Brazing
Brazing using TIG
Clive Haynes12/06/2014 18:42:47
57 forum posts
9 photos
Just as a point of interest has anybody out there used their tig welder for brazing or silver soldering. It is something I thought about trying when I come to making a boiler for my loco this could save me having to buy heating equipment when I already have a TIG. I have googled the subject and it appears that you can but it would be nice to hear from someone who does use this method and hear of any tips.
Bob Brown 112/06/2014 19:15:20
1022 forum posts
127 photos
Do not think it is possible to braze or silver solder with TIG as the heat is too localized. Assuming a copper boiler you could always weld it but will need De oxydized copper filler rods, helium as a gas and may need to back purge and as always needs to be clean.
Mark P.12/06/2014 20:00:44
634 forum posts
9 photos
Not done it myself, but had a motorbike frame made from 731 tubing which was TIG bronze welded.
Regards Mark P.
Boiler Bri12/06/2014 20:06:11
856 forum posts
212 photos
Hi Bob, that's interesting about the tig welding of copper.
you obviously have experience of this, would you share your experiences ?
I.M. OUTAHERE12/06/2014 20:06:50
1468 forum posts
Hi Clive ,
take a look at YouTube and search for joining dissimilar metals by oxtoolco , not a boiler but it will let you see tig brazing in action.
Ian
chris stephens12/06/2014 20:42:30
1049 forum posts
Hi Clive, I can highly recommend watching Tom's videos at Oxtoolco, damn nice chap, he shows TIG brazing/ silver soldering but there is very little capillary flow, which normally provides a lot of the strength, as the heating is very confined to the area of the arc. It does seem to be a very good technique if you want to build up a fillet, Maybe flux would help with making the filler flow but he didn't try it.
chriStephens
fizzy12/06/2014 23:40:23
1860 forum posts
121 photos
hi bob et al - as an ex coded welder who tigs boilers, why on earth would you want to use helium as a gas? I have used tig to sil solder but its not a good idea - if you get too close it reacts very badly and i wouldnt try it again.
Steambuff12/06/2014 23:55:14
544 forum posts
8 photos
Clive,
I would also discuss your plans with your boiler inspector to get his views.
Ian S C13/06/2014 10:16:23
7468 forum posts
230 photos
If you get too close it will vaporize the silver solder/brazing alloy. I don't TIG myself, but I would have thought that heat penetration would not be very deep, therefore the capillary action would be reduced. Ian S C
Gordon W13/06/2014 10:50:46
2011 forum posts
I have brazed using the old twin carbon arc and a stick welder. Takes a bit of practice but works. Not tried silver soldering with this and don't think it will work very well- to much localised heat. Also good for general heatig eg breaking a rusted joint.
Ian S C14/06/2014 10:14:04
7468 forum posts
230 photos
I too have used the carbon arc method with my stick welder, the last lot of rods didn't work too well, they are just listed as gouging rods. Ian S C
Gordon W14/06/2014 10:22:35
2011 forum posts
Don't gouging rods have a hole down the middle for the air ? I think the quality of carbon rods has gone down, maybe depends where they come from.
Clive Haynes14/06/2014 13:32:34
57 forum posts
9 photos
Thanks for all your replies. I will give it a go on some scrap some time and see how I get on, as the way I see it is that heat is heat and if I was to play the arc around the seam to raise the temp before hand it may work. Of course thats the theory, as with many operations and set ups in the workshop there is always a plan B or even C.
Thanks again.
mike mcdermid15/06/2014 00:16:28
97 forum posts
You will need a special rod we use sifalbronze 32 normal sif 1 or 101 isn't interested and likes to behave in a similar capacity to a spitting cobra only with added fumes and flame
again with the silver even using tig but you must use a flux we buy it from thessco ,primarily I tig aluminium titanium and steel bicycles but ironically my actual oxy acetylene leaves far more to be desired than my tig welding skills, I find it easier to tig 0.5wall tubing than brazing it
i will try to post some pictures
