate cases.
Mark P.23/06/2015 09:35:37
634 forum posts
9 photos
Hi all, some years ago I worked for an airline in the wheel bay, we used a barrier cream which seemed impervious to all the grease/ carbon dust from the brakes but when hands were washed it became soap and left hands squeeky clean and soft as a babies proverbial. Can't for the life of me remember what it was called though. At home I use Manista by Comma from the local cheepy shop works for me.
Mark P.
Rik Shaw23/06/2015 09:37:51
1494 forum posts
403 photos
I try and avoid getting my hands dirty by wearing vinyl disposable gloves. The main problem with them is they dissolve after a while particularly when using oil and solvents (brasso zaps them quicker than anything). On an oily job I have used up to three pairs a day. I keep costs down by buying boxes of 100 at a boot for between £2.50 and £3.50. Also, Costco do them for £3.50 if I remember.
For heavier jobs like yesterdays band saw blade change I use the heavy duty industrial gloves with the cotton wrist - these are unaffected by oil.
Looking back to my teenage at work I spent day after day up to my ears washing parts barehanded in a tank of diesel/paraffin I am surprised my mitts have not fallen of from the abuse.
V8Eng23/06/2015 10:53:32
1826 forum posts
1 photos
I have been using something called "The Really Good Stuff" made by Tetrosyl (maybe Carplan branded), seems to work very well for me.
Edited By V8Eng on 23/06/2015 11:01:43
Bazyle23/06/2015 13:52:32
6956 forum posts
229 photos
If you dunk your hands in white grease on entering the workshop the lowest layer of goo will be white. So after cleaning what oozes out later will be less visible. Some people may need to use a graphite or copper grease here. More seriously perhaps a lanolin based paste would work.
Ajohnw23/06/2015 19:03:38
3631 forum posts
160 photos
I used to use swarfega then one day at a car boot I saw Knight's Castile hand soap. We just bought some out of curiosity as we remembered the add on TV from a long time ago now. For some reason it does it's job and it's what we always have by the sink now. We come across it from time to time and buy it to keep a stock.
I wonder if it works so well because it's real soap. It's rather odd that it will shift oil and grime really. My son wont use it as he doesn't like the smell. My wife and I use it all of the time now.
At work, machine work mainly, they used to have some green gritty stuff. No idea what it was called. The gritty aspect was borax as the company had found that this helps prevent skin infections and dermatitis.
Neil Wyatt23/06/2015 20:10:08
19226 forum posts
749 photos
86 articles
Wright's Coal Tar Soap is the real McCoy
My best investment was a nail brush
